Old Jan 30, 2013, 05:28 AM
valiantGLX is online now
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
The ULTIMATE UM 1s BL Conversion
In an effort to come up with the ultimate 1s setup for UM planes I came up with this:
To fit it I needed to wrap a piece of tape around it 2 times:
Here's the weight compared to a stock brushed motor:
This motor is used in the newly released mCPX BL helicopter. Its primary function is to directly drive the tail rotor. The part # is: BLH3904
Specs (Snagged from here):
Motor diameter: 8mm
Motor length: 18.6mm
Shaft: 1.0mm in diameter
Shaft length: 4.4mm protruding
Weight: 3.6g AUW
There are no screw holes - only cooling holes.
However:
This setup turned out to be a bit of a turd in the punch bowl on both 1s and 2s.
Here's what some people have wrote about the 1s performance:
Anyhoo, here endeth all speculation.
The inrunner will spin a UM prop in a UM gearbox on 1S at ~5200rpm's.
The stock motor spins a UM prop in a UM gearbox on 1S at ~6900 rpm's.
The inrunner draws much less current on 1S (less load thanks to lower kV)
Having said that - Sweet mercy! she had some thrust on 2S! I didn't dare go full throttle.
We may have to work on different ratio gearboxes. I think I still have some old different ratio gearbox combo's from back in the day - I can't remember the name of them though - they came with folding props.
Originally Posted by Tarak View Post
I know this seems silly, and more than likely a moot point for our current crop of UM BNF or RTF birds that we were hoping this would be a direct drop in for, but what about propping up the gearbox for more thrust? Would that work, or am I missing some other key component of the equation? Just a thought...
Originally Posted by microheli View Post
Some calculation for 1S:
Code:
Volt    kV    Gear   Slip    rpm   Thrust(5030)
3,7V * 8100kv  / 4  - 30% =  5200 = 25g
3,7V * 13000kv / 4  - 30% =  8400 = 65g
3,7V * 8100kv  / 3  - 30% =  7000 = 44g
3,7V * 8100kv /2,67 - 30% =  7800 = 55g
Other props are also worth to try and 2S with limited Throttle Curve seems possible but need some tests.(current, temp, cooling)
Now here's my thoughts on 2s performance
Originally Posted by valiantGLX View Post
I just ran a 2s thrust test, here's how it went:
http://www.youtube.com/watch?v=pcyRh1DkEPY
My conclusion: This motor and gearbox combo is a dud whether on 1s or 2s It makes about 60g of thrust on 2s with a UM eflite 2 blade prop but the motor cant sustain it. It gets incredibly hot quickly even at around half throttle
My advice: If you have some on order cancel it asap, if they are already on the way try to return them or leave them in the package and flog them off on ebay. Even with 1s you'll need an abnormally large prop to make the same if not less thrust than the stock motor by the sounds of things.
...And here's a 2s thrust test in case you missed it:
mCPX BL tail motor in a UM gearbox on 2s FAIL!!! (1 min 5 sec)
So on to the next motor..... The AP05 5000kV 1s BL motor looks like a winner!
The AP05 5000kV 1s outrunner, it ticks all the boxes, well almost all of them!
1. its 1s
2. it produces 70-90g of thrust with a 5030, and thats not speculation either
3. will work with eflite props, so scale looking props and enough ground clearance for LG is very possible
4. weighs about the same as the stock gearboxed brushed motor
Only downside it that you will need to add a motor mount, but that wouldnt be any more difficult than building your own gearbox or trying to make an aftermarket gearboxed BL motor fit in.
Micronradiocontrol sells both the The AP05 5000kV and mounts for them.
Heres their thrust data for both the AP05 3000 & 5000kV:
3000Kv:
Prop Volts Current Thrust
4x2.5 3.5V 0.9A 32g
4x2.5 7V 2.2A 87g
5x3 3.5V 1.2A 45g
5x3 7V 2.8A 110g
5000Kv:
5x3 3.7V 4.5A 90g
1s ESCs:
ESC: As I dont know for sure how many amps this little motor will draw its hard to select a BL ESC. HobbyKing has a few options though:
6A 1S Brushless Speed Controller
Pros - This would be the easiest one to use for sure, its more or less plug and play. Also it has a built in brushed to BL signal converter, so it will work if you plug it into the motor output of the HH 1s AS3X boards. This ESC has a host of built in programming features too, which dont need a programming card to activate.
Cons - It is never in stock and it weighs quite a bit in comparison to the other choices.
5A 1S Brushless Controller
Pros - Weighs less than the 6a ESC, and its always in stock.
Cons - Its always in stock because its rubbish, just about every review is bad. There are no instructions for it, therefore no one knows how to program it if it is even possible.
XP 3A 1S 0.7g Brushless Speed Controller
Pros - Weighs just 0.7g, comes with 3-pin connectors and is programmable without a programming card
Cons - Hard to find any faults.
SuperMicro Systems - Brushless ESC - 3.5A
Pros - super light at 0.3g and 3.5a continuous power
Cons - Only 4a burst, not programmable, and doesnt include plugs
There are a couple of new 1s ESCs on the HK site but they're not really worth a mention.
valiantGLX is online now Find More Posts by valiantGLX
Old Jan 30, 2013, 05:58 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Done exactly the same thing this end Valiant.
Just need to solder a different plug to the motor and it's go time!
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 30, 2013, 06:02 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Have you done any thrust tests yet?
Also I'm hoping that it will plug directly on to the ESC I bought, looks like it will be a good fit anyway.
Old Jan 30, 2013, 06:09 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Here's some thrust tests I did with the stock brushed motor:
E-flite and GWS prop thrust tests with the 1s UM motor and gearbox.wmv (1 min 30 sec)
Latest blog entry: Please ignore....... for now
Old Jan 30, 2013, 06:31 AM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
Genius idea!
I just have to try this.
thanks!
green_flyer is offline Find More Posts by green_flyer
Old Jan 30, 2013, 07:02 AM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Can't wait to see what you guys get for thrust with this. Anyone know what the KV rating is for the original brushed one? are we going to be using similar props?
coreman is offline Find More Posts by coreman
Old Jan 30, 2013, 07:03 AM
dbdukeboy is online now
Find More Posts by dbdukeboy
Newbe learning everyday!
dbdukeboy's Avatar
United States, OH, Parma Heights
Joined Aug 2012
I need to keep updated on this mod
dbdukeboy is online now Find More Posts by dbdukeboy
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Pinion:
M0.3 1.0mm 9T pinion
This one seems to be as good as any, and its cheap enough, so I threw it in with my ESC order.
A long time ago, I did order a 9T pinion from HK and it didn't work (still using old pinions from burned motors). It may have been another one, but I think it was this one. Just telling you because you may want to have a "plan B", just in case.
RealGambler is offline Find More Posts by RealGambler
Old Jan 30, 2013, 07:08 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Thanks for the heads up. My prior plan A is actually my plan B mCPX 9t pinions should fit too, but they cost like 5x more.
Old Jan 30, 2013, 07:17 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Me Too
No idea on the brushed kV rating do brushed motors even use the kV rating scale
The prop depends on what ESC you are using and the current draw, which is yet to be determined I would like to use the spitfire 4-blade though, its the best all rounder IMO
Old Jan 30, 2013, 07:26 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I am looking at buying a cheap multimeter, does any one know how I can test the amp draw with one (assuming that my ESC was here already)???
Old Jan 30, 2013, 07:29 AM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Outstanding
This will be a great read, and I hope you get this "mod" refined!
Gene K
(As concerns the HK pinion - I also wasted a few pennies hoping it would fit - it didn't. Glenn at RC Connectors sells the correct pinion, but likely won't reveal his source (of course - he runs a business, a great one at that).
Gene K
speedy01 is offline Find More Posts by speedy01
Old Jan 30, 2013, 07:34 AM
chulian1819 is offline
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
Great idea!
what other engines can fit a UM but conected directly to the prop?
chulian1819 is offline Find More Posts by chulian1819
Old Jan 30, 2013, 07:39 AM
Canada, QC
Joined Oct 2009
Hard to tell from the picture if this one mesure DC amps or AC amps. You need something that mesure DC amps. But if I were you, I would buy a Wattmeter (check HobbyKing). Those cheap multimeter don't last long (particularly the probes), and give slow reading (one every second or so). With a wattmeter, designed for our hobby, you get instant result, and peak result (much more valuable). Trust me, much more valuable than a cheap multimeter!
Old Jan 30, 2013, 07:42 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Gene K[/QUOTE]
and RCBabbel recently said he had found a source also
Sold Eflite Celectra 1S 3.7 Lipo Charger AC UM Adpater for MCPX Winterdd Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 24, 2011 07:56 PM
Sold Celectra 4-Port 1S UM charger $25 Shipped AggressorBLUE Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 24, 2011 10:11 PM
Sold Five (5) 1S UM Lipos philipa_240sx Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 20, 2011 10:10 AM
Discussion Taking the UM's brushless.... staying 1s darksiede Micro Ready-to-Fly 72 Sep 01, 2010 08:05 PM
Sold hyperion 25C 160mAh -1S-UM pttse Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 10, 2010 01:21 AM
