Guess it's a 6S plane because it goes beyond Pattern "not just the ability to perform elegant F3A sequence aerobatics, but extreme 3D stunts as well"; 3D is not part of Pattern.
http://www.horizonhobby.com/products...ology-EFL10250 It's on my list! |
JRB,
I tend to go more by the 'engine/motor-size' designation of the plane. The size of the power-package typically contributes more to the overall cost of a plane than the airframe, as it usually drives hardware & servo requirements, as well. In other words, 50-size planes generally cost more to put in the air than 40-size planes of similar quality, even when the wingspans are similar. Joel |
United Kingdom, Taunton
Joined Dec 2012
Looking at the UK price of £289, I think it is good value. There are not many quality F3A aircraft of that size you can put together for that sort of cash. Most kits cost £150 and £140 more is somewhat pushing it for ESC/motor/servos etc.
I only see 2 negatives. One is that the 3D is more of an extra than it's main purpose and I hope nobody buys it first and foremost for that when looking at it in a LHS. The second is the AS3X being illegal for competitions. Even then, I guess it is OK if you can prove the gains are turned off. NB: This is of no issue to me as I can't do a single aerobatic move that I think looks good! |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Since it's meant to do things w/o air over the wings -- it needs more POWER. Wonder if it would do Pattern (only -- no 3D sh-t) on 5S? |
VALUE: Last year I built the Acromaster ARF (foam), with decent components $550 dollars total , plus all the time and gathering up all the correct components and parts the painting and assembly.......In the end I had an aircraft I do not like, has weak landing gear and a weak motor mount. BTW figure in an AR635 and it would be over 600!!!!
![]() FIT/FINISH: If the Splendor is similar to the Visionaire (I have one), the fit, finish and assembly will be AWESOME !!!! ![]() ![]() THE AR635 Rx: dont knock it until you have tried it, remember standard Spectrum Rx is about $60-70 bucks, so this only adds $50, and a whole lot of wind capability. Ask me if I like the Visionaire????? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Specs say 5.5 pounds, 19.7 oz/sq ft WL, and 5-7 min flights on a 6s 3200 with the 525Kv motor & the included APC 14x7E. The demo video doesn't show any extended verticals. However, the plane appears to hover just fine on 6s, so you may be able to prop it for F3A on 5s. Looks like the pack mounts considerably forward of MAC. It would be a matter of choosing a 5s pack that weighs enough to get the CG right for precision flying.
Joel |
I fly a lot of planes w/60BL (vs 46) on 6S-A123 (near 5S) w/14x12 and get very sprightly performance @ 30amps; i.e. Toledo Special.
My calcs indicate the 50BL/Kv525 should be very nice with 14x7 on 5S. !
Oakland township, Michigan
Joined Jun 2005
For reference, I fly a SebArt Angel at 6lbs on 5S. The motor is an Axi 4120/18 with a Kv of about 515 if I remember correctly. For prop, I use an APC 15x10E. With that set up, the plane tops out at around 70-75 mph or so. I am currentlt flying the Intermediate sequence with it and I can make the stall turns as tall as I like them. Not sure that it has unlimited vertical as I normally stall turn before I can't see the plane any longer
.The plane was flown at a contest were the sustained winds were at 20 mph with gusts to 28 mph (the club had a weather station). That was the only time where I felt I really could use more speed. Going into the wind, each pass seemed to take forever. The set-up is good for about 1100-1200 watts depending on the battery being used. On a 5.5 lb this should be more than adequate. The one thing people seem to forget is that it takes more power to generate speed than it does generate thrust. Taken to the extreme, an RC helicopter is able to hover on about 40 w/lb... More than anything is a matter of picking the right prop for the application and power available. Teo |
| Thread Tools | |
| Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! | DFflyer | 3D Foamies | 3561 | Yesterday 12:56 PM |
| For Sale NIB E-Flite Carbon-Z Yak Servo | Cobra68 | Aircraft - General - Radio Equipment (FS/W) | 0 | Jan 27, 2013 05:02 PM |
| Sold E-Flite Carbon Cub UMX BNF $95 | daver22 | Aircraft - Electric - Micro & Indoor Airplanes | 2 | Jan 27, 2013 03:48 PM |
| Sold E-flite Carbon-Z Yak 54 PNP *LPU* | jjohns51 | Aircraft - Electric - Airplanes (FS/W) | 3 | Jan 06, 2013 02:37 PM |
| Sold E-Flite Carbon-Z Yak 54 BNF | 2rbimmer | Aircraft - Electric - Airplanes (FS/W) | 3 | Feb 16, 2011 09:44 PM |
