Old Jan 31, 2013, 02:35 PM
garwood9 is offline
Find More Posts by garwood9
Joined Jan 2013
Help!
what prop should i use
i have a2712-17 1700kv silver monster motor with a 30a esc and a 3 cell 1000mah 20c battery on a light ( one sheet of dollar tree fomm ) delta wing. can i run a 7x6 or8x6 prop on it?
thanks for any help i'm new at this
garwood9 is offline Find More Posts by garwood9
Old Jan 31, 2013, 04:35 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
At 24g that motor is probably okay for 72W max...thus 6A-7A max.
7x6 or 8x6 will be too much on 3s.
Aprox Specs:
3 Cell, 5x5 prop, 73.5W- 7 oz thrust
3 Cell, 6x3 Direct Drive , 6A, 63 Watts- 12 oz thrust
3 Cell,7x3.5 Direct Drive, 3s, 7A, 75 Watts- 14 oz thrust
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 31, 2013, 06:48 PM
garwood9 is offline
Joined Jan 2013
thanks for the great info.
any ideas what to use with a 2 cell 1000mah 20 c battery?
Old Jan 31, 2013, 06:59 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
Heads up RC has some data for that motor.
http://www.headsuprc.com/servlet/the...ushless/Detail
Dr Kiwi has lots of data posted, too. I've entered his screen name into the advanced search options more times than I can count.
carlsoti is offline Find More Posts by carlsoti
Old Jan 31, 2013, 09:12 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
8x4 GWS HD is the safest.. if you aren't going to be using WOT a lot, a 9x5 GWS HD is a possibility.
Old Feb 06, 2013, 03:27 PM
garwood9 is offline
Joined Jan 2013
thanks to everyone for the help.
Question What should I use to paint monocote? Rhea The Builders Workshop 6 Feb 08, 2013 02:43 PM
what kind of prop should i use? kushal_22 High Performance 0 Jun 15, 2002 10:49 PM
what prop should I use wallasan10 Parkflyers 6 Jan 21, 2002 08:58 AM
What size prop should I use? ErnieR Foamies (Kits) 1 Sep 17, 2001 11:10 AM
What prop should I use on a Jeti Brushless 15/4 powered Zagi? Ryan Nau Foamies (Kits) 0 Jul 03, 2001 06:11 PM
