Old Jan 30, 2013, 07:55 AM
Samjet is offline
Find More Posts by Samjet
Samjet's Avatar
Joined Mar 2010
Help!
Fatshark attitude sd and 600 TVL Super HAD
Hello FPV guys
I am new to this part of the rc-hobby and I am in need for some help
I have bought the 600 TVL SUPER HAD Camera and a pair of Fatshark attitude sd. The question is: which cable do I need to connect the Camera to the Fatshark TX??????
Any help appreciated
http://www.securitycamera2000.com/pr...-Menu-DNR.html
Samjet is offline Find More Posts by Samjet
Old Jan 30, 2013, 09:21 AM
Samjet is offline
Samjet's Avatar
Joined Mar 2010
anybody?
Old Jan 30, 2013, 10:15 AM
TigerPilot is offline
Find More Posts by TigerPilot
Joined Jan 2005
I think the reason that nobody answered you is that your question shows you didn't do any research. If you did, you would have read many times that the yellow wire form the camera goes to the tx.
TigerPilot is offline Find More Posts by TigerPilot
Old Jan 30, 2013, 11:15 AM
Samjet is offline
Samjet's Avatar
Joined Mar 2010
UOTE=TigerPilot;23979040]I think the reason that nobody answered you is that your question shows you didn't do any research. If you did, you would have read many times that the yellow wire form the camera goes to the tx.[/QUOTE]
Thanks I couldn't find any valuable information. I did search it. Just need some friendly adwise.
Description:
Is this the cable being used to connect the camera to the tx? And does the goggles come with it. Name: Fatshark cable.jpg
Description:
I have ordered it from readymade rc and the description says:
AtttitudeSD headset (with RX and HT) (Uses the high performance NexWaveRF receiver module)
250mW 7ch 5G8 TX*
Filtered balance lead adapter
3dBi 5G8 antenna
3m AV cable
Futaba data cable
zipper carry case
manual
Does it already come with a cable looking like this:
Name: fatshark cable1.jpg
Description:
Old Jan 30, 2013, 04:37 PM
Samjet is offline
Samjet's Avatar
Joined Mar 2010
Found the answer. The plug on the cable is called molex 5p.
Old Jan 31, 2013, 05:22 PM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
that cable may fit but I use servo type connectors to connect it all...
to prevent making a "custom" cable all the time.
-camera(servo connector like on a servo)(made from servo extension cable)
-vTx(servo connector like on a servo)(made from servo extension cable)
-battery(mate to servo connector)(made from servo extension cable)2 wires only
-then i use a Y servo harness to connect it all together...
the video comes down the signal wire of servo cable from camera to vTx.
-later if you get an OSD, vTx and camera will plug right into OSD.
ror1 is offline Find More Posts by ror1
Old Jan 31, 2013, 09:39 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
This guy is dead right.
samjet, I know i shouldn't enable or reward your lack of reseach on the subject, but I'll make this easy for you.
The fatshark cable can be bought here:
http://www.readymaderc.com/store/ind...roducts_id=694
Cut the end off that doesn't fit into your TX. You'll now have a cable that connects to your TX, and has three bare wire ends.
The three ends are ground, 5V, and video. Solder ground and video, to ground and video on your camera(usually found in the camera's manual). Tape off the 5V wire end, you won't be using it(your camera is 12V).
Your camera is 12V, so you need to splice your camera's postive and ground power wires, into your TX's positive and ground power wires. As long as you are using 3S, this will feed the camera 12V, which it needs to operate. Now power up the TX and goggles, to see if you did it right.
In a nutshell, Camera video and ground need to connect to transmitter video and ground. And Camera power and ground need to connect to transmitter power and ground.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Feb 04, 2013, 11:13 AM
Samjet is offline
Samjet's Avatar
Joined Mar 2010
Thank you very much.
Well I made the wrong question from the start. I was interrested to know if the plug for the tx was included or not. I bought the cable you refered to allthough the right cable did come with the goggles.
Discussion Fat shark Attitude sd in stock Hobbyking mark the shark FPV Talk 20 Dec 10, 2013 09:31 AM
Discussion FatShark Attitude SD centering AeroHeadTW FPV Talk 1 Apr 25, 2013 05:30 AM
Wanted Fatshark Attitude setup garrettt04s FPV Equipment (FS/W) 0 Jan 27, 2013 08:21 AM
Discussion Fatshark attitude head traker with futaba t8fg super nat44 FPV Talk 1 Dec 12, 2012 01:24 AM
Sold Fatshark Attitude SD goggles - w/upgraded 5.8 Tx cavu flyer FPV Equipment (FS/W) 8 Dec 01, 2012 04:45 PM
