Old Jan 30, 2013, 11:46 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Here it is:
8100kV 8mm inrunner mounted in a UM 4:1 Gearbox (2 min 51 sec)
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 31, 2013, 12:08 AM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
Originally Posted by NitroCharged View Post
OMG ~ spins very well, loads of thrust over stock, liter too. Damn time to switch out some gear. Nice Work.
elvill is offline Find More Posts by elvill
Old Jan 31, 2013, 01:19 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
That old gearbox is a little tight so I'll try a newer one out of my Mustang since it's already gutted awaiting retracts..
Old Jan 31, 2013, 05:55 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Wow, my initial thoughts were: They made that motor exactly for that kind of setup. Then, I thought "no way, they would have made it 8.4mm or 8.5mm so you don't need scotch tape for press fit". But now I'm stunt, you just proved that it will more than likely work!! With a cheap Nanotech on top of that. If you have a RPM meter, give us some rating at full throttle, I want to see if it does choke a little or not. Otherwise, even if the flight is shorter, I think those little motors will be hot items for a while! Anxiously waiting for your thrust test for now!
RealGambler is offline Find More Posts by RealGambler
Old Jan 31, 2013, 06:43 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Wow! looks good
I'm anxiously awaiting for both more test videos from you, and me bloody package to arrive from HK
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Jan 31, 2013, 06:47 AM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
I just ordered two of them from Horizon Hobbies directly. $19.95 and in stock. $4.99 US mail shipping. Very cool. One of them will go into a 4-Site I have NIB and the other will either go in my Polecat or Spitfire. Thanks for the info and leads. I have the 3amp 1S ESCs from my previous attempts. Get them while they're in stock! (I didn't want to chance my LHS being on the end of the supply chain)
coreman is offline Find More Posts by coreman
Old Jan 31, 2013, 08:00 AM
chulian1819 is offline
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
Why dont parkzone uses this tiny bl engine in the future UM?
chulian1819 is offline Find More Posts by chulian1819
Old Jan 31, 2013, 08:04 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
That is the 1 million dollar question, isn't it? Why not delay the P-40 product launch and make it BL?
I guess we are still waiting for the FINAL test results. Are any of you guys going to be putting this into a Spitfire/P-40/Corsair? Honestly, my Mustang with a BSX is good enough for me, but the others I'd love to see brushless.
Also, for the Mossie - could this motor be run backwards?
whichwaysup is offline Find More Posts by whichwaysup
Old Jan 31, 2013, 08:27 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Absolutely Thats the beauty of Brushless
I have the mossie electronics, and Im currently building a P38 Lightening for them. If all goes well I'll equip it with this BL setup.
Only problem with the mossie electronics is there is no port fo a ch1 output. It has the pins there, but instead of going to a 3-pin plug they go to a pcb add-on with 2x 2 pin plugs. I think you could solder a wire to the 3rd pin and use that for the ESC. Or is worse comes to worst you could use the gear ch (xport) and mix it to throttle
Old Jan 31, 2013, 08:46 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
or a nice DiffThrust Wright, already got the gearboxs
EDIT: Nah mossey brick sux (heavy and no diff), orange Rx
Old Jan 31, 2013, 09:02 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Now that would be cool
Difficult to set up on a mossie brick though me thinks
You'd need an output on the rudder channel right
Old Jan 31, 2013, 09:37 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
I use it on my Twin Gremlins. You need two channels for the ESCs. Put the second one on the rudder channel Mix the throttle to the rudder 100% and then mix -100% rudder to the throttle so when the rudder moves it increases one throttle and decreases the other. Works great.
What P-38 are you setting up? (or is it a scratch built)
Old Jan 31, 2013, 09:51 AM
Joined Apr 2012
coreman - when you say you use it on your twin gremlins - do you mean this set up (mcpx bl motor) or a different set up?
Old Jan 31, 2013, 10:09 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
they are 3 pound airplanes. I use this PROGRAMMING to get differential thrust
Check out the flat spins on the video on the left
Old Jan 31, 2013, 10:43 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Im scratch building and designing a profile P38
Not bad for MS paint eh! I'll get the A4 PDF's up soon and start a build thread
That twin gremlin is insane Never have I seen a flat spin like that before
But the twins with differential wont work with the ar6400's (unless you have a DX8 and do some crazy mxing). I think I might use a 6ch Orange RX on it now it to get the full functionality
Sold Eflite Celectra 1S 3.7 Lipo Charger AC UM Adpater for MCPX Winterdd Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 24, 2011 07:56 PM
Sold Celectra 4-Port 1S UM charger $25 Shipped AggressorBLUE Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 24, 2011 10:11 PM
Sold Five (5) 1S UM Lipos philipa_240sx Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 20, 2011 10:10 AM
Discussion Taking the UM's brushless.... staying 1s darksiede Micro Ready-to-Fly 72 Sep 01, 2010 08:05 PM
Sold hyperion 25C 160mAh -1S-UM pttse Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 10, 2010 01:21 AM
