Old Jan 31, 2013, 06:27 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by coreman View Post
and big round Spitfire loops
Yeah, it aught to make the UM Spit perform like her full-scale hot-rod air-superiority fighter counterpart!
Joel
turboparker is online now Find More Posts by turboparker
Old Jan 31, 2013, 07:34 PM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
might help save a dollar
Originally Posted by NitroCharged View Post
The brushed and brushless motors both have 1mm diameter shafts.
excellent
Removing 9t pinion from 8.5mm shaft (0 min 52 sec)
no torch no problem
elvill is offline Find More Posts by elvill
Old Jan 31, 2013, 08:40 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Originally Posted by tourist_603 View Post
The helicopter that the BL tail rotor motor comes from is a 2S machine. Will not running in on half the voltage that it was designed for (1S) result in poor efficiency?
Someone who knows more about electric motors can tell us just what the trade offs are.
theorteicaly, maybe... compared to another brushless, most definatly, but compared to the brushed motor? its still better than brushed...
dacaur is offline Find More Posts by dacaur
Old Jan 31, 2013, 09:58 PM
Hawker007 is offline
Find More Posts by Hawker007
Joined Dec 2003
Wow
Hawker007 is offline Find More Posts by Hawker007
Old Jan 31, 2013, 11:49 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i doubt its going to be a mostrous improvement (one 1S) but will be some, and will outlast the brushed motor. plus, you have the option of going 2S (i think) and that will most definalty rock!
my guess is 50g on stock p51 prop.
at any rate, iv been wanting to get some ball bearing gear boxes forthe ep51 motor, and now want them even more!
nemoskull is offline Find More Posts by nemoskull
Old Feb 01, 2013, 04:42 AM
K9000wner is offline
Find More Posts by K9000wner
Thatsright I drankthe rum
K9000wner's Avatar
USA, MN, Robbinsdale
Joined May 2006
Originally Posted by RealGambler View Post
Hard to tell from the picture if this one mesure DC amps or AC amps. You need something that mesure DC amps. But if I were you, I would buy a Wattmeter (check HobbyKing). Those cheap multimeter don't last long (particularly the probes), and give slow reading (one every second or so). With a wattmeter, designed for our hobby, you get instant result, and peak result (much more valuable). Trust me, much more valuable than a cheap multimeter!
will not argue worth of actual meters over wattmeter but it looks like you have one that will only measure to 250Ma...or .25 amps and it will break if more are
seen in that scale ...for amp draw you must measure in a series configuration.
but Harbor Freight sells a great little meter that got to 10amps. for 4-5$
sometimes even less or free with other purchase!
I use it ALL the time and I do own a wattmeter too.
http://www.harborfreight.com/catalog...t?q=multimeter
didnt see all the pages I was behind this thread moves pretty fast
K9000wner is offline Find More Posts by K9000wner
Old Feb 01, 2013, 07:56 AM
chulian1819 is offline
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
this mcpx bl tail engine can be used in all UM!! hope horizon changes all bs to this bl engine
chulian1819 is offline Find More Posts by chulian1819
Old Feb 01, 2013, 09:11 AM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
If you have a quality voltmeter with banana plug leads, you can make a current shunt out of a length of copper household wire. Instructions are here:
http://www.rcgroups.com/forums/showp...36&postcount=1
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 01, 2013, 10:22 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
Hey Nitro ~ You got that combo running 2s yet? 2S 180 with this would be an excellent power setup! Wonder if gearbox can handle WOT 2S
Old Feb 01, 2013, 10:31 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Thanks for the multimeter advice guys, but I think I'll save the $$$ now and just chance it running on my ESC.
Speaking of ESCs, I was at my LHS earlier buying some Depron, and I stumbled accross a small 6a 2-3s ESC for 10 bux, so I bought it.
Problem is I cant get it to work (I am trying with 2s ) I hooked it up with the middle motor wire going to the middle, and the other 2 wires going either side. I then cut the RX plug off taped off the skinny red and black wires and then ran the white wire (signal I presume) to the RX. I plugged the thick power wires to a 2s, and plugged a 1s into the RX.
Does that sound about right so far?
I tried with the mossie brick first, I had a look at the ar6400 manual and soldered an extra wire to the brick for the esc. I then programmed it to brushless mode.
I powered up the TX and moved the throttle to full, then the RX and then the ESC.
My ESC makes a "1,2,3" melody, and then just continues to beep (I counted 100 beeps before I gave up). In the manual it says move the throttle to full then power up the ESC, it will do the "1,2,3" melody, followed by 2 short beeps at which point you should move the throttle down and wait for a long beep.
I also tried mixing the xport with throttle, and using the signal wire from there, but that didnt work either
Any ideas???
EDIT: I just ripped an orange RX out of one of my boats and tested the ESC on that and it worked right away. Any reasons why it wouldn't work with my AR6400s???
valiantGLX is offline Find More Posts by valiantGLX
Old Feb 01, 2013, 11:01 AM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Any ideas???
Are you sure you don't need to rebind? I didn't see anything that you bound the rx to the tx.
Old Feb 01, 2013, 11:17 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Ok sounds promising, I'll try to rebind it now
EDIT: doesnt work, but it works everytime with the Orange RX
I even tried plugging it into the ch2 port (AILE) on the mossie brick with no mixing, still no action. But when I plug it into the orange RX aileron port the esc beeps quickly until I move the stick full left or right at which point it locks that position in as the end point.
There must be a problem with the signal wavelength or something
Old Feb 01, 2013, 11:28 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
Man I hate that mossey brick, could have been so much better!
you direct wired your esc to the mossey brick before the brushed esc', than went brushless out - didnt know it could do that
Old Feb 01, 2013, 11:34 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
You hold the throttle stick up and to the left to switch it into BL ESC mode (for mode 2). You'll bloody well know its worked if there is a brushed motor still plugged in, the brushed motor takes off out of control at full power in BL ESC mode.
So I soldered a wire to the BL signal point, but it doesnt work with my ESC for some reason
Old Feb 01, 2013, 11:49 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
You hold the throttle stick up and to the right to switch it into BL ESC mode (for mode 2). You'll bloody well know its worked if there is a brushed motor still plugged in, the brushed motor takes off out of control at full power in BL ESC mode.
Okay figured since it was twin brushed they wouldn't bother with bl in the brick. Sure'd be nice to have 2 separate throttles (no/constant/trimming) on dsm2 brick *sigh*
Sold Eflite Celectra 1S 3.7 Lipo Charger AC UM Adpater for MCPX Winterdd Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 24, 2011 07:56 PM
Sold Celectra 4-Port 1S UM charger $25 Shipped AggressorBLUE Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 24, 2011 10:11 PM
Sold Five (5) 1S UM Lipos philipa_240sx Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 20, 2011 10:10 AM
Discussion Taking the UM's brushless.... staying 1s darksiede Micro Ready-to-Fly 72 Sep 01, 2010 08:05 PM
Sold hyperion 25C 160mAh -1S-UM pttse Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 10, 2010 01:21 AM
