Old Feb 11, 2013, 10:47 AM
swampflyer is offline
Find More Posts by swampflyer
United States, FL, Keystone Heights
Joined Dec 2012
ive allready been working on that...
been getting her on the sim. lately.. this wing, dialed down, seems a good tool for a newby to pick up some basic orientation skills.
swampflyer is offline Find More Posts by swampflyer
Old Feb 11, 2013, 12:38 PM
Joined Dec 2012
well, during lunch i added the mixes as suggested in the video to get the full throws, maxed them out with travel adjust ending up around 110% and its perfect, without hitting. flew her around for a minute or two in a ton of wind...
WOW.
its a different animal all together now.
with that mix switch and D/R i can get 3 positions now. which is nifty. what were nice tight loops are just ridiculous now and you can hover the thing for a second or two with a bit of wind blowing at you. rolls are much much faster as well.
thumbs will have to catch up. hahaa.
i did have what seemed like something catching inside the motor though. i worked it back and forth by hand and it quit catching. It will occasional stutter when throttle is applied as well? after you play with the wire connection it will stop... ?
Old Feb 12, 2013, 07:18 AM
Dan5.0 is offline
Find More Posts by Dan5.0
Dan5.0's Avatar
Joined Dec 2008
check your solder joints from motor to ESC, sounds like the culprit
Dan5.0 is offline Find More Posts by Dan5.0
Old Feb 12, 2013, 08:13 AM
Joined Dec 2012
will do, thanks.
flew the larger prop yesterday for the first time.
seems a bit slower, smoother. shorter flight time. i like the sound though. haha.
rolls are much much faster. its just ton of fun.
the quickness with which it changes orientation and having to use only the right stick on the transmitter seems to be making me a better pilot with my CYL as well.. flew her yesterday and it just seemed so much smoother. I typically use the rudder alot on my planes... find my left thumb still trying to turn the wing. lol
Old Feb 12, 2013, 08:25 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Originally Posted by swampflyer View Post
will do, thanks.
+1 on the left thumb... lol..!!
cdee
cdee is offline Find More Posts by cdee
Old Feb 12, 2013, 01:45 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
On mine I mixed in ail differential to the rudder stick. That helps a little with giving some input to the left hand. After all these years flying 3D planes I can't just turn off the left hand.
Give it a shot!
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Feb 12, 2013, 05:36 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Give it a shot!
So you're running no differential on the ail stick? yet on the rudder stick? Watching the rolls on some of the videos it looks like some differential might be a good thing, but why on one stick and not the other? Are you just trying to simulate yaw on the rudder stick?
Azarr
Azarr is offline Find More Posts by Azarr
Old Feb 12, 2013, 08:09 PM
Columbia SC
Joined Feb 2005
Left rudder - left ail Up. Right rudder - right ail up.
Gives some yaw effect but also, and more important, gives the left hand something to play with.
Old Feb 12, 2013, 10:25 PM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
I'll have to try it, not quite grasping what it accomplishes, seems backwards. On an elevon plane I'll run R master, A slave but always in the same direction.
L rudder - left aileron up etc.
Azarr
Old Feb 13, 2013, 08:19 AM
Joined Dec 2012
Give it a shot!
i'll give that a try.. might help with trying to get some of those rolls going like in your vid., which is awesome by the way.
Old Feb 13, 2013, 09:00 AM
Columbia SC
Joined Feb 2005
You guys are right, I wrote it backwards. Post edited. Sorry.
Old Feb 13, 2013, 10:07 AM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
FWIW, on an elevon wing I often use the rudder stick as a "dual rate" for the ailerons by changing the mix values higher or lower depending on the plane.
Azarr
Old Feb 14, 2013, 08:58 AM
MOfroggy is offline
Find More Posts by MOfroggy
East Texas
Joined Nov 2008
Maidened my Crak Wing yesterday and I have to say it is VERY much fun to fly. I have 4 of the Nitroplanes POP's in various sizes and The Crak Wing is more fun to me than all of them.
This thing loops in a heartbeat, hovers and does reverse knife edges like some of my flat foamies. I am sure there are a lot more maneuvers yet to be learned by me. (Keep those videos coming!) Does anyone have a favorite maneuver with the CW they would like to share?
You won't be sorry you got one! (And the price is right!)
Joe
MOfroggy is offline Find More Posts by MOfroggy
Old Feb 14, 2013, 10:51 AM
Joined Dec 2012
right on.
i DO have a problem with my wing though...
i need more batteries.
Old Feb 14, 2013, 11:49 AM
jcansdale is offline
Find More Posts by jcansdale
jcansdale's Avatar
United Kingdom, Gunnerton
Joined Dec 2010
What's a reverse knife edge?
jcansdale is offline Find More Posts by jcansdale
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Sold Twisted Hobbies Crack Yak - LPU Air Candy Aircraft - Electric - Airplanes (FS/W) 5 Jan 30, 2013 12:34 AM
Sold Twisted Hobby Crack Yak - RTF Roly72 Aircraft - Electric - Airplanes (FS/W) 10 Jan 22, 2013 12:18 PM
Sold Twisted Hobby Crack Yak Roly72 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jan 21, 2013 07:01 PM
