Old Jan 31, 2013, 11:12 PM
tsecrist is offline
Find More Posts by tsecrist
tsecrist's Avatar
Salt Lake City
Joined Apr 2005
Cellpro 10s and UMX 2 cell battery adapter?
What adapter do I use for the UMX 2 cell batteries.... The fma adapter does not accommodate the plug of the battery???
tsecrist is offline Find More Posts by tsecrist
Old Jan 31, 2013, 11:54 PM
RFreak is offline
Find More Posts by RFreak
United States, MI, Ann Arbor
Joined Dec 2004
Tsecrist- EP buddy has a parra board that lets you charge up to 6 batterys at a time and its only $13.95, so it's not much more than an adapter would be. It's what I use with my PL6 just plug the batterys into the para board balance port and the other plug on the para board into the banana plugs power leads and your set to go.heres the link-http://epbuddy.com/index.php?main_pa...roducts_id=348
RFreak is offline Find More Posts by RFreak
Old Feb 01, 2013, 12:10 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Maybe an adapter like this UMX Beast parallel charge adapter will work. There is also a cheaper version without the banana plugs for a couple of dollars cheaper on the RC-connector site,
You will need a way to connect the JST-XH balance tap of the above parallel harness to the Cellpro's balance port. I would imagine if you use other lipo's with the XH balance taps, that you would already have an adapter for it.
Edit. Oops. Already answered while I was typing.
KC is offline Find More Posts by KC
Discussion Cellpro 10s - A123 3.60/3.65v Preset too high for 6.6V LiFePo4 Battery?? boiko FMA Direct 6 Jun 23, 2013 03:18 AM
Sold Hobby King Multi-battery charging adapter for UMX-type batteries K_B Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 03, 2013 07:02 AM
For Sale UMX series adapter Join 2x 1 cells and make a 2 cell edu01jose Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Jan 20, 2012 06:55 AM
