Old Jan 30, 2013, 02:45 PM
Ricky971 is offline
Find More Posts by Ricky971
Italy, Toscana, Orbetello
Joined Mar 2012
Accucel 6 - Balance problems
Hi everybody!
I've a new Accucel 6 and three brand new Turnigy 2.200 3S 25C Batteries.
When I charge the battery, one per time, at the end of the cycle the Battery charger gives me a measure of 4.18 - 4.18 - 4.18 Volts (should be perfect!).
But when I measure with a multimeter, I've 4,18 - 4,18 - 4,26 Volts, that is totally dangerous for the third cell (over 4,20 Volts).
This happens for all the batteries: I make the balance charge and at the end I've differente measures between Accucel 6 and my tester, and the last cell that has always 4,26 Volts on my multimeter.
Even if my multimeter is not professional, I'd have the same measure on all the cells, but it's not so and I'm sure that is something wrong in the Accucel.
Do someone else had the same problem?
Is it possible to solve it?
Thanks everybody!
Ricky971 is offline Find More Posts by Ricky971
Old Jan 30, 2013, 02:48 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Sounds like you better buy a new charger! over charging a lipo is bad news!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 30, 2013, 03:04 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Calibrate it!!!
Calibrating the Turnigy Accucell-6 Battery Charger (4 min 23 sec)
TURNIGY ACCUCEL-6 Battery Charger Calibrating (1 min 50 sec)
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jan 30, 2013, 03:12 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
There's 2 flavors of the Accucell-6 floating around. HK sends it and you don't know which one you get until you get it.
The newer one does not have the calibration menu on it; it instead has IR reading.
The older one has calibration, but no IR.
so if you don't get into the calibration menu, you have the newer one.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Jan 30, 2013, 11:15 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, FL, Naples
Joined Apr 2009
I have 2 Accucell 6 chargers. One is about 4 years old and is the 5 amp version. I have calibrated that one.
The other is about a year old and is the 6 amp version. Just checked it and it does go into calibration mode.
I did read somewhere that they came out with one that can check internal risistence and that when they added that feature the calibration feature was dropped.
I'm no battery expert. So, is 0.08 of a volt an issue?
tacx is offline Find More Posts by tacx
Old Jan 30, 2013, 11:34 PM
Joined Dec 2007
Yes. I have both; one with the calibration menu and one with the IR reading
The calibration one lacks IR, and the IR one lacks calibration
Turnigy Accucel-6 has IR readings (1 min 12 sec)
Old Jan 31, 2013, 03:13 AM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
Soiunds very predictable:
http://www.rcgroups.com/forums/showthread.php?t=1788569
Rich in ILM is offline Find More Posts by Rich in ILM
Old Feb 02, 2013, 02:08 PM
Ricky971 is offline
Joined Mar 2012
Originally Posted by mrforsyth View Post
Calibrate it!!!
Mark
Thanks everybody.
I can go in the calibration menu, and I already did it, but for sure it's not this the problem: with calibration menu You can calibrate the total voltage, not the single cells voltage.
I bought two of them: one for me and one for my father: its one is perfect!
He measures 4.20 Volts on each cell and, when he measure them with a professional multimeter, they're exactly 4.20 Volts.
Just to make an experiment, I asked him to make a calibration of +5 on the calibration menu and at the end of the balanced charge he had again 4.20 Volts on the Accucel's display, but with the multimeter he measured 4.18 Volts, equals on each cell.
Mine is not so: I read 4.20 Volts on each cell on Accucel's menu, but when I measure it I've got 4.18 - 4.18 - 4.26 Volts and this is bed.
I discharge the single overcharged cell till 4.18 Volts with a bulb, but it's boring.
I've ordered an iCharger 106B Plus and in the meantime I'm charging each single cell alone, as 1S per time, connecting to the battery charger output two wires of the balance connector.
In this way I use three charging cycles for each lipo, but at the end I've exactly 4.20 Volts on each cell.
I think that my Accucell is fake or bugged...
Old Mar 31, 2013, 03:18 AM
K9000wner is offline
Find More Posts by K9000wner
Thatsright I drankthe rum
K9000wner's Avatar
USA, MN, Robbinsdale
Joined May 2006
one of these may help ..until new charger arrives
love my Balance pro............just one location below
http://www.amainhobbies.com/product_...=Product-Feeds
K9000wner is offline Find More Posts by K9000wner
Old Mar 31, 2013, 03:27 AM
K9000wner's Avatar
Joined May 2006
HELP!
my accucel does the same but WAY off
my balance charge reads 4.12/ 1.83/ 4.09 ... on a perfectly balanced
12.3 battery brand new
check by DVM and Balence pro to be 4.1x3
has anyone hacked one of these yet ..or do I just send it back .......
....IF they believe me.......... bought from HK
thoughts and or suggestions please...
it will charge to 12.6 ish on a nonbalence charge ( do that with B Pro attached).
and other voltages are ok as I have been double checking everything
so it seems just the balance taps are Fddd up ????? help
Old Mar 31, 2013, 03:50 AM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
Originally Posted by K9000wner View Post
HELP!
Help! *** MOVED *** Accucel 6 charging problems leatherlips Multirotor Electronics 0 Jan 29, 2013 04:46 PM
Sold Like New Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories MJB9 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jan 29, 2013 08:58 AM
Discussion Problem with Life battery and accucel 6 leopereira Batteries and Chargers 11 Jan 20, 2013 12:07 PM
Sold Turnigy Accucel-6 50W 6A Balancer/Charger - $24 shipped nuttcaze Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 09, 2013 12:35 PM
Sold Turnigy Accucel-6 50W 6A Balancer/Charger FieldofDreamsFlyer Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 07, 2013 05:03 AM
