Old Jan 31, 2013, 08:20 PM
ElectFoam is offline
Find More Posts by ElectFoam
Joined Jan 2013
Painting Foam
Helo everyone
My first post here. I am wanting to paint a new a/c that I will be getting and wondering if you thought the attached paint would be ok to use. It will go over the exsisting paint.
ElectFoam is offline Find More Posts by ElectFoam
Old Feb 01, 2013, 11:08 AM
gofish is offline
Find More Posts by gofish
United States, CA, Rocklin
Joined Jan 2006
I'd say you're taking a risk. Testors brand works well as long as you use fine coats.
Water based paints works well too such as Krylon brand, but spraying it on evenly can be challenging.
If you do decide on that particular brand, test a small part of your plane with it, somewhere you can barely notice.
gofish is offline Find More Posts by gofish
Old Feb 01, 2013, 11:45 AM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
ElectFoam,
What kind of foam is your plane made out of?
If it's EPS (beer cooler type) foam or depron, that paint will likely eat it. If you're working with EPO or EPP foam, you'll probably be ok.
Can you share a pic or link to your model?
I agree with gofish...Testors has been ok on every kind foam that I have tried so far.
MRGTX is offline Find More Posts by MRGTX
Old Feb 01, 2013, 03:18 PM
Joined Jan 2013
Originally Posted by MRGTX View Post
ElectFoam,
I will not recieve the plane until next week, but it is EPO foam. Today I did a test on pink foam and white foam from a shipping box, and did not like what I saw. , So I have decided to go with water based acrylic which I did test on another model and liked the results so far.
Thanks for your replys
Old Feb 01, 2013, 08:43 PM
Luiselopez39 is offline
Find More Posts by Luiselopez39
Canada, ON, Burlington
Joined May 2012
Hi, I am actually working in a 737-700 and a MIG-15. And I have a smooth finish using Magikote, a light wait filler "Fast and final" and a water base acrylic polyurethane "Stays Clear" (Benjamin Moore). the surface are smooth and you can not see the shape of the foam, it looks like fiberglass. very happy with the results.
I also bought this week an airbrush and spray gun HVLP, never used those things but I will learn.
Luiselopez39 is offline Find More Posts by Luiselopez39
Old Feb 17, 2013, 05:43 PM
Laneritc is offline
Find More Posts by Laneritc
1st to the scene of the crash
Laneritc's Avatar
United States, GA, Dalton
Joined Jul 2012
so is it better to use a water base spray primer first? thinking about painting ny Ares Gamma 370 before assembly. Thanks for any advise, Lane
Laneritc is offline Find More Posts by Laneritc
Old Feb 17, 2013, 09:53 PM
rdcracer1 is offline
Find More Posts by rdcracer1
Joined Feb 2013
primer coat
"so is it better to use a water base spray primer first? thinking about painting ny Ares Gamma 370 before assembly. Thanks for any advise, Lane "
Just make sure the primer is compatible with the cover coat or you will have a gooey mess underneath
rdcracer1 is offline Find More Posts by rdcracer1
Old Feb 18, 2013, 02:54 AM
bbz is offline
bbz
Find More Posts by bbz
bbz
bbz's Avatar
Australia, QLD, Aroona
It really depends on the foam. Most foam that gets used in packing is EPS (expanded polystyrene) Which melts with most spray paint and superglue. From what i hear EPO will not melt with spray paint and superglue.
If you spray EPS in the sun (so it dries fast) and from far enough away with a few light coats you can get away with minimal melting if any.
bbz is offline Find More Posts by bbz
Old Feb 19, 2013, 04:51 PM
Vethraxx is offline
Find More Posts by Vethraxx
Vethraxx's Avatar
Lynnwood, wa
Joined Oct 2007
I just painted styrofoam using the Short Cuts by Krylon. All was well untill I added the white for the stripes to turn the J3 into a Grasshopper. It ate into the foam, but took a long time to do so. The dark green, and black, no problem. It did not eat through the wing, but certainly made some ditches in the foam. Time to get me an airbrush
Vethraxx is offline Find More Posts by Vethraxx
Old Apr 24, 2013, 10:11 AM
wingman456 is offline
Find More Posts by wingman456
Foam crusher
wingman456's Avatar
United States, MN, Granite Falls
Joined Dec 2011
painting foam
I have had good success painting any kind of foam by first brushing on a thin coat of polyurethane (commonly used on wood). Allow it to dry thoroughly and then lightly sand it smooth with a 220 grit paper. Be careful not to sand through the polyurethane. Then you can use any normal spray paint to color coat the foam. Make the first coat very thin and spray from about 12" away from the foam. Let the first coat dry and spray again as many times as needed for the desired finish.
wingman456 is offline Find More Posts by wingman456
Help! Painting a super cub (Z foam) BiddySlayer Foamies (Kits) 4 Apr 06, 2014 07:38 AM
Discussion paint for z-foam hobby zone supercub? aeronaut999 Foamies (Kits) 5 Jan 16, 2014 08:08 AM
Discussion Paint bleeding under masking on foam. Watdazit Painting and Finishing Tips 11 Feb 22, 2013 10:15 PM
Discussion Dollar Tree Foam paint and tape. Pyrofan Electric Plane Talk 4 Jan 24, 2013 11:00 PM
Discussion Foam Painting azflyingguy Foamies (Scratchbuilt) 2 Jan 08, 2013 10:13 AM
