Old Jan 30, 2013, 07:24 PM
flying jeep is offline
Find More Posts by flying jeep
Brownsburg, Indiana
Joined Aug 2005
Question
What's a good radio for sailplanes?
I have a large, 4m, sailplane that I'm about to build. It looks like the Spektrum DX6i I recently purchased does not have enough channel capasity for what I'm building. I'll have flaps, ailerons, rudder, elevator, and throttle. Yes, it's electro. But I thought I would spread this question around the other sailplane forums to see what turns up. As always, I'm shopping on a seriously tight budget. So tight, I may have to buy used and a piece at a time.
flying jeep is offline Find More Posts by flying jeep
Old Jan 31, 2013, 07:30 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
If you are serious about scale, the more channels the better.
JR: 9503 (9 ch), 11X (11 ch), 12X (12 ch)
Spectrum: DX8 (8 ch) or DX18 (18 ch although only the first 12 are proportional, the rest are for accessories)
You get the drift, Futaba has radios up to 18 channels, Airtronics and Hitec have 10 and 7 channel radios. Yes, you can do a lot with Y cords, but nothing makes programming easier than a servo/channel per surface.
I suggest you save your pennies and buy the best, highest capability radio you can.
tkallev is offline Find More Posts by tkallev
Old Jan 31, 2013, 11:43 AM
jcstalls is online now
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Dito
Plus, consider a good used JR XP9303 module based system. Being module based you can use nearly whatever system receivers you desire; DSM2, XPS, Assan, Flysky, Futaba and so on 2.4.
I have seen good used units here on RCG for around two bills.
http://www.google.com/search?q=XP930...=2133&bih=1078
Jared
jcstalls is online now Find More Posts by jcstalls
Old Jan 31, 2013, 12:25 PM
rc4fun is offline
Find More Posts by rc4fun
Maryland
Joined Dec 2002
The new Jeti's look nice too.
http://www.espritmodel.com/jeti-dupl...nly-radio.aspx
You can also use Match Box and other channel expanders but in the end it ends up costing about the same as a high end radio and the install is much more complex.
The Futaba S-bus can make installing lots of servos neater and easier.
rc4fun is offline Find More Posts by rc4fun
Old Jan 31, 2013, 01:40 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
8 ch is not enough channels. Get a 10/12 or 18.
Ail 1
Ail 2,
Flap 1,
Flap 2,
Air brake 1,
Air brake 2,
Rudder,
Elevator,
Tow release,
Gear,
Motor
There's 11 for a standard 4m such as an aSW 20. Go bigger and you could have another 4 for additional ailerons/flaps and 1 for redundant elevator.
jimbo320 is offline Find More Posts by jimbo320
Old Jan 31, 2013, 03:35 PM
mario alvarez is offline
Find More Posts by mario alvarez
Fight On!
mario alvarez's Avatar
San Salvador, El Salvador
Joined May 2001
Airtronics SD-10G. Can't say enough good things about it.
mario alvarez is offline Find More Posts by mario alvarez
Old Jan 31, 2013, 07:07 PM
cooper998 is online now
Find More Posts by cooper998
Nothing like a good WOODIE!
cooper998's Avatar
USA, DE, Newark
Joined Jun 2005
Plenty of Futaba 9c radios out there at good used prices, some even with a 2.4 module. A great radio that also has specific sailplane programming.
You may also want to check out some of the other brands on 72 mhz, many have upgradable modules for 2.4 available
Tony
cooper998 is online now Find More Posts by cooper998
Old Feb 01, 2013, 01:17 AM
dgliderguy is online now
Find More Posts by dgliderguy
Where's the lift?
dgliderguy's Avatar
United States, WA, Snohomish
Joined Mar 2001
I might add that any radio with side sliders is a good idea for sailplanes-- especially powered sailplanes. I have a big motorglider with spoilers, and I use the throttle stick for engine throttling, and a side slider (JR9503 radio) for my spoilers. Without the slider, I would have to use a switch for spoilers (all up/ all down). That works, but not as well as proportional.
dgliderguy is online now Find More Posts by dgliderguy
Old Feb 04, 2013, 03:01 AM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
Futaba 14MZ
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Feb 04, 2013, 08:41 AM
tkallev is offline
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I only use sliders until I have the camber amounts for the various flight modes ironed out, then disable them.
Old Feb 04, 2013, 10:02 AM
Seadog is offline
Find More Posts by Seadog
Seadog's Avatar
Canada, BC, Bowen Island
Joined Jan 2004
A Second Look?
So, back to the original question. There is no mention of "Scale"; in fact it sounds non-scale and as stated, just looking in various forums for ideas. There is also a mention of a "seriously tight budget".
Therefore, jumping in with "ya gotta have 8-10-12-14 channels (pick one) for your future scale happiness" (or words to that effect) isn't helping. The fact is, he can fly the electric sailplane with his 6 channel radio, with flaps on a y-lead with adjustment, controlled by a slider. Dgliderguy has it pegged.
Dave Smith
Seadog is offline Find More Posts by Seadog
Old Feb 04, 2013, 04:13 PM
Joined Jul 2004
Hitech Araura 9 might be the answer..... great value for money!
Old Feb 04, 2013, 09:31 PM
bleker is offline
Find More Posts by bleker
bleker's Avatar
Kingdom of Sweden, Västra Götaland County, Gudhem
Joined Feb 2008
Graupner MC 19 And newer
bleker is offline Find More Posts by bleker
Old Feb 05, 2013, 12:55 AM
tkallev is offline
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Since the question was posted in the Scale forum, assuming future scale planes is not unreasonable.
Old Feb 05, 2013, 01:02 AM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
If you are looking for easy glider setup, radio range to no end, telemetry and great support you should seriously look at the Hitec Aurora A9. It is priced way below some of the mainstream brands and is a bargain in my opinion.
Highfly! is offline Find More Posts by Highfly!
Discussion One more "What's this sailplane thread" jolly01 Thermal 9 May 29, 2015 03:19 PM
Discussion What's a good gyro setup for 3D jtaylor996 3D Flying 27 Jan 18, 2013 02:08 PM
Question What's a good ESC for a 450 size heli? Mr. Wiz Electric Heli Talk 11 Jan 03, 2013 07:20 PM
Discussion What's a Good JR Radio for Sailplane Application Johnnie Paul Radios 15 Jul 18, 2006 08:54 AM
