This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Old Feb 01, 2013, 02:19 AM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
MPU9150 integration
With the MPU9150 now on the Marcy3 board, it's slightly bigger than the Ladybird board. Mounting it somewhere which doesn't flex is the next great task.
The dual I2C busses & new capacitors accounted for that. A wishful crystal to get the PIC as fast as possible added some more size. If the PIC does nothing else, it can get 140 readings of all 9 sensors per second. Without the crystal, it can get 80 hz. 50Hz is probably enough for the application.
Being the low end PIC that it is, only software I2C was justified. If it was concerned with the full attitude stabilization, it would need hardware I2C for the gyro/accel part. The trend is now to use STM32F ARMs for even these nano quads.
Jack Crossfire is offline Find More Posts by Jack Crossfire
New Product Micro Integrated PCB w/ESCs Quadcopter Frame 235mm Daniel.A design Mini Multirotors 1518 Feb 06, 2015 11:33 PM
Sold Turnigy Talon Tricopter - Integrated Tail Servo Mount Set With Thrust Bearing Mod flashted Aircraft - Electric - Multirotor (FS/W) 2 Jan 20, 2013 12:07 AM
Sold Turnigy Talon Tricopter - Integrated Tail Servo Mount Set With Thrust Bearing Mod flashted FPV Equipment (FS/W) 1 Jan 19, 2013 10:16 PM
