Espritmodel.com Heli Air
Old Mar 03, 2013, 03:23 PM
St Louis, Mo
Joined Oct 2010
Maiden the Wing today. What a blast!!!
K.Jones is offline Find More Posts by K.Jones
Old Mar 03, 2013, 06:14 PM
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Crack Wing Combat...
Had some informal Combat last night, at an indoor Soccer Arena, with the Crack Wing, on and off over the course of 3 hours there was almost always 2 Crack Wings with streamers in the air, and at some points there were ten or more... Crazy Crack Fun. They held up very well, however, not for the timid..
cdee
cdee is offline Find More Posts by cdee
Old Mar 03, 2013, 06:25 PM
United States, CA, Santa Rosa
Joined Mar 2011
I have a question about the crack wing motors. I bought 2 kits so my flying buddy and I could go at each other. The first crack has about 20 more flights than the second and the motor is about 25% stronger than the second which has less than 10 flights. Is this just a break in thing or could the second motor be bad.
And Cdee, how are you attaching the streamers?
asosestrom is offline Find More Posts by asosestrom
Old Mar 03, 2013, 06:41 PM
Team Twisted!
cdee's Avatar
Joined Jun 2011
Could be the difference in Batteries, if you still have less power even with the same battery, next check that the prop is balanced, an out of balance prop will rob power, beyond that not sure.
Streamers can be attached in various ways, last night I just used the Green High Tack Painters tape, worked just fine. Notice that it is best to put something with a little "stretch" (I used two rubber bands, one split and one whole, tied together as shown in the photos) inbetween the streamer and the Wing as shown, and directly behind the motor will have the least effect on handling.
cdee
Old Mar 04, 2013, 10:21 AM
East Texas
Joined Nov 2008
cdee
How long are the streamers you all use? Are they just crepe paper?
MOfroggy is offline Find More Posts by MOfroggy
Old Mar 04, 2013, 01:19 PM
Team Twisted!
cdee's Avatar
Joined Jun 2011
yes... crepe paper streamers.. all I could find was something about 1.50 inches wide, which want to cut in half, and they should be about 20ft long, just make sure that they are all the same length, as the object is of course to have the longest ribbon after some set period of time in the air....
cdee
Old Mar 07, 2013, 09:28 PM
just an earth-bound misfit, I
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Originally Posted by hercdriver7777 View Post
Left rudder - left ail Up. Right rudder - right ail up.
Gives some yaw effect but also, and more important, gives the left hand something to play with.
I finally got my CW built and in the air today. Awesome little wing!
I'm trying to program the mix you suggest, but my DX7s has me confused. After fiddling with it for about 15 minutes, I am clueless how to mix the ailerons to the rudder.
Murman is offline Find More Posts by Murman
Old Mar 09, 2013, 07:53 AM
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
in my DX8, I had to create my own elevon mix, then mix the rudder into that.
use the rates to get rudder to up elevon only
took me a while
gatorb8 is online now Find More Posts by gatorb8
Old Mar 09, 2013, 07:58 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
hone1er,
I've been experimenting with some scratch versions of the Crack Wing.
Would you be interested in that here or should I post on a new thread.
don't wan't to hijack if ya want to keep this focused on stock crack wing!
Old Mar 09, 2013, 04:03 PM
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Definitely interested. New thread in the scratch builder foamy forum or here.
potshot is offline Find More Posts by potshot
Old Mar 10, 2013, 05:45 AM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Set up a program mix with rudder master - aileron slave. If you change the rate from 100% (either higher or lower) you can also use it as an instant dual rate without having to touch a switch.
Azarr
Azarr is offline Find More Posts by Azarr
Old Mar 14, 2013, 08:10 PM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
I love this Crack Wing design
I scratched a few Crack's out of MPF foam with rudders
I smoothed many of the cuts, eliminated the tabs for quick hand cut and build
made the rudders symetrical top to bottom, flys unbelievable!
hope no one minds if I post it here, if so, I'll delete
Scratch Wing with Rudders (3 min 55 sec)
ScratchWingMini (4 min 11 sec)
Old Mar 14, 2013, 08:23 PM
Murman's Avatar
Joined Jul 2008
Knife edges with a wing! Awesome!
Old Mar 14, 2013, 09:39 PM
Twisted Realm's Avatar
New Jersey
Joined Aug 2008
Looking good gator, rudder mod is cool for sure very cool
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Old Mar 15, 2013, 06:21 AM
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
What is MPF foam? And what motor and battery are you using? Nice videos.
tomcor is offline Find More Posts by tomcor
Sold Twisted Hobbies Crack Yak - LPU Air Candy Aircraft - Electric - Airplanes (FS/W) 5 Jan 30, 2013 12:34 AM
Sold Twisted Hobby Crack Yak - RTF Roly72 Aircraft - Electric - Airplanes (FS/W) 10 Jan 22, 2013 12:18 PM
Sold Twisted Hobby Crack Yak Roly72 Aircraft - Electric - Micro & Indoor Airplanes 0 Jan 21, 2013 07:01 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 178 Jan 02, 2013 11:05 PM
