Old Jan 30, 2013, 10:06 PM
miniquad22 is offline
Find More Posts by miniquad22
miniquad22's Avatar
United States, CA, La Mesa
Joined Dec 2012
Accucell 6 input volt err
Hello I'm getting an input voltage error message on my accucell 6 charger when I'm trying to charge my 5000mAh 3s sky lipo. My power supply gives off 13.7-13.8 volts, so is this not enough? What power supply should I use to charge my battery?
Any input is much appreciated.
miniquad22 is offline Find More Posts by miniquad22
Old Jan 30, 2013, 10:34 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Voltage is fine. How many amps does the power supply give?
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 30, 2013, 11:08 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
5A x 12.6v (3S) = 63W
AC-6 is only good for 50W. Try a lower charge rate, like 4A. You are likely maxed out assuming you PS is good for AT LEAST 5A.
flydiver is offline Find More Posts by flydiver
Old Jan 31, 2013, 10:51 AM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
Your particular 12 volt power supply does not have adequate current capacity. Also the charger will not get to 5 amps. More like 4.2.
Obtain a higher capacity power supply or or reduce the charge rate.
Rich in ILM is offline Find More Posts by Rich in ILM
Old Jan 31, 2013, 01:37 PM
United States, MN
Joined Feb 2011
I use a 12v supply with my Accucell 6 all the time and have no problems. Volts have nothing to do with amps in the way you are stating. They are two completely different things. Volts x Amps = Watts. That's all there is to it.
Yes it will only get to about 4A charging a 3S but getting a higher capacity power supply will not change that. It's a 50W charger, the charger is the limit not the power supply as you say. 50W max / 12.6V (fully charged 3s) = 3.96A charge rate limit.
Suggest reading this page for more info:
https://sites.google.com/site/tjingu...w-tos/shopping
Old Jan 31, 2013, 02:35 PM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
I had a typo at the front of my reply. I have corrected it.
Old Jan 31, 2013, 11:43 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Makes no odds .. the ccucel is same as my B6 internally ... you can set it to as many amps as you like but it will only run up to the 50W max ... and contrary to popular posts - it means 50W total ... so actual output is reduced by losses / heat etc. and you really get less than 50W via your charge leads.
The OP is getting Voltage Input Err ... so something is not connected right.
Page 32 of the ACC 6 manual says that INPUT VOLTAGE ERR = input voltage is below limit set.
Therefore power supply is not meeting required level. This could be due to poor connection ... bad plug ... creating high resistance ... or an insufficient rated power adaptor. Power adaptors quote volts / mA but in fact are rated at VmA ... that is basically Watts. So it may say 12v ... but if it's a low mA adaptor - it will struggle to supply.
Second - you need a very smooooooth power supply to the charger. I have lots of 12V / 5A adaptors at home from various such as high power rechargeable flashlights etc. None of them will work with my B6 (same machine as Acc 6) ... they are too rough a supply. I need to have a smooth REGULATED PC power adaptor ...
Nigel
Nigel
solentlife is offline Find More Posts by solentlife
Old Feb 01, 2013, 06:04 AM
AlastairL is offline
Find More Posts by AlastairL
Noob making progress
Australia, NSW, Mt Colah
Joined Oct 2012
I had a similar problem trying to use an auto PB charger. In this case, the unloaded input was too HIGH, ~ 18v. As you can't get lipo load on before the input error cuts out, no go.
Solved by killing 2 birds with one stone.
Connect car charger to my field battery, (60Ah car battery).
Then clip the field tap to the battery and A6. Charge lipos @ 5A while topping up field battery for the day.
Alastair
AlastairL is offline Find More Posts by AlastairL
Old Feb 01, 2013, 06:23 AM
solentlife's Avatar
Joined Jan 2010
The B6 is rated to take 18V .... seriously.
Quote from my manual :
Specifications
Operating voltage range: DC11.0~18.0 Volt
As to using a Pb charger ... a Car accumulator charger - I doubt it would work anyway - it's too 'dirty' a charge ... it actually relies a certain extent on it NOT being a smooth steady charge load to keep jolting the car battery ...
Its one of the reasons you cannot power much with one other than charge a car battery ! Even the clever auto-detect ones are not clean.
The only way is a regulated smoothed power adaptor ... or Computer power box.
Nigel
Old Feb 01, 2013, 07:45 AM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
[QUOTE=solentlife;23999087]. The B6 is rated to take 18V .... seriously.
Specifications
The only way is a regulated smoothed power adaptor ... or Computer power box[QUOTE=solentlife;23999087].
Connectiing a car battery charger to a 60ah car battery works quite well. The supplied voltage, is then, quite smooth and stable.
Old Feb 01, 2013, 09:03 AM
solentlife's Avatar
Joined Jan 2010
Absolutely ... in fact you could do it with a lesser battery as long as Charger is not too much for it. My point was that a car charger is a dirty form of charge ... and is why it doesn't work by itself.
Thje same applies to many of the cheap 600W or similar generators with 12V as well as mains output. The 12v supply is crude and often not smooth enough for many items. So for our purposes if it won't power a LiPo charger ---- add a battery to smooth it out.
Just for info ... if you find your cheapo generator will not run your fancy auto-detect Car charger ... - try an older non auto-detect car charger ... they usually don't care about dirty mains input. I have an old 4A plain charger ... that works of any 220 - 240V mains supply no matter how 'rough'. But my auto detect won't even start charging from my 600W genny ...
Nigel
Help! Turnigy Accucel-6 50W 5A Balancer/Charger Battery Vol Err lquick Batteries and Chargers 14 Jun 06, 2014 09:32 PM
Discussion Turnigy Accucell-6 input vol err slein69 Electric Power Cars 6 Feb 05, 2013 08:56 AM
Sold Turnigy Accucel-6 50W 6A Balancer/Charger - $24 shipped nuttcaze Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 09, 2013 12:35 PM
Sold Turnigy Accucel-6 50W 6A Balancer/Charger FieldofDreamsFlyer Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 07, 2013 05:03 AM
