Old Jan 30, 2013, 02:17 AM
coolmobility is offline
Find More Posts by coolmobility
coolmobility's Avatar
Australia, VIC, Paynesville
Joined Sep 2009
Waxing Hull for Racing - to wax or what?
Do you experienced guys wax your hulls for improved speed or not? In my kayak paddling days a waxed hull was much more slippery and easy to paddle and I'd wax my small yachts before races.
I know in large sized yachts there is discussion re waxed hulls or finely sanded for fastest hulls and antifoul types/preferences. Haven't seen any comments on waxing RC yachts on any thread though...
I'm relatively new to IOM racing and a mate has just reconditioned an identical hull to my Orca (wide planing hull). When he launched it in drifting winds he just walked away from me without any real trimming. I though (hoped) that it was his shiny new paint job versus my old oxidised one. Perhaps waxing my hull would help in below hull speed conditions. When wind picked up I was fully competitive with all in fleet (Actually 2nd overall).
Looking for comments and feedback.
Colin
coolmobility is offline Find More Posts by coolmobility
Old Jan 30, 2013, 03:41 AM
waboats is offline
Find More Posts by waboats
Joined Jan 2007
C.5.2 MAINTENANCE
Routine maintenance to the hull such as removing and adding fittings and remote control
equipment, replacing hull patches, painting, polishing, smoothing etc., is permitted
without re-measurement and re-certification provided the compliance with D.2 is not
affected.
waboats is offline Find More Posts by waboats
Reply With Quote  (Disabled)
Old Jan 30, 2013, 03:51 AM
bigpat is offline
Find More Posts by bigpat
Love RC Yachts!!!
Australia, VIC, Melbourne
Joined Aug 2012
Check my post in IOM discussion...
But no, i don't wax, but use a silicone free polish on thd hull, and 1200 wet and dry on the foils and bulb.....
bigpat is offline Find More Posts by bigpat
Old Jan 30, 2013, 05:55 AM
seabee CE is offline
Find More Posts by seabee CE
Nirvana 38, Seawind 178
seabee CE's Avatar
Joined Feb 2012
Some of the ODOM guys I raced with used RainX on the hulls, not saying is good or bad, just adding another theory.
seabee CE is offline Find More Posts by seabee CE
Old Jan 30, 2013, 02:01 PM
Hircsailor is offline
Find More Posts by Hircsailor
Kimo
United States, HI, Honolulu
Joined Jun 2011
Some of our guys use mold relase wax, one even uses that once a year car wax,while some don't do anything to their hulls. Believe that any difference is in the trimming and s]the skippers skill. As far as sanding the hull the only real difference that I have seen was in the hull finish and no real change in speed. What works on full size boats doesn't always work on models.
I base this on not being able to sail the last 9 months and just watching the guys sailing so I wasn't distracted by sailing.
Hircsailor is offline Find More Posts by Hircsailor
Old Jan 30, 2013, 02:43 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
The next time your mate is sailing with you and walking away, swap rigs. If the increase in speed follows the rig you'll know where the speed comes from. I believe that rig tuning is far more critical in light air than in heavy air. Next most important item would be fin and bulb position/angle/etc. A tiny difference in bulb angle might make up the difference as well. Of course, I'm assuming your hull is fair and doesn't contain giant bulges, cavities, etc and only differs from your friends in surface finish.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Jan 30, 2013, 04:04 PM
Tom Corbett is offline
Find More Posts by Tom Corbett
Joined Mar 2012
The answer to the question is "No". Do not put wax on a sailboat hull. It is slower. To make some very complicated hydrodynamics simple--there is less drag if you have a thin layer of water sticking to the hull rather than water repellent wax. If you want, sand with a fine grit wet/dry sandpaper--900 or above and then polish from time to time. This is a matter of fact, not opinion.
Tom Corbett is offline Find More Posts by Tom Corbett
Old Jan 30, 2013, 04:34 PM
Joined Sep 2009
Thanks for the feedback. Now I'm just as confused as I was from big boat discussions.
What is the difference between waxing (with car wax) and polishing?
Wouldn't sanding with 900 or 1200 grit then polishing end up with a smooth surface again?
As a newbie, this forum is filled with great knowledge but seems there are naturally many opinions and few definitive answers. My job to decide on balance of opinions.
Old Jan 30, 2013, 04:38 PM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
The sanding should be done with soapy water to stop the grit paper clogging.
ToniGe23 is offline Find More Posts by ToniGe23
Old Jan 30, 2013, 05:26 PM
Joined Mar 2012
We are talking about rough/smooth at a very fine level. The idea is that you want to have a level of roughness in your finish sufficient to trap a microscopic layer of water to the hull. This is because the friction difference between water and water is lower than between water and wax (hence less drag). Anything that repels water--like wax--is a bad thing. This is not an "opinion' thing it is established, basic hydrodynamic fact.
Old Jan 30, 2013, 06:02 PM
ToniGe23 is offline
ToniGe23's Avatar
Joined Jun 2005
Club member of mine has a Topico an ex Graham Bantock boat, below the water line it's been rubbed back with 1200 grit and it sure is a slippery bugger in light winds!
Old Jan 30, 2013, 06:31 PM
Joined Sep 2009
Thanks for the clarifications. Makes more sense now. Have to get some 1200 grit wet/dry and soapy water and give it a try. Can't do much harm with a light 1200 sand on wetted areas and may wax the deck to get better water shedding.
Thanks again.
Old Jan 30, 2013, 06:36 PM
Gregg28 is offline
Find More Posts by Gregg28
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
Waxing is adding a microscopic hydrophobic (water repellant) finish. Polishing is just using friction to get a microscopic smooth finish without adding anything.
Gregg28 is offline Find More Posts by Gregg28
Old Jan 30, 2013, 08:01 PM
waboats is offline
Joined Jan 2007
The basic difference in the term wax as opposed to polish is more to do with the understanding of each compound used.
Waxing in 1:1 scale generally adds a layer to the outside of the hull & this is OK when considering the size of water molicules..
In R/C terms the water cannot be scaled so waxing would be OUT IMHO.. Then as pat says using a Silicone Free Polish & 1200 builds a perfect finish.
Be mindful of the size as you scale down.. Some people comment that their boats become more twitchy to sudden changes in wind pressure & can tend to round-up easier. Not sure I agree but if the idea is to move easier through the water by reducing friction then it goes as said that movement in ALL directions is improved by the reduced friction... So improved concentration & oveall balance of the boat may be needed.
Old Jan 31, 2013, 03:23 AM
KoneWone is offline
Find More Posts by KoneWone
KoneWone's Avatar
Germany
Joined Mar 2009
Agree 100% most noticable difference is in light airs. I measured 2 hulls with push test across swimming pool 10 meters (without rigs) 20 times to find average measure between boats touching other side of the pool, then sanded one hull and it made gain of 10 cms !!!
Over 100 meters that = 1 metre
KoneWone is offline Find More Posts by KoneWone
Question Any suggestions for a pylon racer tx? Or what min characteristics? demuddy High Performance 7 Jan 29, 2013 03:08 PM
Discussion Thought about applying wax paper to the bottom of my hull GreenAce92 Waterplanes 5 Jan 09, 2011 07:43 PM
Discussion what raceing or standerd upgrades should i get for my t-maxx 3.3 robertsos Off-road Cars 12 Apr 01, 2008 09:13 AM
Discussion new racing boat hull - what engine, etc ?? shappo Racing Boats - Internal Combustion 6 Jan 06, 2008 05:46 AM
What to do first, Polish or Wax? ecologito Life, The Universe, and Politics 6 Jan 19, 2005 09:01 PM
