Old Jan 31, 2013, 07:44 AM
Chophop is online now
Find More Posts by Chophop
A jewel in the junkpile !
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
Question
Engine Fit Question
Is there a list of planes the RCGF 15cc will fit entirely in the cowl of and power it for at least a slow unlimited vertical ? I assume it is an attempt at replacing a 60 glow engine.
RCGF 15cc vs NGH9 comments wanted also.
Chophop is online now Find More Posts by Chophop
Old Jan 31, 2013, 03:32 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
The RCGF 20cc directions suggest that air exits to the cowl should be 3 times the size of the intake hole. What I am saying is that you need exit vents, whether or not the engine sticks outside the cowl.
If the engine is completely inside the cowling, it may overheat badly.
wuest3141 is offline Find More Posts by wuest3141
Old Jan 31, 2013, 04:33 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Slow unlimited vertical? would come down to power to weight ration.
Thermalin is offline Find More Posts by Thermalin
Old Jan 31, 2013, 09:53 PM
Chophop's Avatar
Joined Sep 2006
That I already knew Thermalin. But thanks for the tip.
I'm looking for someone who has already done it. I may hop on down to the NGH9 but I have only seen it running wet and oily at the cylinder top .
Old Feb 01, 2013, 07:01 AM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
Yup, it's best to use the weight up before the power.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Feb 01, 2013, 07:18 AM
Chophop's Avatar
Joined Sep 2006
What airplane can I use that this the motor fits in ? I see them with the motor sticking out and or no cowling. Maybe just stick with electrics then. I don't like such an investment in time and money looking like a rig.
Old Feb 01, 2013, 09:10 AM
AMA 537620
Joined Oct 2008
Best bet is probably a .60 sized Sukhoi or Yak, those big radial cowls usually cover most of the engine. You will need a hole for a glow ignitor, needle valve and exhaust pipe at the very least. Most of the other aerobatic planes, Extra, Edge, Cap etc have a wide cowl and the head will usually be close to flush with the cowl if mounted sideways. Most smaller planes, those under 1.20ci/20ccish size will have some part of the engine projecting through the cowl, it's just something you have to expect.
Old Feb 01, 2013, 10:22 AM
Chophop's Avatar
Joined Sep 2006
Yea, a YAK would fit me well, my old nickname was Motormouth.
Discussion comercial source for onboard starter to fit DLE/DA/MD engines Big Nuts 181 Giant Scale Airplanes 4 Jan 20, 2013 11:48 PM
Question Saito FG-14B 4-stroke 14cc gas engine, fits in ? DogFly. Beginner Training Area (Fuel) 4 Jan 18, 2013 10:42 PM
Discussion Hangar 9 60 corsair engine question... shamrock1990 Engines 9 Jan 16, 2013 10:45 AM
Question Engine question, please need answer. Turqui Engines 5 Jan 15, 2013 02:02 AM
