Denver, CO
Joined Dec 2005
A plain router bit made for cutting wood is ok, if sharp. Usually they are harder to find in small sizes. I often use the Rotozip 1/8" bits since they are easy to find locally. The tile cut bit works good. Also I have had good results with the Sabercut bits in foam. I usually mill with these bits at about 7,000 rpm, and 70 inches per minute. Depends on the foam. I usually set the feed to 70 ipm, since that is the fastest I want to run the machine. Then do a test cut, and turn the rpm down until the foam cutting sounds good, (sort of a slicing sound). To much rpm for the feed rate, and it melts the foam. Not good since it builds up on the bit, and makes a ball on the end of the bit.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051 Here is a video of my mill with the 1/8" Saber bit milling Owens Corning XPS pink foam. http://www.rcgroups.com/forums/showthread.php?t=1427681 |
Denver, CO
Joined Dec 2005
Your router might be limited to the lowest rpm it can run at. If you have to run a high rpm you might need to get some much smaller router bits. I use many small sized fishtail chipbreakers. they cut like the foam is not there. This company sells good endmills.
http://www.precisebits.com/products/...s/fcrouter.asp |
Not sure, the tool path was generated by Autodesk's online CNC Utility, http://www.123dapp.com/, and I haven't look at it closely... Will do this next.
http://www.cncroutercentral.com/CNC-...ts-Downcut.asp Which tool diameter do you use? It looks pretty small on your picture... Why using small diameter bit is advantageous? I though that, if the large fillet at the corners isn't a problem, bigger bit would be better, since the cutting speed will be higher. Or do we want to have as low cutting speed as possible, thus small tool adds to this? Sorry for all these silly questions, I'm so new to this whole CNC milling... But I love it so much--your 3D model is converted to a real thing with such high precision! ![]() Thank you, Boris |
United States, PA, Greensburg
Joined Oct 2009
the bit in the picture is one of my milling endmills. I think it was 1/4". Your design will depict the maximum size endmill you can use. My spindle can be setup to take 1/8" shank up to 1" shank though most of my tooling is 3/8". I have milled foamies (the pockets) at over 120IPM no problem though I usually keep it about 80 IPM. I also set up index marks so I can mill on the CNC and final cut on the laser .
I have milled alot of foam. Rohacell, Herex, XPS, etc. Normally I feed at around 80-120ipm depending on the foam particulars. I always try to cut with a 1/4 tool, typically a four fluted radiused endmill. Alot of the advice above could have saved me much grief over the years... used dedicated bits, downspirals for cutouts, etc.
My mill spends most of its time at lower RPM settings in foam, like around 8k. If you go much higher and don't increase your feed rates, you are probably burning and melting the foam as much as cutting it. I get alot of bits from lakeshore carbide... www.lakeshorecarbide.com. They have a great selection, decent pricing and excellent service. |
| Thread Tools | |
| Cool my new cnc foam cutter and cnc milling machine | logicalmetal | Foamy EDFs | 6 | Sep 15, 2010 03:46 AM |
| Discussion Is is possible to CNC mill EPP or similar foam? | FLY...Please | The Builders Workshop | 17 | May 09, 2007 07:35 AM |
| Discussion CNC milling foam | JAS | Indoor Pattern/F3P | 21 | Mar 31, 2007 06:51 PM |
| cnc milling of foam parts? | jenner | The Builders Workshop | 3 | Jun 03, 2003 11:51 PM |
