Old Feb 02, 2013, 06:28 PM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Originally Posted by miatamama View Post
I ordered another from HK with the 3amp esc, that is working as good as the 7a so far.
JCS
miatamama,
Just a bit of clarification please
So the 3a ESC works well with the AP05 5000kV on 1s?
What prop/s do you use?
Can it still sustain full throttle?
Valiant
PS - Micron radio control sells the motors a few pounds cheaper than Microaces. It says 17 GBP, but once its in the shopping basket it drops down to 14 GBP
valiantGLX is offline Find More Posts by valiantGLX
Old Feb 02, 2013, 07:36 PM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
valiant, I use the 5x3. They seem to be the sweetspot prop. I use them on my scratchbuilt champs to the beast and anything I build. I do have some 6x3's coming and will try them. I will post a pic of the 3amp I use. Have only had 2 friday indoors to try the new motors. Have run 15 batts thru them and have not had any cutouts on either motor. I am using the cheapest 300 nano batts so had to change the connectors.
JCS
miatamama is offline Find More Posts by miatamama
Old Feb 02, 2013, 07:53 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
JCS
Cool, I just ordered 1 more of those 3a ESCs (so I have 2 in total), 2 more AP05s (so I have 3 in total), and 2 300mah nanotechs
Im gonna run 2x Ap05s with the 2 3a escs and both 300mah lipos in my scratch built/designed P-38.
and
The other Ap05 and xp-7a will go on my 3D micro mustang.
Latest blog entry: Please ignore....... for now
Old Feb 02, 2013, 09:19 PM
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
How do I attach a pic to a PM?
Speedy, This is the most important part. I cant attach to a PM
JCS
Old Feb 02, 2013, 09:57 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
You can't, but better to post it here as was suggested.
How do I get the mount off the motor to get to the soldered wires? I removed the C lock washer, but then what? Everything still seems pretty well locked together. Sorry if I'm not using the correct terms.
Gene K
speedy01 is offline Find More Posts by speedy01
Old Feb 02, 2013, 10:06 PM
I R Irv is online now
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Miata what happened to 7, 8 ,and 9?
TODD
I R Irv is online now Find More Posts by I R Irv
Old Feb 02, 2013, 10:09 PM
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Gene, I think you would have to soak it in acetone and that might take the enamel off the wires. I did everything from the back with the mount on using a magnified visor while pulling the wires thru the mount Hard to do but if I can do it anyone can.
JCS
Old Feb 02, 2013, 10:12 PM
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Irv Ignore them. You only have to work with 1-6. 7-8 and 9 just pass thru there arent any lead ends on them.
JCS
Old Feb 02, 2013, 10:28 PM
I R Irv's Avatar
Joined Nov 2008
JCS
Gotch, I was cofused because when I wind a motor I wrap
1-4-7 2-5-8 3-6-9 with 7, 8 and 9 being the termination. Same thing but different.
TODD
Old Feb 02, 2013, 11:24 PM
Desert flier is offline
Find More Posts by Desert flier
Desert flier's Avatar
Australia, SA, Morphett Vale
would any of these outrunners on HK work in a Micro Mustang?
http://www.hobbyking.com/hobbyking/s...x_GPS_C03.html
Desert flier is offline Find More Posts by Desert flier
Old Feb 03, 2013, 12:05 AM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
I did everything from the back with the mount on ....
Worked like a charm - at least on the bench: AP05 motor, HK 030 ESC, R415 receiver, Hyperion 1S240mah battery, and DX6i transmitter.
Thanks again for the help!
Gene K
Old Feb 03, 2013, 12:53 AM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Might work but you'd do some foam carving as that's an outrunner and would need clearance to spin.
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 03, 2013, 01:11 AM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
That GPS C03 motor/gearbox was discussed and dismissed a couple of years ago in this interesting thread that started out exploring what could be done with a 10mm motor/gearbox. Conclusion (if I recall correctly) was that for the cost one could get a bettermotor/gearbox combination that had a much harder prop shaft.
Gene K
Old Feb 03, 2013, 02:22 AM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
Idk
still see couple possible uses for this combo 1S & DD 2s
1) 3blade 5045s dual pusher diff thrust wright flyer lite esc on 1s would be sick
2) smallish size dd props like estes cw/ccw gh wright flyer props - finally a motor that can push cw/ccw, 8.5mm DD gets hot. some 1s smaller on 2s
maybe not ULTIMATE but liter esc than brushed, liter than stock, single cell all doable if lite and used correctly bl is mucher cooler, last longer
elvill is offline Find More Posts by elvill
Old Feb 03, 2013, 10:20 AM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Originally Posted by valiantGLX View Post
HH has no excuse! Disregarding BL there are better brushed motors to be had out there that out perform the current stock setup. Take the Bravo SX motor for example, it reportedly makes 25-30% more static thrust than the stock motor, and it even fits in the gearbox.
valGLX,
I've been selling Nine Eagles SP & SX 8.4mm brushed motors for a year or two now.
I always ask for feedback on motor performance.
http://www.rcgroups.com/forums/showp...postcount=1242
I receive many PMs and get virtually no neg feedback.
Pretty incredible!
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Sold Eflite Celectra 1S 3.7 Lipo Charger AC UM Adpater for MCPX Winterdd Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 24, 2011 07:56 PM
Sold Celectra 4-Port 1S UM charger $25 Shipped AggressorBLUE Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 24, 2011 10:11 PM
Sold Five (5) 1S UM Lipos philipa_240sx Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 20, 2011 10:10 AM
Discussion Taking the UM's brushless.... staying 1s darksiede Micro Ready-to-Fly 72 Sep 01, 2010 08:05 PM
Sold hyperion 25C 160mAh -1S-UM pttse Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 10, 2010 01:21 AM
