Old Feb 01, 2013, 02:47 PM
josy11 is offline
Find More Posts by josy11
Detroit, MI - USA
Joined Sep 2004
5s or 6s for 65" Osiris
Hi All,
I have a 65" Osiris that I have flown with a 5S setup that draws about 85-90A in my current configuration. The issue I have is that it puffed several 5S 5000 Nano tech's and I am wondering if this plane might be a bit better behaved if I convert to 6s - I have tried reducing prop on this plane to reduce current draw, but was not pleased with performance on 75-80Amp props
Is anyone there flying with a 6S? - I would actually prefer to keep it 5S, as I have a 10S 2 meter ship that is quite easy on the 5S packs
If you fly 6S on this plane, could you let me know your setup?
If you are flying 5S, what prop and curernt draw are you seeing? - perhaps I just got a bad batch of Nano's. I might add that another flyer at my field also puffed his 5S 5000 nano's as well on the same setup
Thanks!
Joe
Joe F
josy11 is offline Find More Posts by josy11
Old Feb 01, 2013, 05:46 PM
jlachow is offline
Find More Posts by jlachow
Bridgewater, NJ
Joined Nov 2004
Flown several hundred flights on a 5S setup with this plane without having a battery issue. Hacker A50 12S, Castle 100Lite ESC, 16X10 Carbon Fiber prop. Batteries used were Gens Ace 30C 5300's, and THunderpower 25C 5000's. Maybe you are running the batteries too hard or long in time. Never go below 80% of capacity and use throttle management. Average flight time just short of 7 minutes. I also used packing tape on the bottom of the canopy to keep the airflow closer to the batteries.
jlachow is offline Find More Posts by jlachow
Old Feb 04, 2013, 03:02 PM
RCBRUSKI65 is offline
Find More Posts by RCBRUSKI65
United States, MI, Saginaw Charter Township
Joined Feb 2007
I fly my Wind s 50, which is similiar in size on a Hacker A50-16s with a 6s4400 pack and only pull about 60-62 amps. I think that set up is a lot easier in the controller and batteries.
RCBRUSKI65 is offline Find More Posts by RCBRUSKI65
Old Feb 04, 2013, 03:35 PM
Jim Lee is offline
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
josy11,
I'm flying my Osiris on 6s. It has all the vertical that you would need. I fly both the advanced and Masters Sequence with it without any problems. The only thing I would do different, is go to the 6s 5000mAh battery.
My Set-up
Hyperion HP-4035-10 405Kv
Phoenix Ice 100 ESC
6s 22.2v 20c 4000mAh G-Force Lipo
APC 16 x 10e Prop
77Amp load. Input watts 1,600
J
Jim Lee is offline Find More Posts by Jim Lee
Old Feb 06, 2013, 05:27 PM
josy11 is offline
Detroit, MI - USA
Joined Sep 2004
HI All
Thanks for the reply.
AS to the question on how I treat my Lipos, I never fly them more than 75% of capacity, so I don't think that was the cause. I am beggining to think the Hobby King Nano techs are poor quality and will switch out to soemthing else - I am still leaning towards 6S for this setup -
I apprecaite all the responses
Old Feb 13, 2013, 11:26 PM
Jeff Worsham is offline
Find More Posts by Jeff Worsham
AMA 13456 NSRCA 4513
Jeff Worsham's Avatar
Rio Rancho, NM
Joined Nov 2007
Originally Posted by josy11 View Post
HI All
Started flying my 62" Osiris late last summer. Hacker A50-12s, 100A Castle, 16x10 APC. Was new to electric so bought 3 types of 5s 5000 batteries to learn about different brands. All 12 batterys got the same care and treatment.The two Turnigy Nano-techs died (puffed and lost capacity) with only 23 and 25 cycles each. The Zippys and Sky Lipos are still going strong. Over 320 flights on the plane now. I will never buy nano-techs again, of any size.
Jeff Worsham is offline Find More Posts by Jeff Worsham
Old Feb 21, 2013, 04:02 PM
HouseOf4Doors is offline
Find More Posts by HouseOf4Doors
HouseOf4Doors's Avatar
United States, CA, Richmond
Joined Dec 2007
Using 5s 5000's Zippy both 20 and 25 C no problems, Intermediate sequence, plenty power for me.
bp
HouseOf4Doors is offline Find More Posts by HouseOf4Doors
Old Feb 21, 2013, 05:11 PM
mazjag is offline
Find More Posts by mazjag
Marietta GA.
Joined Jan 2011
I`m using the exact same set-up...I have not had any problems so far with the nano techs, but I maybe have less flights...They are just getting warm after about 7 minutes..I`m keeping an eye on the nano techs as I`m not sold on them either.
mazjag is offline Find More Posts by mazjag
Old Feb 25, 2013, 07:03 PM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
All of the nanotechs I've used get hot easier then others. I would try different packs.
Also, the goal of the 5S setup was so that you could use the same packs if you eventually moved to a 2M 10s plane.
(of if you already have a 2M 10S plane, and you wanted a smaller practice plane...you could use the same packs)
I flew mine on 5S with no problems.
HI All
djmoose is offline Find More Posts by djmoose
Old Mar 11, 2013, 01:55 PM
garvin is offline
Find More Posts by garvin
TRINIDAD
Joined Nov 2006
6s 5000 gens ace P-13 easy
garvin is offline Find More Posts by garvin
Wanted Wanted: Motrolfly 4315 for 5s and/or 6s setup Vince_TT Aircraft - Electric - Power Systems (FS/W) 5 Sep 29, 2012 01:10 AM
Discussion 3D Hobby Shop 62" Osiris or 65" Vyper???? r/cmark Electric Plane Talk 2 Feb 16, 2011 01:17 PM
Sold want to trade a BAe Hawk 15 DF ARF by E-flite brand NIB trade for 5s or 6s batteries java8297 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Aug 29, 2009 11:16 PM
For Sale Align 6s 4200 New bat for sale or trade for 5s 5000 & CF Blades rhampton Aircraft - Electric - Helis (FS/W) 0 Jun 12, 2008 06:21 AM
Discussion Which Brusless motor Best For MY Inspire60 5s or 6s huison2005 Power Systems 0 Jan 10, 2008 05:19 AM
