Old Jan 30, 2013, 01:05 PM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Originally Posted by BlazingStar View Post
Here's a real basic question:
How does the pinion attach to the motor shaft? Simple slip-on? Any special tools or adhesive needed?
press fit
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Jan 30, 2013, 01:17 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Originally Posted by bhoov128 View Post
press fit
I think RC Babbel uses JB Weld on his BSX conversions, but could be wrong.
whichwaysup is offline Find More Posts by whichwaysup
Old Jan 30, 2013, 01:23 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Yes he drill the old pinions and then puts a small amount of JB weld on the shaft and slides it on.
IndyMatt is offline Find More Posts by IndyMatt
Old Jan 30, 2013, 01:29 PM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Originally a press fit, since he has to drill. JB weld is a good idea unless you ever want the opportunity to remove your pinion again. Otherwise you might try heating the pinion on the stove or somewhere similar to expand it till the pinion slides on the motor shaft.
Old Jan 30, 2013, 05:49 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I popped mine off using pinion puller and hammered it onto the inrunners shaft. It's a really tight fit.
I fired the inrunner up n 2S with no prop this morning to make sure it ran after soldering new leads onto it. No problems so far. I'll measure kV and stuff after work.
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 30, 2013, 05:52 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Originally Posted by whichwaysup View Post
I sure hope HH is spying on this thread!
Yeah baby!!
brushless55 is offline Find More Posts by brushless55
Old Jan 30, 2013, 06:39 PM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Yes! that's what I want to hear
Would it be possible to try it on 1s, and measure the amp draw too?
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Jan 30, 2013, 06:48 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
awesome work guys, cant wait to see how this turns out!!!
dacaur is offline Find More Posts by dacaur
Old Jan 30, 2013, 07:29 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
whats the gear ratio of the gearbox?
stock steup gets in the area of 7k rpm on the prop.
so you will kneeed more if tyour making more thrust.
8000kv bl motor, at 4v, 32000rpm.
4:1 gearbox puts it at, 8000 rpm theroetical.
IIRC, Vlad mentioned the need for a really high kV, somthing like 15,000kv.
i wouls love to see what happens. if you get a chance, try a three blade gws 5030.
the stock motor shaft measure 1.45mm, so a ebay 681xxz bearing shold just slip right in.
nemoskull is offline Find More Posts by nemoskull
Old Jan 30, 2013, 08:28 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
4:1 or 36T/9T
RealGambler is offline Find More Posts by RealGambler
Old Jan 30, 2013, 08:38 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
1S runs really nice too. Time for a prop.
I hope HH is visiting because they aren't responding to messages via Facebook.
Old Jan 30, 2013, 08:50 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I cant wait
If HH are indeed visiting...... Change the setup on the AS3X bricks so that dual ailerons are possible with flaps. The problem is in the on board mixing, instead of reversing ch2 it should be mirrored.
Old Jan 30, 2013, 09:25 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by valiantGLX View Post
I cant wait
Mirror's or reversing channel 2 won't cause Flaps to work with AS3X.
Reverse Channel 2 is required to use linear aileron servos and not have to individually reverse one, since you aren't flipping the servo over like a rotary servo.
UNGN is offline Find More Posts by UNGN
Old Jan 30, 2013, 09:36 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I dont want the flaps to have AS3X, I want my dual ailerons to have AS3X while being capable of acting as flaps too.
Is there a proper term for that... Flaperons?
EDIT: I think I know what you mean now, if ch2 was mirrored instead of reversed the flaps would move in opposite directions?
Old Jan 30, 2013, 09:46 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Uploading the vid now Valiant - just a run up of the unit with prop. ETA 45mins.
Sold Eflite Celectra 1S 3.7 Lipo Charger AC UM Adpater for MCPX Winterdd Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 24, 2011 07:56 PM
Sold Celectra 4-Port 1S UM charger $25 Shipped AggressorBLUE Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 24, 2011 10:11 PM
Sold Five (5) 1S UM Lipos philipa_240sx Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 20, 2011 10:10 AM
Discussion Taking the UM's brushless.... staying 1s darksiede Micro Ready-to-Fly 72 Sep 01, 2010 08:05 PM
Sold hyperion 25C 160mAh -1S-UM pttse Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 10, 2010 01:21 AM
