Old Jan 31, 2013, 08:57 AM
lynn1953 is offline
Find More Posts by lynn1953
United States, MS, Terry
Joined Feb 2005
Measuring discharging output from charger
I saw somewhere on how to check the actual mah the charger is drawing from the battery during a discharge by putting a voltmeter in between the batt and chrgr. I have seached hi and lo and can't find it again. There was a diagram for the pig tail and I can't recall the details. I think it was actually a calibration check for the charger. If anyone can help I would really appreciate the feedback. I have a accucyle elite and a 306b that I would like to check to see what is actually being pulled from the batt.
lynn1953 is offline Find More Posts by lynn1953
Old Jan 31, 2013, 09:55 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Why not just put a watt meter between the charger and battery?
Though you have to remember anytime you do a check like this it's only as accurate as the device measuring it.
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 31, 2013, 10:38 AM
lynn1953 is offline
Joined Feb 2005
I don't have a wattmeter(yet) but I have an Fma DVM shunt that when connected with a dvm in between a battery and motor will show the amps a motor pulling. I would guess that might work.
Old Jan 31, 2013, 10:39 AM
United States, MN
Joined Feb 2011
Yep that will work. The charger is no different from a motor, they are both discharging the battery.
Old Jan 31, 2013, 10:49 AM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
A shunt / DMM will register current (mA, A) but has no ability to record capacity (mAh, Ah).
mrforsyth is offline Find More Posts by mrforsyth
Old Jan 31, 2013, 10:56 AM
lynn1953 is offline
Joined Feb 2005
Thanks, I I thougth it was logical but I didn't want to let the smoke out of something
Old Jan 31, 2013, 11:10 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Any decent charger with a LCD dispaly will show the mAh removed from the battery during a discharge jusr rge same as they show mAh delivered to the battery during a charge.
See graph and text here
http://www.rcgroups.com/forums/attac...mentid=4165842
Note charge stated at Storage Level.
Charles
Old Jan 31, 2013, 11:39 AM
lynn1953 is offline
Joined Feb 2005
Thanks Charles. I was just curious if the chargers would match close to what the charger was telling me. What is bugging me more than anything is how I can stumble across something doing a search and can never seem to retrace my search to find it.
Old Jan 31, 2013, 11:59 AM
touche is offline
Find More Posts by touche
Canada, MB, Winnipeg
Joined Jan 2006
LOL..I have a whole book of bookmarks on stuff I stumble across.
touche is offline Find More Posts by touche
Discussion Measuring motor RPM from recorded motor sound using free software vinnieg Electric Motor Design and Construction 5 Feb 01, 2013 10:00 PM
Question PPM and RSSI output from a NON-telemetry FrSky nige838 FPV Talk 4 Jan 29, 2013 06:10 PM
Sold Thunder AC680 Professional Dual-Power LiPo Balance Charger/Discharger with extras sgonzo818 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Jan 25, 2013 09:47 PM
Alert USD 10 Discount SKYRC 400W 10A Dual Output Balance Battery Charger / Discharger szewang2805 Hot Online Deals 0 Sep 11, 2012 10:15 PM
