Old Jan 30, 2013, 04:02 PM
sidewinderFSK is offline
Find More Posts by sidewinderFSK
United States, TX, Lubbock
Joined May 2007
OSD pro with guardian issue
When I turn on the Stabilization / Elevn Mixing On the plane ailerons will deflect when the wings angle changes, only problem is turning to the LT is good. Turning to the RT the ailerons start to deflect in the correct direction until the wing dips approximately 10%,,, at this time the servos will move to full travel in the opposite direction. This would cause a uncontrollable decent straight to the ground.
Under the guardian menu I can not get heading hold to work.
The manuals are wonderful, but to extensive. On one page you need,
Connect this here,
place this there,
turn this on,
If it doesnít work read here! (Ladder troubleshooting) not surf the forums. I have no doubt that someone had my RTH problem, but finding it.
And gee-whiz guys why didnít you make room for heading hold / RTH activation via an aux channel or am I missing something. Navigation of your menus while flying sucks. If I was flying at 10000 ft no problem, but at 300 ft, only seconds to the ground? Or am I missing something. Create a serial device to control function using aux channels. Right now as far as I understand the OSD Pro, with the guardian has 2 AUX input to control the OSD extensive table of contents. Switching between these menus while flying takes hours of practice and removing the pilotís attention from what matters, flying!
The OSD is functioning correctly, I have too much invested in the support equipment, (video) If I can't get some real tech support the eagletree is coming out and will find the FPV system that works as advertized!
sidewinderFSK is offline Find More Posts by sidewinderFSK
Old Jan 30, 2013, 04:34 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Sidewinder, & sorry you're having an issue with the stabilizer.
Let's first focus on getting that resolved, then I want to get more feedback from you about how we can improve the manual and the menuing.
Can you please follow the below steps. As a shortcut, you could first follow step 3, and if that doesn't work, also do steps 1 and 2. However, I suspect doing step 3 will resolve the issue.
1) If you are not running version 10.43 of our software already (indicated by clicking "Help, about" in the software), please install version 10.43 from here.
2) Open the OSD configuration page in the software, and click "Factory Reset," which will clear out your prior config. Then configure the OSD's display settings as desired, and click OK.
3) At this point, run the Servo Analysis Wizard either on the PC, or from the OSD's menu.
4) Confirm the problem is resolved.
Please let me know what you find.
billpa is offline Find More Posts by billpa
Site Sponsor
Cool Guardian stabilization module for your OSD Pro - $54.99! billpa FPV Equipment 1981 Jun 18, 2014 04:29 PM
Sold Eagle Tree OSD Pro with Guardian Stabilizer Mattsrcking FPV Equipment (FS/W) 4 Oct 21, 2012 12:31 PM
Sold OSD Pro Pkg with V4 100A eLogger and GPS / Guardian (((SOLD))) bah7566 FPV Equipment (FS/W) 5 Aug 21, 2012 05:36 AM
Help! Problem with OSD Pro + Guardian MatthiasC Eagle Tree Systems 16 Aug 11, 2012 07:24 AM
Sold OSD Pro Pkg with 100A eLogger/Integrated Connectors and GPS and Guardian Stabilizer Nick_P FPV Equipment (FS/W) 1 Jun 16, 2012 11:45 AM
