Old Feb 01, 2013, 04:56 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Originally Posted by valiantGLX View Post
So I got my 2s setup functional (Still waiting on a 1s ESC to try), and WOW its a freakin power house
At 1/2 throttle its probably producing 2x the thrust of the stock brushed motor.
At 3/4 throttle I'm crappin my self holding on to the gearbox with my fingers, it sounds amazing at that speed.
At full throttle it strips the thread on the prop, so far I have only had it a full throttle for maybe 2 seconds.
BUT
It gets extremely HOT even at 3/4 throttle, even after 10 seconds its almost too hot to touch. For the tests I was using the 3 blade eflite prop, which I think has the least thrust out of all the props, and a Nano-tech 300mah 35-70c 2s.
However my gearbox isn't very smooth, I think heating the pinion up red hot and sliding it off the brushed motor with a butter knife may have warped it a bit. I tried filing the teeth ever so slightly which helped but the prop still doesnt spin as freely as I'd like.
The 2s verdict, even if my gearbox was running smooth I think the motor would blow up after a minute at full throttle, or melt through the gearbox Someone else should do a quick 2s test though in case I'm wrong
Well, if you bump up the voltage you need to downsize the prop. You can't run a 5" prop at 2S
You need to be careful heating the motor because heat will damage the permanent magnets and then give you less power.
coreman is offline Find More Posts by coreman
Old Feb 01, 2013, 05:48 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
Originally Posted by dude_109 View Post
Hot isn't good. I guess either lower kV or lower voltage.
Separate question, any chance of press fit prop directly onto motor shaft to eliminate more wear and tear parts? Without the 4:1gear reduction, even on 1s, its probably too much amps pull for motor to handle.
if you want to go direct drive, you will need a small prop similar to the one the heli comes with. this motor was designed to run direct drive on a 2 cell battery, so it should be fine with just the right prop. same would go with the gear drive, just the right prop will get you in the same current draw as the tail blade and the motor should last just as long as it would in the heli.
derk is offline Find More Posts by derk
Old Feb 01, 2013, 08:04 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
But a small diameter, high RPM prop is inefficient, and it's also a poor match to the UM airframes. Unless you're pylon racing a streamlined UM bullet with symmetrical wings, you'd want a slower-turning prop that's around 5" diameter. Hence, why the UMX planes use outrunners for dd.
Joel
turboparker is offline Find More Posts by turboparker
Old Feb 01, 2013, 08:09 PM
RCBABBEL is online now
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Pylon racing a streamlined UM bullet with symmetrical wings?
Yes please!!
rc
RCBABBEL is online now Find More Posts by RCBABBEL
Old Feb 01, 2013, 08:19 PM
valiantGLX is online now
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Yes please!!
rc
Like this
AS3X
monster control surfaces
2s BL
mCPX tail rotor prop
Definitely not the setup Im going with though. Although I might test the thrust of it
valiantGLX is online now Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Feb 01, 2013, 08:23 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Anyhoo, here endeth all speculation.
The inrunner will spin a UM prop in a UM gearbox on 1S at ~5200rpm's.
The stock motor spins a UM prop in a UM gearbox on 1S at ~6900 rpm's.
The inrunner draws much less current on 1S (less load thanks to lower kV)
Having said that - Sweet mercy! she had some thrust on 2S! I didn't dare go full throttle.
We may have to work on different ratio gearboxes. I think I still have some old different ratio gearbox combo's from back in the day - I can't remember the name of them though - they came with folding props.
NitroCharged is offline Find More Posts by NitroCharged
Old Feb 01, 2013, 08:31 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
That's no good!
2s it is then, just got to find a good prop
Tell me about, I just about shat myself at full throttle Its a pitty it cant handle the UM props though
Old Feb 01, 2013, 08:35 PM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
That's no good!
What about clipping 1/2" off each blade?
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 01, 2013, 08:59 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Seems a bit brutal, I'll try it tomorrow
I just bought the AP05 5000kv and a XP-7A 1s ESC for my profile 3D mustang, seems like the best 1s option now @ 70-90g of thrust
Old Feb 01, 2013, 09:13 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That won't result in any more thrust at 1S, which was the whole point of this experiment. We have 2S motors out the Wazoo.
The motor isn't loaded at all on 1S, hence the ZERO temp rise. Putting less load on it won't make it spin much faster, because the RPM that its turning now is very low load, anyway.
It looks like we need a 9K or 10K motor.
UNGN is offline Find More Posts by UNGN
Old Feb 01, 2013, 09:37 PM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Yeah, i see your point. Higher kv motor, or a slightly taller gearbox.
Old Feb 01, 2013, 09:59 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
So I should cancel the two motors I have on backorder?
Gene K
speedy01 is offline Find More Posts by speedy01
Old Feb 01, 2013, 10:02 PM
Tarak is offline
Find More Posts by Tarak
Total Newbie
United States, NC, Fayetteville
Joined May 2011
I know this seems silly, and more than likely a moot point for our current crop of UM BNF or RTF birds that we were hoping this would be a direct drop in for, but what about propping up the gearbox for more thrust? Would that work, or am I missing some other key component of the equation? Just a thought...
Tarak is offline Find More Posts by Tarak
Old Feb 01, 2013, 10:11 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Gene K
I would if I were you, unless you want to experiment with 2s, or larger props.
The AP05 5000kv seems like the best 1s BL motor around at the moment, only problem is that its not a direct drop in but fitting a motor mount would be well worth the 70-90g's of thrust it offers.
I'm sorry to get everybody's hopes up with this thread, believe me Im just as disappointed. It sounded sooooo good in theory though
Makes sense!
I have some 5030 & 6030 GWS 3 blade props I can test with it on 1s (once I get my 1s ESC), since the rpm's are lower than stock wouldn't it be more torquey?
Old Feb 01, 2013, 10:27 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Like I said - a little tinkering with different gear ratio's is next!
I think I have a 2.67:1 and a 3:1 here.
Sold Eflite Celectra 1S 3.7 Lipo Charger AC UM Adpater for MCPX Winterdd Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 24, 2011 07:56 PM
Sold Celectra 4-Port 1S UM charger $25 Shipped AggressorBLUE Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 24, 2011 10:11 PM
Sold Five (5) 1S UM Lipos philipa_240sx Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 20, 2011 10:10 AM
Discussion Taking the UM's brushless.... staying 1s darksiede Micro Ready-to-Fly 72 Sep 01, 2010 08:05 PM
Sold hyperion 25C 160mAh -1S-UM pttse Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 10, 2010 01:21 AM
