Old Jan 31, 2013, 04:25 PM
Greg Knipp is offline
Find More Posts by Greg Knipp
Greg Knipp's Avatar
Manitowoc, Wisconsin
Joined Dec 2003
Question
Powerhouse construction
Hello all I am about to embark on a build of a 1/2A sized Powerhouse short kit from Bob Holmann, however, after studying the plans, looking over the parts and searching the many build threads of the Powerhouse on E-Zone I still am a bit stuck on a construction technique and feature of the Powerhouse.
While the trailing edges on most of these styles of models are of the tapered balsa (triangular) style the Powerhouse design employs a flat sheet supported at a slight upward angle by steps cut in the back end of the ribs and the underside of this TE piece is sanded with a slight bevel to conform to the undercamber profile of the airfoil. Somehow this TE piece is married to the tip pieces, which then must lie flat and will terminate at the midpoint of the LE profile. These tip pieces support the back ends of the two tip ribs which have the notches cut on the bottom surface of the ribs.
Now, in my head, I believe I have a mental picture of how this all fits together and it probably is much easily done rather than trying to figure it out. I just want to have things in line before I start gluing wood together and makle foolish mistakes.
So what I am asking is that anyone who has built a Powerhouse could PLEASE help me out and possibly post pictures of how the whole wing tip, TE spar assembly goes together. I would be forever grateful.
I have included a link to show how the wing is designed and hopefully will make it easier to understand what I am trying to explain.http://www.theplanpage.com/Months/2101/phpt2.htm
Thank you in advance for any help that is offered.
Greg Knipp
Greg Knipp is offline Find More Posts by Greg Knipp
Old Jan 31, 2013, 11:40 PM
Chad H is offline
Find More Posts by Chad H
Chad H Fly`n Farmer
Chad H's Avatar
Ancaster, Ontario Canada
Joined Nov 2007
Bob`s doin` one here: http://www.rcgroups.com/forums/showthread.php?t=1809223
He should be able to help you out.
Also, go back to the start of the "Vintage & Old-Timer Designs" forum, click on the blue bar in the upper right where it sais "search this forum", and type in Powerhouse, or Powerhouse build ect. Try different wording.
You should get some threads, and a build or two on it. It`s a very popular, cool looking, and good flying model.
Also, ask williame3590, he has no less than 3 full size, and one the size you are constructing.
You will get lots of help here, they are all good guys. Even the ones from England!
Lmao.................Chad.
Chad H is offline Find More Posts by Chad H
Old Feb 01, 2013, 10:58 AM
RyanNX211 is offline
Find More Posts by RyanNX211
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
Long time ago, but I just filled in with some liberally glue TE stock for a smaller plane at the tips
RyanNX211 is offline Find More Posts by RyanNX211
Old Feb 03, 2013, 09:48 PM
Greg Knipp's Avatar
Joined Dec 2003
Boy I am just not having any luck here getting some bites on this. I have dug through the many threads about the Powerhouse various times and found nothing that helps my situation. I have sent out a few e-mails and PM's without any responses.
Maybe I'm trying to get everybody while they are on vacation or something? I don't know??
Thanks anyway;
Greg
Old Feb 05, 2013, 03:56 PM
Greg Knipp's Avatar
Joined Dec 2003
Thank you one and all.
Discussion Good ARTF fiberglass and wood construction to buy for around £70 - £80($115) tunde20 Slope 4 Jan 04, 2013 06:32 PM
Discussion Powerhelis.com horses Vendor Talk 0 Aug 30, 2009 09:54 PM
Video: Logo20, Powerheli, Joker, Acrobat10 Kraeuterbutter Electric Heli Talk 1 Mar 19, 2005 06:04 PM
