Old Jan 31, 2013, 01:39 PM
malcolmm is offline
Find More Posts by malcolmm
Joined Jan 2005
Thunder Power 65C lipo with very high resistence
I bought 8 Thunder Power 6s 7700 65C lipos about four months ago. I have finally finished the plane they are going in and am now charging them (kept at storage charge up until now). The packs will be used in series for 12s.
I noticed that one 6s pack has much higher resistence, 8 to 10 times higher, than the other packs. In addition to high resistence, my charger has a very hard time balancing this pack.
I have tried using different charging cables, different ports on my charger, two different chargers, I get the same result.
Has anyone encountered this problem before, and is there anything I can do other than return the pack to Thunder Power?
malcolmm is offline Find More Posts by malcolmm
Old Jan 31, 2013, 01:48 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Not uncommon to have variability. Far less common with quality packs (TP, Hyperion, etc.).
Absolutely nothing can be done to improve it other than returning to TP for warranty replacement.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jan 31, 2013, 03:21 PM
malcolmm is offline
Joined Jan 2005
I'm most concerned with the huge variance in resistence.
I have contacted Thunder Power about this issue. I was just wondering if anyone had encountered a similar issue and knew of a solution.
Old Jan 31, 2013, 06:14 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
Only solution is to replace the pack, its a dud, happens to all of them.
desertstalker is offline Find More Posts by desertstalker
For Sale Thunder Power 65c 2700mah 6s V55EVO Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 05, 2013 11:26 AM
Discussion Thunder Power 6S 5000 mah 65C Marcz1 Batteries and Chargers 9 Jan 28, 2013 09:52 PM
Sold Thunder AC680 Professional Dual-Power LiPo Balance Charger/Discharger with extras sgonzo818 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Jan 25, 2013 09:47 PM
Discussion High power LiPo power switch DeepThought DIY Electronics 10 Jan 04, 2013 04:15 AM
Sold Thunder Power 65C, Hyperion, and Air Thunder Lipos for sale FL62 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 01, 2011 09:34 PM
