Old Jan 30, 2013, 12:39 AM
loquacious is offline
Find More Posts by loquacious
loquacious's Avatar
Australia, WA, Perth
Joined Apr 2012
Question
Run Low Voltage Alarm plus LEDs
I want to run my low voltage alarm and LEds from my 3s battery balance connection. Is there an adapter that allows me to do this and if so where could I purchase one from?
loquacious is offline Find More Posts by loquacious
Old Jan 30, 2013, 12:47 AM
squid10 is offline
Find More Posts by squid10
Israel
Joined Nov 2012
http://www.hobbyking.com/hobbyking/s...rm_2s_4s_.html
squid10 is offline Find More Posts by squid10
Old Jan 30, 2013, 12:52 AM
loquacious's Avatar
Joined Apr 2012
Originally Posted by squid10 View Post
Thanks but I already have the alarm and LEDs .. what I am after is an adapter so I can run both off the same battery.
Old Jan 30, 2013, 05:46 AM
Mrhide is offline
Find More Posts by Mrhide
Mrhide's Avatar
Canada, QC, Laval
Joined Aug 2012
you could certainly use this one
http://www.hobbyking.com/hobbyking/s...onitor_3S.html
...and plug in a JST connector for the LEDs?
Mrhide is offline Find More Posts by Mrhide
Old Jan 30, 2013, 08:40 PM
loquacious's Avatar
Joined Apr 2012
My LEDs are running off the battery balance plug., I also want to put a battery monitor on it too how can I run BOTH from the battery balance plug?
Old Feb 01, 2013, 07:42 PM
loquacious's Avatar
Joined Apr 2012
I am guessing due to lack of responses that what I am trying to do cannot be done?
Old Feb 01, 2013, 08:29 PM
heli-yeah is offline
Find More Posts by heli-yeah
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
A couple of questions:
  1. What voltage LiPo are you using?
  2. Does your voltage alarm monitor each cell, or only the total pack voltage?
  3. Are your LEDs rated for the full voltage of your battery?
  4. Do you solder, or know anyone who can do it for you?
heli-yeah is offline Find More Posts by heli-yeah
Old Feb 01, 2013, 08:37 PM
sgg05158 is offline
Find More Posts by sgg05158
Singapore, Singapore
Joined Oct 2012
Voltage display of total voltage and individual cells plus buzzer alarm when voltage drops to certain level are very common..
http://www.hobbyking.com/hobbyking/s...age_Alarm.html
sgg05158 is offline Find More Posts by sgg05158
Old Feb 01, 2013, 09:11 PM
loquacious's Avatar
Joined Apr 2012
I am using a 4500mAh 11.1v batter
The alarm I have measures each cell
LEDs are rated for full voltage
I can solder to some degree / also know someone who can solder
Old Feb 01, 2013, 09:12 PM
loquacious's Avatar
Joined Apr 2012
Hi sgg0158
I already have the voltage monitor and the LEDs I am just looking for a way to run them both together. I thought there might be an adapter out there so I could connect both to the balance plug on my lipo
Old Feb 01, 2013, 09:28 PM
MayMayDay is online now
Find More Posts by MayMayDay
ParagonUAV
MayMayDay's Avatar
Canada, BC, Vancouver
Joined Mar 2012
If the LEDs are rated for the 3S lipo, just add a JST or other connector to your power distribution board/harness. Run them directly from there and the battery alarm off the balance plug.
MayMayDay is online now Find More Posts by MayMayDay
Old Feb 02, 2013, 11:12 AM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
I have a few follow-up questions, but I will try to recommend a few options based on the more common set-ups that I am familiar with.
Assuming you have JST-XH balance connectors on your batteries, you could get something like this product. Simply cut away one of the male connectors, and excess wires, then solder it to suit your needs.
JST-XH Parallel Connector
Essentially you would be making a little bridge from the male, and female connectors, then you could "tap-out" the type of connector you need for your LEDS using the outside two wires (12V). (Same idea as the connectors linked below, that use JST connectors.) You would also need some heat shrink.
Another (solder free) option, could be to dedicate the balance tap to the voltage alarm, and use one of the products below to power your lights. (Again, assuming you use one, or the other type of battery connector...)
Deans connectors w/JST (male)
XT-60 connector w/JST (male)
Using a distribution board is a good clean option, I have used that method in the past. Recently I have eliminated all distribution boards from my multi's, and started using a custom wiring harnesses fitted with taps for accessory power.
Old Feb 03, 2013, 12:59 AM
loquacious's Avatar
Joined Apr 2012
Thanks for all the info .... I will give option one a go as I am not really keen on having another connection coming off the main battery lead. Probably being over cautious but the balance lead with parallel connector seems like a good option.
Old Feb 03, 2013, 03:19 AM
jseyfert3 is offline
Find More Posts by jseyfert3
Posted as eflightdude 06-07
United States, IL, Peoria
Joined Aug 2012
<snip>
Hmm, I've got a 10 pack of the balance extenders, and I want to feed battery voltage to my Naze32, as it has a built-in voltage monitor. But I don't feel like unwrapping the electrical tale on my wiring harness right now, and this is a good solution until I get tired of plugging in two wires all the time. Thanks!
jseyfert3 is offline Find More Posts by jseyfert3
Old Feb 06, 2014, 08:35 AM
Patrollin is offline
Find More Posts by Patrollin
Joined Feb 2014
I have run into the same problem, could you purchase a set of the 3s JST-XH connectors
http://www.ebay.com/itm/10x-3S-4-Pin...-/300931361267
And make a reverse of this cable (2 male 1 female)
http://www.hobbyking.com/hobbyking/s...2xJST_XH_.html
Then plug one end into the voltage alarm and the other into an adapter to power the LED's
http://www.hobbyking.com/hobbyking/s...ad_4_JST_.html
Patrollin is offline Find More Posts by Patrollin
Question Wire in Low Voltage Alarm directly into board Guntar Multirotor Talk 2 Jul 02, 2013 12:58 PM
Help! How to calculate low voltage alarm for 4S? Scooter619 Batteries and Chargers 2 Jan 18, 2013 03:14 PM
Article Hobbymate Low Voltage Monitor LED/Alarm Review 78dave Batteries and Chargers 3 Jul 19, 2012 07:54 PM
Discussion 1s lipo led low voltage alarm scheme otoman Power Systems 0 Jan 09, 2012 09:14 AM
