C05M Micro brushless outrunner 11000kv HobbyKing AP03 4000kv Brushless Micro Motor (3.1g) hexTronik 5gram Brushless Outrunner 2000kv AD-C5 Micro Motor 4.6g Weight 3700Kv etc, etc.... The problem with direct drive is that you really need 2s to make any power, on 1s they aren''t much better than the stock brushed motors. Thats why I have opted for a gearboxed inrunner for the ultimate 1s setup
However I have hundreds of applications for a multimeter. Here's the actual one I want to buy: http://www.ebay.de/itm/350505278444?...84.m1423.l2649 Most of the page is in german, but the specs read in any language, looks like it would do alternating currents too |
I cant recommend any particular one, because I havent tried any. However I hear good thing about the AP05 ![]() With a 5030 prop on 2s you apparently get 110g of thrust The inrunner gearboxed setup weighs 4.7g, the ESC (which I hope works) weighs 0.7g, and a large 260mah 1s lipo weighs 6.5g. Not sure how much thrust it will make yet lets just say 70g The AP05 is 5.4g, a good 2s ESC weighs 6g, 2s 260mah weighs 14g. But makes lets just say 100g of thrust (I think 110g is a bit optimistic). 1s setup ca. 10g 2s setup ca. 26g (dont forget to add a few grams for a strong motor mount) 28-30g in the end Which ones better depends on your plane, how you want to fly it and wing loading. For the average PZ UM lets say an average weight of 40g (in the air)......... 1s 260mah BL setup will make it 43 - 45g with around 70g of thrust 2s 260mah BL setup will make it 65 - 68g with 100g of thrust The 1s BL setup will have less wing loading so power off landings should be possible, it will be easier to fly, yet very aerobatic. However the top speed will be less than 2s. The 2s BL setup will have a lot more wing loading so you will have to fly it fast to keep it in the air, and landings will need to be attempted at speed. Also it will be less aerobatic and you'll have to keep a close eye on the wings when bank and yanking, with the added weight and speed you could tear the flimsy wings right off your plane. If you only want to do high speed runs, and fly your plane more like a rocket this setup is for you |
on your pic it only shows 2 probe sockets so have a care... A watt meter definately the better bit of kit to purchase.. later a tacho helps both types of meter go into the line between the battery and the motor..the watt meter is easy because you just plug in the battery to one end..then take the other ends connector to the esc... no holding probes.. |
Hi! I am running the APO5 5000kv motors. Is said they push 90grams thrust with a 300 mah single cell. I dont use a scale for measuring thrust. I use a gram guage so may be the difference. I get 72 grams of thrust with one of Microaces units with their Esc and 71 grams from a HK APO5 3000kv wired for 5000 kv and using the HK 3amp esc. so far working as well as the more expensive 7 amp esc.
JCS |
A bit of digging around brought me to this thread: http://www.rcgroups.com/forums/showt...1549707&page=2
| Thread Tools | |
| Sold Eflite Celectra 1S 3.7 Lipo Charger AC UM Adpater for MCPX | Winterdd | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Aug 24, 2011 07:56 PM |
| Sold Celectra 4-Port 1S UM charger $25 Shipped | AggressorBLUE | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Jul 24, 2011 10:11 PM |
| Sold Five (5) 1S UM Lipos | philipa_240sx | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Jan 20, 2011 10:10 AM |
| Discussion Taking the UM's brushless.... staying 1s | darksiede | Micro RTF | 72 | Sep 01, 2010 08:05 PM |
| Sold hyperion 25C 160mAh -1S-UM | pttse | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | May 10, 2010 01:21 AM |
