Old Feb 01, 2013, 03:00 AM
Sarboy is offline
Find More Posts by Sarboy
Sarboy's Avatar
Joined Mar 2010
Description: Top of tail on an iPad for scale.
Sarboy is offline Find More Posts by Sarboy
Old Feb 01, 2013, 03:03 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Description: Might just be able to see disser on other side through tail
Old Feb 01, 2013, 03:05 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Description: Bottom of tail, no carbon tip caps.
Old Feb 01, 2013, 03:13 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Tail is out and I'm fairly happy for a first attempt.
Need to cut better foam cores. This is really the main point as I'm sure it all stems from there.
Other than that I need to position the mylar better so everything lines up better. I think the disser worked well considering it was hand placed and cut strips.
Seems very rigid and weighs 8g. Again for a first attempt I'm happy and it's certainly usable. Well for a have fun and learn tequnique kind of way.
Next up the fuz and vertical stab. Hope to have better cores for the vert.
Tom
Old Feb 01, 2013, 08:05 AM
rdwoebke is offline
Find More Posts by rdwoebke
The Self Confuser
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
Tom, I think that tail looks great.
Ryan
rdwoebke is offline Find More Posts by rdwoebke
Old Feb 01, 2013, 02:03 PM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Hmm, looking at equipping my model and just wondering if anybody has used ripmax sd100 for tail/rudder and sd150 for the wings? Looks like they should work well.
Any good or are there better out there for the cash?
Tom
Old Feb 01, 2013, 02:18 PM
bwill6 is offline
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
Looks just like a D47 to me. I've had D60s in wings before and they were good little servos. I couldn't detect any slop in them and they had good resolution. I know Jun C had D47s on ailerons of his Neos and swapped them out because of flutter issues. But he is launching well over 200 ft, so for us mere mortals the D47 isn't a bad choice. Personally I doubt I'd flutter a wing with D47s (throwing ~160'), but I prefer to use beefier servos anyway.
bwill6 is offline Find More Posts by bwill6
Old Feb 08, 2013, 02:41 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Vertical stab not good, I'll have to do another one.
Description:
Old Feb 08, 2013, 02:43 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Description:
Old Feb 08, 2013, 03:08 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
The vert did not go as planned. I redesigned my templates and managed to achieve a good core from help over on the composites forum. I was very pleased with myself.
I then cut the mylar's and prepared everything ready to go. Pump, bag, tools, cloth etc, I was set.
I had decided to do a carbon leading edge and cut a strip of fabric backed with ATT(Adhesive Transfer Tape). As this was 200g carbon I neglected to include a carbon spar as I thought the leading edge cap might provide the rigidity required. So the carbon was stuck to the leading edge and wet out and put aside while I layed up the skins on the mylar's and wet out.
Now feeling very pleased with myself I turned to put the whole lot together only to find the carbon had come away from the leading edge and would not stick back down no matter what I did. So, off came the carbon and on the mylar went to the core.
This all went into the bag and was vacuumed to see what would happen.
The result can be seen in the previous posts. I'm quite pleased with the finish, and the torsional rigidity provided by the disser but the longitudinal strength is quite poor.
I think the carbon I used was too heavy and as it was woven from 3k very hard to form on such a tight radius. Never mind. We live and learn.
I now have some lighter carbon ordered from f&g so should not have the problem again. Additionally, I will now be including a spar to all my stabs because for the weight cost, why not?
Now to get on with the wings and fuz.
Old Feb 08, 2013, 07:50 AM
bwill6 is offline
Joined Jun 2011
You really need a proper spar on your tails, especially on the vertical. Just doing a LE wrap of carbon won't cut it. For mine I cut a vertical slit about six inches long in the core where the spar will go and slide in a pre-cured strip of bias cut 1.6oz glass. Then I lay a single strand of spread 12k tow over the top on either side. It's not the only way, but it works for me. I'm thinking about replacing this method with .75 mm carbon rods, another proven method.
Old Feb 08, 2013, 07:52 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Disser cloth for wings.
Description:
Old Feb 08, 2013, 07:58 AM
rdwoebke is offline
The Self Confuser
rdwoebke's Avatar
Joined Feb 2004
I am very impressed with your work so far.
Ryan
Old Feb 08, 2013, 01:19 PM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Thank you Ryan.
I have bagged the wings today but I don't think they will be any good. It's all in the materials and I didn't have any Mylar for them. I used acrylic sheet which might work but I'm doubtful. I have work tomorrow so will pull them out the bag on Sunday. I'll know then if I have to do them again.
In the mean time I need to do new vert stab.
Tom
Old Feb 10, 2013, 08:48 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Got the wing out the bag
Description:
Discussion Evolution 3- the E Pluribus Unum DLG group build log Traian Hand Launch 915 May 11, 2015 08:29 AM
Build Log My First Kit Build Contender build chaos2984 The Builders Workshop 100 Nov 06, 2013 08:28 AM
For Sale DLG SuperGee2 superrior quality, already builded AndrewID Aircraft - Sailplanes (FS/W) 4 Apr 28, 2013 08:52 PM
Discussion My First Kit Build Contender build chaos2984 Electric Warbirds 2 Jan 28, 2013 08:29 AM
