Old Jan 31, 2013, 12:17 AM
Spyde is offline
Find More Posts by Spyde
Denmark, Region Zealand, Jyderup
Joined Jun 2010
LED steps on 6s??
Dó any of you know if those LED strips Can handle 6s??
Its the Big led strips from altigator
Spyde is offline Find More Posts by Spyde
Old Jan 31, 2013, 04:12 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Most LED strips are rated at 12 Volts, so not advisable to connect directly to 6S. Perhaps you can connect two in series?
GordonTarling is offline Find More Posts by GordonTarling
Old Jan 31, 2013, 03:16 PM
jlouden is offline
Find More Posts by jlouden
Joined Nov 2003
You are going to need a 12v regulator. You can wire a 7812 very easily between the batteries and the LED strips.
jlouden is offline Find More Posts by jlouden
Old Jan 31, 2013, 03:40 PM
rcsnow is offline
Find More Posts by rcsnow
Joined Jun 2012
Yep, this should work.
rcsnow is offline Find More Posts by rcsnow
Old Jan 31, 2013, 04:49 PM
Michael64 is offline
Find More Posts by Michael64
United States, TX, Thrall
Joined Feb 2010
You can also use your balance tap from your battery and get a male end and the connector or just solder the wire to the male tap. Then you can have either 3s or 4s you pick thats what I do on my 6S machines. No regulator needed with this method.
Michael64
Michael64 is offline Find More Posts by Michael64
Old Feb 01, 2013, 02:49 AM
caotri is offline
Find More Posts by caotri
Hochiminh City
Joined Mar 2004
Michael64
cut them in to 2 and conect in serial.mthat is what I did on my multicopter which run 5 or 6 s. the 7812 will geting crazzynhot ifmused.
caotri is offline Find More Posts by caotri
Build Log Micro / mini canopy from plastic bottle...step by step bulesz Mini Multirotors 35 Feb 25, 2013 04:51 PM
Question 1115/2.5d on 6s? biskit High Performance 2 Jan 08, 2013 02:27 AM
Discussion percentage power steps to run led setup pshappens Power Systems 2 Jan 29, 2009 07:40 PM
Discussion Step-Up Transformer for LEDs / Small Switches Frankenator Flight Accessories 13 Jun 20, 2008 07:13 PM
Help! Dead LED on Optic 6s maguro Hitec/Multiplex USA 1 Jan 29, 2008 01:20 PM
