Old Feb 01, 2013, 11:25 AM
Aeronut41 is offline
Find More Posts by Aeronut41
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Delta Kite on a Trike Question
Hi, I have a 7" delta rogallo wing type kite that I want to use on a simple trike setup similiar to what the guys were doing with the Harbor Freight kites a while back. I have sort of worked out the trike part and plan to use the aluminum channel for the frame. I am wondering if a simple vector steering mount on the motor would have enough authority to steer it or whether the string reverse elevon type arrangement would be better.. The pusher motor of course will be closer to the CL/CG than when mounted as a tractor. Any thoughts on this matter? Thanks, Aero
Aeronut41 is offline Find More Posts by Aeronut41
Old Feb 02, 2013, 04:33 PM
ritchie_laird is offline
Find More Posts by ritchie_laird
ritchie_laird's Avatar
Australia, VIC, Craigieburn
Joined Jul 2012
I have done this, I made a simple trike of Balsa and Carbon Tubing.
steering I used a single servo attached between the wing and the trike which moved the center of balance and the kite banks. for the take off and landing or climbing I used the power of the motor to do that. more thrust and you climb, less thrust and you glide down.
hope this helps.
Ritchie
ritchie_laird is offline Find More Posts by ritchie_laird
Old Feb 02, 2013, 07:00 PM
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Thanks for the comments Ritchie, Keeping the trike simple sounds like the way to go! Best, Aero
Old Feb 02, 2013, 08:39 PM
Joined Jul 2012
your welcome buddy, no point reinventing the wheel till you want to refine it for your purposes.
good luck with it, and put up a video when your in the air with it.
Old Feb 09, 2013, 08:01 PM
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Making some progress and have the basic gondola parts mostly finished. Lots of power with a 12/6 prop! Best, Aero
Old Feb 09, 2013, 08:32 PM
Joined Jul 2012
looking good, its coming along fine. i still have not put the steerable nose wheel on mine as yet. don't forget, when I first put a delta on mine I used the centre of gravity and it did not work, I had to find the centre of lift which I did by holding to the wind and moving my fingers along till the wind held it right. used this as the pivot point.
Old Feb 10, 2013, 04:20 AM
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Thanks for the tip! I'll find the CL on mine that way. Best, Aero
Old Feb 27, 2013, 12:17 PM
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Well, The trike is ready for a little test lift off to see if everything is ok but the weather sure won't cooperate! My pilot is getting itchy or maybe scared Best, Aero
Old Feb 27, 2013, 11:22 PM
Paulnuneaton is offline
Find More Posts by Paulnuneaton
Nuneaton
Joined Aug 2009
Heres a pic of my home made trike and it flew wicked after i upped the prop hope you guys like it
Paulnuneaton is offline Find More Posts by Paulnuneaton
Discussion Flaps on Delta wing Teddy Ong Electric Plane Talk 2 Jan 05, 2013 08:49 AM
Build Log delta trike nadine Foamies (Scratchbuilt) 9 Sep 17, 2011 10:14 AM
Discussion Delta Kite Question Parkerflyr RC Paragliders and Kites 4 May 28, 2011 11:45 AM
Discussion 12 foot Delta Kite RC-Conversion flattermann The Builders Workshop 4 May 15, 2011 02:03 AM
For Sale Monster Delta Kite MrKie Non R/C Items (FS/W) 0 Dec 10, 2006 02:47 PM
