Old Jan 31, 2013, 06:15 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Video
ESC Problem. . . .
Hi Demondriver here have a look at the problem i'm having with my 75Amp HET ESC on my 707, any suggestions will be appreciated!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Jan 31, 2013, 09:31 PM
rrg is offline
rrg
Find More Posts by rrg
rrg
rrg's Avatar
United States, KY, Edgewood
Joined Dec 2007
May be the "Current Limiting" on the esc. Can you get your hands on a program card? Did you run the throttle all the way up then back down just for giggles....
rrg is offline Find More Posts by rrg
Old Jan 31, 2013, 09:35 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Programming error would be my guess, Were the esc's purchased at different times? It could also be a firmware issue (not upgraded to the latest settings).
foam and tape is offline Find More Posts by foam and tape
Old Feb 01, 2013, 12:22 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
or you've got a bad FET.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 01, 2013, 02:35 AM
Up-Out-&-Gone
Joined Mar 2007
I have the programming sheet that came with it, this a virtually brand new ESC.
Old Feb 01, 2013, 02:37 AM
Up-Out-&-Gone
Joined Mar 2007
Its possible Peter, it works fine on 18 volts but past that is a no go.
Old Feb 01, 2013, 02:40 AM
Up-Out-&-Gone
Joined Mar 2007
A bad FET board, Its possible Rich but it wouldn't run anything if that where the case.
I'm gonna try and fly her on 2 18volt lipos and hope for the best saturday.
In the mean time I'm gonna listen & run down all these Good suggestions.
Old Feb 01, 2013, 11:42 PM
mlee8249 is offline
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
I know this sounds dumb, stupid, impossible...but I had a problem where the motor I had would only studder. Both motor and ESC were brand, spanking new. I figured the ESC was a bum. Called the guy I purchased it from and he said, please clean off the connectors from the battery and the ESC with alcohol.
Whaaaat?!!! Are you kidding me?
He was right. It's worth a try because you have nothing to lose.
Mike Lee
mlee8249 is offline Find More Posts by mlee8249
Old Feb 01, 2013, 11:51 PM
Joined Jan 2009
it could also be that your ESC hasn't been set up at the factory to automatically detect 6S and only automatically detect 1S-5S.
Old Feb 02, 2013, 01:39 AM
Up-Out-&-Gone
Joined Mar 2007
Mike Lee
Thanks Mike, Not a bad idea Sir!
Old Feb 02, 2013, 01:41 AM
Up-Out-&-Gone
Joined Mar 2007
I'm leaning to that explanation the most Rich, if it where truly defective it wouldn't handle any current at all.
Old Feb 02, 2013, 01:42 AM
Joined Jan 2009
for sure. is there no information on the site about it? how about some info on one of the forums? there's gotta be a way to program that, without having the card. a series of beeps while using the transmitter is all you really need.
Old Feb 03, 2013, 05:59 AM
scruffy1 is online now
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
you have the throttle on the wrong stick
nah, just playing with you - no idea why it does that, sorry
scruffy1 is online now Find More Posts by scruffy1
Old Feb 03, 2013, 08:16 AM
rrg is offline
rrg
rrg
rrg's Avatar
Joined Dec 2007
Anything yet?????
Old Feb 03, 2013, 10:53 PM
Up-Out-&-Gone
Joined Mar 2007
Yeah I'm still looking, I might have to step up to a 100 AMp esc.
Discussion SimonK esc and pancake motors problem? milo12 Multirotor Talk 9 Apr 27, 2014 04:41 AM
Help! E-flite Pro60 ESC problems kawika1kalina Power Systems 2 Jan 19, 2013 02:04 PM
Help! Motor/ESC problem after soldering?? low beeps and motor wont start calle3 Micro Helis 0 Jan 14, 2013 12:58 PM
Help! ESC Problem with Turnigy 9x Wrice4 Power Systems 2 Jan 10, 2013 08:20 AM
Discussion TX, RX, ESC, BEC, where is my problem? flybyjohn Power Systems 10 Jan 03, 2013 06:09 PM
