Old Jan 31, 2013, 01:16 PM
serpa4 is offline
Find More Posts by serpa4
United States, NM, Las Cruces
Joined Jul 2005
Buddy box problems. Need assistance
I have two radios that have worked fine in the past when used as a buddy box.
The primary transmitting radio is a DX6i DSM2 and the slave box which my son uses is a JR 6ch standard TX with a digital display. Not sure of the model since I"m at work. The primary radio, DX6i flies the play fine. However, the buddy box radio, when used as a buddy box, has no up elevator control. It only has down. The LCD display on the slave shows the servo movement with up and down, but the servo doesn't go up. Since the plane flies fine on the primary box, obviously the servo works as does the primary radio. If you buddy them up, and give control to the slave radio, there is no up. Take control back to the primary and up works. I cannot test the slave radio directly on the plane since the plane receiver is DSM and the slave radio is not.
There are no mixes, all throws are good, no servo reversing, etc. Checked many times.
Seems the slave radio reads the servo moving on the LCD display, but no up in real life. What is the issue? Bad radio? Dirty contacts in the sticks? If dirty, then why does the display show the servo moving?
Thanks for any advice.
I might have to fine a standard receiver to test the slave transmitter.
serpa4 is offline Find More Posts by serpa4
Old Feb 01, 2013, 02:12 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
That sounds like a weird one, especially down with no up.
I'd say take the box apart and clean the contacts.
Maybe one half is broken.
Check the contact plugs on the buddy cable as well.
Butch777 is offline Find More Posts by Butch777
Old Feb 01, 2013, 02:16 PM
bigtruck169 is offline
Find More Posts by bigtruck169
United States, NY, New York
Joined Dec 2009
can u just bind the JR 6ch directly to the plane? i assume both are DSM system.
My buddy box are dx7 + dx5. no issue at all after almost 2 years of abuse. next step will be dirty contact on radio sticks or buddy box cable plug hold.
good luck
bigtruck169 is offline Find More Posts by bigtruck169
Old Feb 01, 2013, 04:35 PM
serpa4 is offline
Joined Jul 2005
Unfotunately only the master is DSM, the slave tx is standard frequencies. That would have made it simple for sure.
Old Feb 01, 2013, 05:30 PM
jstern429 is offline
Find More Posts by jstern429
United States, CA, Livermore
Joined Dec 2009
Take the back off the JR radio and look at the pot that is connected to the elevator stick . The pot has three wires connected to it. I would be willing to guess that one of the outer wires has come off as this would explain the problem you are having.
jstern429 is offline Find More Posts by jstern429
Old Feb 02, 2013, 11:46 AM
serpa4 is offline
Joined Jul 2005
Well, in an attempt to remove the pot, I broke it completely. Time for a new radio unless I can find a new left stick.
All I really need is a 4ch trainer box really. I hate to throw out a good DX6i for sure.
Old Feb 03, 2013, 04:57 AM
Teddy Ong is offline
Find More Posts by Teddy Ong
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
Well you could get a TSIX by Orange. The trainer cord plug is different but it is a very good copy of the DX6i. Cheap too!
Teddy Ong is offline Find More Posts by Teddy Ong
For Sale 7 FOOT TRAINER BUDDY BOX CORD FOR SPECTRUM and JR $7 shipped 3drcparts Aircraft - General - Radio Equipment (FS/W) 4 Jan 17, 2013 10:35 AM
Discussion Can you buddy box with a dx4e or dx5e?? RcAirplaneNoob Electric Plane Talk 3 Jan 12, 2013 10:17 PM
Question Need Help with a Spektrum Radio Buddy Box Question gabrielisrael Electric Plane Talk 15 Jan 07, 2013 08:45 AM
Discussion Need your assistance troubleshooting a banner ad Matt Gunn Atlanta Area RC 9 Jan 06, 2013 09:27 PM
Discussion Buddy box problems need suggestions. Fishmasterdan Hitec/Multiplex USA 8 Mar 25, 2007 10:35 PM
