Old Jan 31, 2013, 04:31 PM
rob-sten is offline
Find More Posts by rob-sten
'Rainmaker'
rob-sten's Avatar
Cheshire, UK
Joined Apr 2006
How fast can this go...
Picked up one of these - HK3226-1400
How fast can it be made to go? Without going too daft on ultra-high cost kit that is...
Thinking a new scratch build rather than mouldie, to keep costs under control, ala Ninja Speed style maybe?
Thoughts, comments, suggestions welcome...
Rob
rob-sten is offline Find More Posts by rob-sten
Old Jan 31, 2013, 05:46 PM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Rob
I have a Friend that uses that same motor in a Sundowner 36 on 4s slightly clipped down 9 x 9 APC Electric Prop to 8.5 x 9. clocked at around 145mph and drawing just under 150Amps
I hope that helps
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Feb 01, 2013, 04:11 AM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
Hallo Rob,
For a Ninja-Speed sized Speeder i would take a bigger motor.
Erwin Schaumburger (the designer of the ninja) made some other interesting scratch built projekts as the 2/3 or 4/5 ( these Numbers are more or less the size compared to the Nina)
The 2/3 may be a little small for that Motor,its designed for Funjet-drives, but it may work when you keep airframe light.
I run my 2/3 with HK3026-1400 at 6S and 7x10 but will change to a lighter Drive soon.
http://www.rc-network.de/forum/showt...Funjet-Antrieb
The 4/5 was designed for up to 10S, Schiwo scored 380Km/h with a 3226-900 Kv at 10 S and 7x10.
http://www.rc-network.de/forum/showt...peeder-bis-10s
Your motor will not be able to take more than 6 Cells with reasonable props,so i would have a closer look at Erwins newest design,the Gixxer:
http://www.rc-network.de/forum/showt...ell-der-Gixxer
This Plane is designed arround 250g outrunners and 6 Cells,with your Motor, 6S 3000 and 7x10 i would expect speed arround 350Kph.
For all this planes it is possible to get Plan,CNC milled kit and wingcores.
Regards
Yello
Mreyello is offline Find More Posts by Mreyello
Old Feb 01, 2013, 05:23 AM
hul is offline
hul
Find More Posts by hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
this is basically the same motor as the Kontronik I used on this wing: http://www.rcgroups.com/forums/showthread.php?t=1302684
203mph on 5s on a 7x10
Hans
hul is offline Find More Posts by hul
Old Feb 01, 2013, 11:55 AM
rob-sten is offline
'Rainmaker'
rob-sten's Avatar
Cheshire, UK
Joined Apr 2006
Thanks Guys for the pointers and links.
I now have some research to do before fixing planform and size but The Gixxer looks good.
Good to see some numbers, I have 5S3600 and 6S3000 Lipos already in my OpusGTE, I'm scared to think what ESC I'll need with the 7x10 for this one
Cheers
Rob
Build Log Project Fast and Cheap: just how fast will an Exceed Drift Star go? Bugman Jeff On-road Cars 102 Mar 27, 2016 03:59 PM
How fast 400motor can go????? jason_ices High Performance 34 Sep 17, 2003 03:28 AM
How fast can you go? henke High Performance 12 Dec 30, 2001 03:29 AM
