Old Jan 30, 2013, 07:48 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
Silane for resin/silane for epoxy
Curious to know if anybody has ever used the 3/4 glass from thayercraft they have listed for resin rather than the smaller, narrower glass listed for use with epoxy.
What is silane? Is it simply a wetting agent or similar?
http://www.thayercraft.com/106.htm
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Jan 30, 2013, 11:53 AM
David Forbes is offline
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
Yup, I've used it, it works fine for our uses with epoxy. Here's info on the finishes used on FG http://www.thayercraft.com/finishes.htm
Dave
David Forbes is offline Find More Posts by David Forbes
Old Jan 30, 2013, 02:38 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Silane is a finish the creates a molecular link between the resin and the fiberglass
wyowindworks is offline Find More Posts by wyowindworks
Old Jan 31, 2013, 03:39 AM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Does it increase strength of the layup? Or simply make wetting out easier and more reliable?
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Jan 31, 2013, 04:57 AM
Joined Apr 2010
Looks as though it does strengthen Jim
From the link David provided :Finishes are put on glass fabrics to allow a strong bond between the resin and the glass. If you take a sheet of glass and put resin on it, let it cure then try to peel it off it will easily come off, or chip off. Finishes like Volan or Silane act as intermediaries between the resin and the glass. Volan has been around a lot longer than the Silanes but I think is still one of the best finishes. Volan is generally the softest finish with the exception of some Silanes.
Old Jan 31, 2013, 08:13 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
All of the above is correct. I don't think silane could be called a wetting agent in the same sense as soldering flux, it's only purpose is to increase bonding strength between epoxy and fibre. If it does help with wetting, that's only a fortunate side-effect. I have not researched this aspect, so can't really comment if and how much effect it has on wetting properties. All of the fabrics that I am aware of are treated with silane or some equivalent stuff.
jkettu is offline Find More Posts by jkettu
Old Feb 06, 2013, 02:41 PM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
IIRC, the various finishes reduce the strength of the glass fibers, but increase the strength of the bond more than enough to compensate.
Gerald
G_T is offline Find More Posts by G_T
Discussion will fiberglass resin cure like epoxy? jeff262 Composites Fabrication 7 Jan 12, 2013 07:10 PM
Discussion Composite :: Epoxy Resin or Polyester Resin Nīmā Composites Fabrication 4 Aug 27, 2012 01:34 AM
Question Can epoxy resin be mixed with polyester resin? boredom.is.me Composites Fabrication 10 Jul 28, 2011 11:53 AM
Discussion Epoxy resins vs. polyester resins FlyJumper The Builders Workshop 28 Jan 12, 2009 07:54 PM
Discussion Resin--or Epoxy Resin??? WATERTIGHT Dock Talk 10 Dec 16, 2006 09:48 PM
