Old Feb 11, 2013, 10:46 AM
johnbyrne is offline
Find More Posts by johnbyrne
Often wrong ("wife")
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
Oh yea, I have noticed that fuel makes a big difference in a break. If you run say 10% cool power you may get no break but put 10/29 all castor fuel in her and at times the motor will break. I tend to run 10/22 half and half most of the time and get good results but for say a Fox 35, you need the high castor fuel to get the right run.
johnbyrne is offline Find More Posts by johnbyrne
Old Feb 11, 2013, 11:25 AM
tigreflyer is offline
Find More Posts by tigreflyer
Joined Apr 2012
Originally Posted by GallopingGhostlr View Post
Here's my 4-2-4 engine, a Testors Series 21 McCoy .40 Black Head. Been testing it by retrofitting a lightweight YS muffler to cut the bark for in-city flying. Today's runs proved it runs fine without overheating.
I learned to fly well on a Voodoo with a black head 40 on a surge tank. Listening to that sucker break was like listening to fine music.
tigreflyer is offline Find More Posts by tigreflyer
Old Feb 11, 2013, 01:20 PM
GallopingGhostlr is offline
Find More Posts by GallopingGhostlr
Vintage Aircraft Lover
GallopingGhostlr's Avatar
United States, NM, Clovis
Joined Jan 2013
I've got some building to do, tigreflyer. Already have a Sterling 42 in (1067 mm) wingspan Profile Grumman F6F Hellcat reserved for it. Shooting for early summer first flight.
If all goes well, I'll see about videoing it.
GallopingGhostlr is offline Find More Posts by GallopingGhostlr
Old Feb 11, 2013, 02:21 PM
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
While I have no first hand knowledge of this, I have been told that the McCoy engines were based on Fox designs so they should run very similar. With that said and assuming there is some truth behind I bet I know exactly how sweet that 40 black head sounds
Old Feb 11, 2013, 03:45 PM
Traian is offline
Find More Posts by Traian
Traian's Avatar
United States, GA, Roswell
Joined Mar 2008
Yes the timing dictates the break from 4 to 2 and back to 4. Some have softer break run faster rpm lower pitch props while other break harder run lower rpm and use a higher pitch.
And yes the fuel plays part in it too. The Castor help with keeping the motor cool and motors run away because they get hot and cannot cool down. They can also run away because poor installation improper cooling weak mounts (that turn fuel to foam).
The critical point is again what to do in order to achieve the proper response. And above all you cannot make an LA40 behave like a Fox35. They are completely different animals timed differently and behave different. But they both bolt on a Twister or a Cardinal or a Smoothie. Some planes have more wing area some thicker airfoil some are profile or built up fuses and guess what you can make either motor run fine. The challenge is to find the proper receipt for you particular slice of cake and the receipt calls for a proper prop, for proper cooling, for rigidity, for proper fuel delivery, for proper fuel, for proper needle and venutri, and the search is to find a user friendly set that is not picky and so narrow that it runs completely different with the slightest change in temperature and pressure.
Traian is offline Find More Posts by Traian
Old Feb 11, 2013, 06:18 PM
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
100% agree
Old Feb 16, 2013, 08:08 PM
Joined Jan 2013
Welll said. Agree wholeheartedly with the "user friendly set that is not picky and so narrow that it runs completely different with the slightest change in temperature and pressure."
Old Feb 25, 2013, 07:11 PM
badbill is offline
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
Here's my Brodak .40, 2 hole spraybar. I think it does pretty good!
Bill Davenport
AMA 28141
Brodak .40 Four Stroke Break (0 min 13 sec)
badbill is offline Find More Posts by badbill
Old Feb 25, 2013, 07:22 PM
Joined Apr 2012
I'm hearing it friend! Your fuel system is obviously correct and your engine picks up, I'd guess maybe 800 -1000 RPM when it goes vertical. But I don't hear a classic break like one would expect from a McCoy, a Fox 35 or an OS Max S 35. Those engines clearly break from a 4 cycle to a 2 cycle. Nice plane BTW, were I to build a stunter it'd end up looking much like yours.
Old Feb 26, 2013, 07:19 AM
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
Hey Bill,
Nice looking plane, Vector right? The Brodak 40 sounds good. With that said, that isn't what I call a classic 4-2-4 break but I bet it does it in the air. The break has something to do with the engine loading and unloading, not going lean due to pointing the nose up I think. The "break" happens much quicker than your video. Does the plane take off in a 2 cycle and then go into a 4 cycle in level flight? This is what a classic break does and then breaks into a 2 when you do turn and the plane slows. I think this is when the prop loads up a bit more and makes it break.
Old Feb 26, 2013, 10:39 AM
badbill is offline
Habitual Freeloader
badbill's Avatar
Joined Dec 2002
Pretty much agree with all above, except that I should have clarified- The video shows what I tune for to get the break in the air. You are never going to hear the true break without a load on the prop. I also have a Stuka Stunt OS 35 with an awesome break. The plane is the Vector ARF, flies real nice.
Bill Davenport
AMA 28141
Old Feb 26, 2013, 12:12 PM
Traian is offline
Traian's Avatar
Joined Mar 2008
Bill Davenport
AMA 28141
Bill it sounds a little rich still. It should sing when you get the nose up and transition a bit faster. Try to hold with the nose up and lean till it maxes out then put the model level and you should notice the drop. That will be the happy place for that motor. When you get it with the nose up it struggles to get from 4 to 2. By the time it gets to 2 you already finished the loop or you are in trouble on the wing over due to lack of response.
The question is what does it do in the air.
Old Feb 26, 2013, 12:14 PM
badbill is offline
Habitual Freeloader
badbill's Avatar
Joined Dec 2002
You will always have to fly it a couple times to get it perfect. I have about a dozen flights on the motor / plane, the video was done after I had to dissassemble and tune again after getting some crap in the fuel tank and motor- An older hypo got pieces of rubber in it. As a side note, my son and I had a blast doing this in the yard.
Bill Davenport
AMA 28141
Old Feb 26, 2013, 12:24 PM
Traian is offline
Traian's Avatar
Joined Mar 2008
Add a fuel filter on the intake line or clean the tank thoroughly and filter the fuel when fueling. Ceramic car fuel filters work great to filter the fuel that goes in the tank. One lean run on a motor can kill it.
Old Feb 26, 2013, 05:06 PM
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
Bill Davenport
AMA 28141
Yep that is what I kind of figured Very nice looking Vector. My Vector is a wonderful plane.
Discussion What 2.4 GHz DIY will work with Robbe Multiswitches? HelgeBe Radios 3 Aug 23, 2013 11:30 AM
Question What is available for starting really big gas engines? Sackie Giant Scale Airplanes 95 Mar 02, 2013 07:37 AM
Poll What will you by if Multiplex make they 2.4 m-Link modules FCC compliant tiju000 Radios 105 Dec 07, 2009 08:23 AM
Help! How do and what do i need to start my engine?? Roter Wash Fuel Heli Talk 4 Jun 23, 2008 08:20 AM
