Old Jan 30, 2013, 09:07 AM
sailr is offline
Find More Posts by sailr
Land O' Lakes, FL
Joined Aug 2003
Flat finish for Monocote?
Has anyone found a good flat clear that can be sprayed on monocote/ultracote, etc?
I have tried a couple but they always blush really bad, giving a crappy result!
If you have found a product that works, what was your procedure for prepping the covering before painting?
sailr is offline Find More Posts by sailr
Old Feb 08, 2013, 10:55 PM
Leroy G is offline
Find More Posts by Leroy G
Leroy G.
Leroy G's Avatar
Coeur d' alene, Id.
Joined Jan 2010
A good wipe down with 0000 steel wool and you may not need to put a flat coat on it, all it does is add weight.
Leroy
Leroy G is offline Find More Posts by Leroy G
Old Feb 09, 2013, 06:13 PM
sailr is offline
Land O' Lakes, FL
Joined Aug 2003
Interesting idea. Thanks.
Old Feb 13, 2013, 02:59 PM
redball8 is offline
Find More Posts by redball8
What - Me Hurry?
redball8's Avatar
United States, IL, Naperville
Joined Jul 2004
I've used the steel wool, and highly recommend it. Best done before covering; lay the film on a flat surface (I used a ping-pong table), and pour some non-flammable paint deglosser (ie, glycol based) on it to serve as a lubricant. Be careful of the direction of strokes you take with the steel wool, a cross-hatch will simulate fabric fairly well.
redball8 is offline Find More Posts by redball8
Old Feb 20, 2013, 05:03 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
I do not have the address, but John Redman from Horizon Hobbies did an upgrade finish of the 30cc P-47 and he did this very thing, it is all on Youtube.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Feb 20, 2013, 07:16 PM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
Here it is. http://www.horizonhobby.com/article/...underbolt-30cc
Harry
Harry H is offline Find More Posts by Harry H
Old Feb 21, 2013, 11:46 AM
sailr is offline
Land O' Lakes, FL
Joined Aug 2003
Redman used the Top Flite Lustre Coat Flat Clear. Says it's the only one that's fuel proof.
Gallery Crawler King at Rowher Flats peacekeeper94 Rock Crawlers 3 Jan 29, 2013 07:46 PM
Wanted Adjustable tow hook for flat bottom fuse ak79 Aircraft - Sailplanes (FS/W) 6 Jan 15, 2013 09:36 PM
Discussion Help me find this material - flat finish trim tape verticalflight Painting and Finishing Tips 2 Aug 04, 2009 09:36 AM
Discussion Help me find this material - flat finish trim tape verticalflight Composites Fabrication 0 Aug 03, 2009 08:19 PM
Discussion Flat finish for Spit...what should I use? millerhill Scale Sailplanes 2 Apr 14, 2008 09:56 AM
