Old Jan 30, 2013, 01:09 PM
tdonily is offline
Find More Posts by tdonily
Village Idiot!
United States, OK, Ponca City
Joined Mar 2003
Question
Restoring a US12
Hello everyone,
At long last, I'm getting around to returning a used US12 I acquired some time back to the local waters. But I need to correct some issues that I have with it first.
The main one is what looks like stress cracks in the gelcoat of the hull. Do I sand and fill the outside of the hull? And anything needed on the inside?
The other is repainting the hull. My only experience is with a few lexan RC car bodies which is entirely different. Do I sand it down to the glass first, or just rough sand, primer, and so on?
Thanks in advance,
Travis
tdonily is offline Find More Posts by tdonily
Old Jan 30, 2013, 05:52 PM
rcsoar4fun is online now
Find More Posts by rcsoar4fun
Corpus Christi, Texas, United States
Joined May 2003
Might help to have pics of the actual damage, inside and out. The inside of the hull, with bare fiberglass, will generally tell you if there is damage to the glass or just gelcoat.
Where is the damage?
rcsoar4fun is online now Find More Posts by rcsoar4fun
Old Jan 31, 2013, 02:55 PM
tdonily is offline
Village Idiot!
Joined Mar 2003
The worst is just below where the hull and keel meet. From the inside, it appears as if the fiberglass is still intact.
The lead ingot is fixed. Unsure of whether I can free it for this repair.
Old Jan 31, 2013, 07:17 PM
Joined May 2003
Hard to tell. Could be someone forcing the lead in place or dropping the boat onto the keel.
Couple of ways to repair. One is to run some thin CA into the outer cracks, then run a layer of glass on the inside. I wouldn't grind out the gelcoat/glass. I doubt the lead is glued in there very well, or it wouldn't have busted along the side.
Old Jan 31, 2013, 07:44 PM
ktm500mx is offline
Find More Posts by ktm500mx
United States, FL, Indialantic
Joined Jul 2008
us 12 repair
If it where me I would check if there is delamination and go there I have a us 12 that's has a similar issues and had to make significant repairs.
later mike
ktm500mx is offline Find More Posts by ktm500mx
Old Jan 31, 2013, 08:56 PM
mrpenguin is offline
Find More Posts by mrpenguin
Australia, TAS, Penguin
Joined Mar 2012
@tdonily:
I would think this is an area subjected to a good bit of stress. What may not look like much of a crack would open up under stress I reckon.
For me, I would make sure it is repaired properly rather than patching it up, otherwise you may be doing the job again after a few good gusts of wind or a bit of stress while handling.
Any idea how the damage was caused? Almost looks like it has been dropped on the keel or squashed or something????
mrpenguin is offline Find More Posts by mrpenguin
Old Jan 31, 2013, 09:48 PM
tdonily is offline
Village Idiot!
Joined Mar 2003
I honestly have no idea how the damage happened as this is how it was when I picked it up.
Have looked at removing the ballast to aid in the repairs, but would have to get thw epoxy loose. Thnk a heat gun would help?
Thanks again,
Travis
Old Feb 01, 2013, 05:31 AM
bkopke is offline
Find More Posts by bkopke
Registered Billy
Louisville, KY
Joined Dec 2003
A heat gun may blister the finish or damage the resin/glass. You might try wrapping a towel around the area and pouring hot (boiling) water over the towel until the lead is loose. Much less chance of damaging the boat. Wear gloves, glasses and etc. to be safe, of course.
Brian
bkopke is offline Find More Posts by bkopke
Old Feb 01, 2013, 09:45 AM
tdonily is offline
Village Idiot!
Joined Mar 2003
Thanks Brian,
Will give that a shot.
Help! Model Stinson Reliant restoration joemtz488 Giant Scale Airplanes 15 Sep 19, 2013 12:30 PM
Discussion americian eagle B-17G restoration warbird_cowboy Giant Scale Airplanes 9 Jan 26, 2013 05:37 PM
Sold Restored vintage Nikko Dictator artist2 Cars - Cars and Parts (FS/W) 1 Jan 26, 2013 02:06 PM
Question Hobie Hawk restorers? chip.greely Slope 12 Jan 23, 2013 11:20 AM
For Sale Pristine Tamiya Blackfoot restored must look!! scorpion1 Cars - Trucks and Parts (FS/W) 0 Jan 09, 2013 04:20 PM
