Feb 03, 2013, 09:45 AM
Napa, California
Joined Jul 2006
Hi Mike,
I'm sure it wouldn't hurt to ask Ray, and he's such a nice guy - I've asked him a few questions myself, I don't think he'd mind! It would be a little more challenging perhaps, but you could always trace down the parts that you have onto paper, then draw in the detail of the structure to build? Not sure if that would be something that you would be comfortable doing...just a suggestion? I'd start by asking Ray though which would probably be the easiest!
So, I need to throw this in here too... I'm not certain that what I've done is going to be the best result in the end. Ray's designed a great sailplane here, and the slight additional weight in the tail from solid surfaces may not be a problem. From past experience with other electric sailplanes that I've built, I've found that I needed what I considered to be too much weight up front in order to balance that tail, hence my reason for keeping the tail as light as possible. I think that this is a logical approach but who knows - time will tell! Heck, wouldn't it be hilarious if I had to add weight to the tail? I'm thinking that by moving all of the electronics around I'll be able to find a solution that works -hopefully!?
Cheers,
Rob
