Old Feb 07, 2013, 05:40 PM
starwarsfan is offline
Find More Posts by starwarsfan
United States, NY, Wyoming
Joined Apr 2011
Question for the guys already flying. On the set up for the first flights is there any "reflex" needed. On other wings I fly it recommends some up trim for the elevator.
starwarsfan is offline Find More Posts by starwarsfan
Old Feb 07, 2013, 08:50 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Yes.... with that said... set up every thing neutral and level on the bench before your maiden.. then when you get out to the park or field dial in 4 or 5 click of up elevator... than adjust from there as needed for level flight... I have found that if you use the recommended CG point it will stay level at all throttle settings. While inverted you will have to push, but it is completely predictable. It does not seem to need the "noticable" amount reflex that a Zagi or other similar wing requires.
cdee
cdee is offline Find More Posts by cdee
Old Feb 07, 2013, 09:00 PM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
fyi....
you will very likely want more than one...!!
cdee
Old Feb 09, 2013, 09:45 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Got to fly my Crack Wing today! That thing is a total blast to fly!
Tisted Hobbys - Crack Wing (3 min 29 sec)
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Feb 10, 2013, 09:00 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
+1..!! I agree, great video too
cdee
Old Feb 10, 2013, 10:07 AM
Murman is offline
Find More Posts by Murman
Go Panthers!!
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
I'm always amazed by your talent, Chris. Great video. Could you share your setup? Did you use Twisted's "Power Combo" or other gear? Thanks
Murman is offline Find More Posts by Murman
Old Feb 10, 2013, 10:32 AM
Columbia SC
Joined Feb 2005
Thanks Murman! Everything there is stock Twisted Hobbys combo and running 7x3.5 prop.
It's a great little performer on the stock package.
Chris
Old Feb 10, 2013, 04:01 PM
K.Jones is offline
Find More Posts by K.Jones
St Louis, Mo
Joined Oct 2010
Im thinking of using a different battery from HK.
http://www.hobbyking.com/hobbyking/s...dproduct=22906
K.Jones is offline Find More Posts by K.Jones
Old Feb 10, 2013, 07:02 PM
Murman is offline
Go Panthers!!
Murman's Avatar
Joined Jul 2008
The 250mAh 2s battery from Twisted Hobbies is 17g. So is the one you linked to. I would say it will work just fine. I've got 4 NanoTech 350mAh 2s packs that weigh 20g I will be using on mine. I doubt 3g will make a huge difference in performance.
Old Feb 11, 2013, 09:04 AM
swampflyer is offline
Find More Posts by swampflyer
United States, FL, Keystone Heights
Joined Dec 2012
maidened mine over the weekend. What a blast to fly this thing. didnt touch my other planes the whole time. Flys slow, flys fast. it was the only thing i flew. gotta get more batteries. speaking of which, my flight times with the smaller prop and the 250 TH lipo were just GREAT. 5 minutes easy. 4 if your zooming around the entire time.. but honestly, i love just gliding down to the ground and blasting out of it inches of the dirt.
my roll rates, however, with the dx6i are not up to par with the vids you guys are posting...? i read the thread regarding the transmitters issue with full travel. they resolve the issue by using the ail and the aux1 channel on the reviever, BUT my issue is i have a micro receiver im using that has no Aux. ports... ?
any suggestions?
swampflyer is offline Find More Posts by swampflyer
Old Feb 11, 2013, 09:40 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
any suggestions?
The Roll rates in the Video I posted are not quite as high as the one from Herc. You can enlarge the cutout slightly to get more of one or the other control, but as mentioned in the Manual and Build Post when checking for bind you need to move the sticks to the corners of the Radio's Gimble for full servo movement.
Glad you all are starting to get the Maidens done on your Wings... and enjoying them... they are very addicting, easy and FUN.
cdee
Old Feb 11, 2013, 09:55 AM
Joined Dec 2012
i think i may have found a solution.
(thanks for the tip cdee.. i'll be sure to check for bind after i make any changes to travel)
How to: Dx6i with elevon mixing to get 125% throw (9 min 0 sec)
Old Feb 11, 2013, 09:57 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
Excellent... I thought I had seen that there was some discussion some where about the the Elevon Mixing on the DX6.
thank you for posting the video / link.
cdee
Old Feb 11, 2013, 09:59 AM
Joined Dec 2012
thought it might be helpful to anyone else with this radio.
(i gotta find a way to talk the wife into lettting me get a new transmitter. lol)
Old Feb 11, 2013, 10:52 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
Just tell her you need a second one so that your and her can both fly...
cdee
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 04:54 AM
Sold Twisted Hobbies Crack Yak - LPU Air Candy Aircraft - Electric - Airplanes (FS/W) 5 Jan 30, 2013 01:34 AM
Sold Twisted Hobby Crack Yak - RTF Roly72 Aircraft - Electric - Airplanes (FS/W) 10 Jan 22, 2013 01:18 PM
Sold Twisted Hobby Crack Yak Roly72 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jan 21, 2013 08:01 PM
