Old Feb 01, 2013, 09:07 PM
Bigiron is offline
Find More Posts by Bigiron
Bigiron
Wichita KS
Joined Oct 2010
Veco 45 is pretty good at 4-2-4 ing
Bigiron
Bigiron is offline Find More Posts by Bigiron
Old Feb 03, 2013, 12:21 AM
johnbyrne is offline
Find More Posts by johnbyrne
Often wrong ("wife")
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
Brodak 40 has a pretty good break .. though some report they couldn't get the run right while others have very good luck.
johnbyrne is offline Find More Posts by johnbyrne
Old Feb 03, 2013, 07:05 AM
steve111 is offline
Find More Posts by steve111
Joined Feb 2009
The Enya 09-IV will (not sure about the earlier marks but don't see why they wouldn't). Also the Enya 45-I.
steve111 is offline Find More Posts by steve111
Old Feb 03, 2013, 10:40 AM
stuntflyr is offline
Find More Posts by stuntflyr
stuntflyr's Avatar
United States, AZ, Tucson
Joined Jun 2010
Super Tigre G21 46 and V60 are great 4-2-4 engines.
OS FP 15's, 40's and 46's are high rpm/lowpitch prop engines. So are FSR's.
I've run Foxes both ways, 4-2-4 and high R's.
McCoy 19's, 35's are 4-2-4, Stallion 35, Veco 19, 45, Torp 45, etc are too.
Any newer stuff I had are all piped PA's.
Chris...
stuntflyr is offline Find More Posts by stuntflyr
Old Feb 03, 2013, 08:57 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Yeah, the enya will, but it's a bit feeble doing it.
Curare is offline Find More Posts by Curare
Old Feb 04, 2013, 04:06 PM
tigreflyer is offline
Find More Posts by tigreflyer
Joined Apr 2012
I'm looking forward to the next contest at Whittier Narrows. I'll make a list and listen very carefully.
tigreflyer is offline Find More Posts by tigreflyer
Old Feb 04, 2013, 05:15 PM
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
Oh yea, don't forget the modern engines like the PAs if you can still find one. They have a wonderful break too though to me not as much as say a ST V60 but still a very nice break.
Old Feb 04, 2013, 06:41 PM
The Kiwi is offline
Find More Posts by The Kiwi
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
Randy isn't going to keep working with the cases that Henry had supplied, now that Henry sold the business?
He's still showing the 40, 51, 61, 65, and 75 sizes, and the engines still look like they started out from the Nelson production line.
http://www.aeroproduct.net/
The Kiwi is offline Find More Posts by The Kiwi
Old Feb 05, 2013, 07:53 AM
Traian is offline
Find More Posts by Traian
Traian's Avatar
United States, GA, Roswell
Joined Mar 2008
Don't forget the RoJET engines. I run PA and RoJET.
Most motors will 424. Some motors have a soft 424 some have a hard 424. That depends on the motor timing. Even then I had a 60 size 424 harder on muffler then the same motor had a softer 424 on pipe. Also I had a Norvel .049 doing 424.
Maybe the question should be how to make a motor run properly. I f you get a motor out of the box and expect it to 424 right away and you get it the first time then you are in one of the two categories: One the Very lucky category or two the one that has a similar plane to someone else and you copied his setup.
Traian is offline Find More Posts by Traian
Old Feb 05, 2013, 11:08 AM
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
I thought all the PAs were gone. Maybe I'm wrong. I don't have deep enough pockets for one right now so I've not kept up lol.
Agree with the "most" statement. With proper plug, prop, venturi, needle setting, fuel, etc most can be made to break. I get a soft break out of my perfectly timed Tower 40 in my Vector 40 running 10/22 fuel and an APC 11.5/4.5 prop on unifo. It is super consistent and does break though not near as pronounced as say a Fox 35 but some planes don't need as much break either. The Vector 40 seems that way, it seems to fly the same speed regardless of engine run and which way the pointed end is pointed. I think it also helps that I hang it out there almost 70' and fly her a bit faster than my other planes. To me it does better corners with just a tad more speed.
Old Feb 08, 2013, 09:35 PM
GallopingGhostlr is offline
Find More Posts by GallopingGhostlr
Vintage Aircraft Lover
GallopingGhostlr's Avatar
United States, NM, Clovis
Joined Jan 2013
Here's my 4-2-4 engine, a Testors Series 21 McCoy .40 Black Head. Been testing it by retrofitting a lightweight YS muffler to cut the bark for in-city flying. Today's runs proved it runs fine without overheating.
GallopingGhostlr is offline Find More Posts by GallopingGhostlr
Old Feb 08, 2013, 09:40 PM
Joined Jan 2013
Here is my other 4-2-4 engine, a Testors McCoy .19 Red Head. I turned a sow's ear into a silk purse by converting a dysfunctional Tatone .09-.19 Calumet EM-4 muffler into a tongue muffer.
Old Feb 11, 2013, 05:50 AM
warrenlead is offline
Find More Posts by warrenlead
Aviator
warrenlead's Avatar
Australia, NSW, Anna Bay
Joined Aug 2011
The LA46 runs a nice break, similar to a ST46 but not quite as good. Since the ST46 is harder to come by and much more expensive these days, the LA 46 is used by a few here as a good substitute. They run nice with an 11x5
The LA40 on the other hand are cows to work with and will run away, unless they are modified and even then are best steered clear of.
warrenlead is offline Find More Posts by warrenlead
Old Feb 11, 2013, 09:22 AM
Traian is offline
Traian's Avatar
Joined Mar 2008
A run away motor is one clear sign of a motor that has insufficient load on it. Put a prop with slightly larger diameter and it will cure this run away. If the diameter is too big the motor will stay in the 4 cycle and will not break. Like I said before most motors with proper timing will 424 if you know how to set them up. I have seen LA40 424 just fine but there are certain things that need to happen in order to achieve that.
Old Feb 11, 2013, 10:43 AM
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
I've run la 40s and 46s and both run about the same (we have several in fact at our field). With that said, none really do a true 424. Any motor can be made to have a slight break as Traian says but the la motors are timed to run a bit faster. Tower 40s are pretty much the same (as are FP 40s). These newer motor designs are just not designed to turn a larger prop at lower rpm. I have a Tower 40 in a VEctor 40. I run 10/22 fuel uniflo with APC 10.5x4.5. It has a slight break only but this is just fine on the Vector. Kind of the same run that Brett has described for the FP20 I believe. Nothing wrong with it .. just different. With this said, none of these are gonna break like say a Fox 35 or V60 without changing a few things like timing, at least in my humble opinion.
Discussion What 2.4 GHz DIY will work with Robbe Multiswitches? HelgeBe Radios 3 Aug 23, 2013 11:30 AM
Question What is available for starting really big gas engines? Sackie Giant Scale Airplanes 95 Mar 02, 2013 07:37 AM
Poll What will you by if Multiplex make they 2.4 m-Link modules FCC compliant tiju000 Radios 105 Dec 07, 2009 08:23 AM
Help! How do and what do i need to start my engine?? Roter Wash Fuel Heli Talk 4 Jun 23, 2008 08:20 AM
