Old Feb 22, 2013, 03:50 PM
maxmus is offline
Find More Posts by maxmus
Joined Aug 2012
Hello, I am building a TBS Discovery with APM 2.5+ with ublox gps and I'm running into a weird issue.
With power going through the Power Module, I get 0 satcount, and on USB power, I get 10+ satelites instantly.
I've checked it by having the APM powered only by USB power, logging on the PC. I get solid 10+ satelites. As soon as I attach external power (ie: battery, lab-grade DC powersupply, etc), satelite drops down to zero. I also did a test on the console, by typing test command, and gps. same results there.
I've tried grounded aluminum foil wrapped around the power module to see if that is it, no dice. This is the second Power Module that is doing this, first one went back and got replaced because I thought the problem was the power module.
I hope you guys can tell me what I need to do to fix this... Thanks in advance.
maxmus is offline Find More Posts by maxmus
Old Feb 22, 2013, 04:01 PM
RYBAT is offline
Find More Posts by RYBAT
Hires and Fires Dev's
Joined Feb 2008
Try Lipo power with the GoPro turned off....GoPro's emit huge RF Noise from rear of case...I see your GPS Antenna is too close to the GoPro
RYBAT is offline Find More Posts by RYBAT
Old Feb 22, 2013, 04:04 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Are you using the TBS power distro system...the one built into the frame plate? Is so, you may be picking up 'noise' from that. Also having your GPS antenna so close to your GoPro (noisey camera) may be an issue. I put my camera and VTX (with antenna) up front and my Rx and GPS antenna's in the back and have no problems with sat locks. I'm using the RCT CN06 GPS as well as their current sensor.
Vantasstic is online now Find More Posts by Vantasstic
Old Feb 22, 2013, 04:08 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
I am impressed with this board.... everything is on stock setting other than some minor alt hold tuning.... this thing flies autonamous very well, however I need to tune the stabilzation in order to get better smooth flying.
anyway very nice board, I ordered three more
Steve
saabguyspg is offline Find More Posts by saabguyspg
maxmus is offline
Joined Aug 2012
Thanks for the fast replies gentlemen.
The above test was done with everything un-powered. Gopro didn't have power, the video TX did not have power. Only things that had power were the ESC's and APM and GPS and the 3DR Power Module.
I am not using the TBS Core powersupply.
Even if the noises were the cause, the problem wouldn't go away by running USB power right? This is very weird... :/
I will try and see if the TBS's distribution board in the frame is causing the issue, by powering up the frame and powering up the apm separate via USB.
Old Feb 22, 2013, 04:35 PM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
Originally Posted by Wingbreaker View Post
tried it didnt work should i try rx to rx and tx to tx?
"it didn't work" offers no clues.
do any LEDs light up on the GPS ? does it have any LEDs ?
Are you testing indoors or outdoors ?
How long did you wait ?
How did you determine it didn't work ?
Which connector on ArduFlyer 2.5 are you connecting the GPS to. ?
jabram is offline Find More Posts by jabram
Old Feb 22, 2013, 04:42 PM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
I tried in terminal: test then gps
It never communicated.
I am connecting it to the side molex connector labeled GPS as per the diagram posted.
Also, keep in mind I am dealing with the readytoflyer from witespy. it has just the side facing gps female port.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Feb 22, 2013, 04:52 PM
jabram is offline
Joined Jul 2012
can you post a photo ?
Old Feb 22, 2013, 05:02 PM
Video Juggernaut
Joined Nov 2003
all photos are post a few pages back.
Old Feb 22, 2013, 05:13 PM
jabram is offline
Joined Jul 2012
I was thinking a current photo of how you connected it, saves a lot of questions.
Old Feb 22, 2013, 05:47 PM
Video Juggernaut
Joined Nov 2003
I connected as per other member's instruction.
Gnd to 1
tx to 3
rx to 4
vcc to vin 2 and tried 6 1pps too.
from the gps board to the side gps female molex (upper left position of board in the pic) to the 4 pin points or solder locations of the gps module.
Old Feb 22, 2013, 06:15 PM
jabram is offline
Joined Jul 2012
I have no idea where he got those connections from - THEY ARE WRONG
It is EXTREMELY FRUSTRATING when trying to help you and you do not answer my questions and also cannot be bothered to take a CURRENT [that means as it now is] photo.
Old Feb 22, 2013, 06:56 PM
Video Juggernaut
Joined Nov 2003
What's there to show? I am using the old connection.
I am not running the same board as your picture. it doesnt have the new gps molex female. You basically are telling me the same thing the other guy told me but just different wiring. I can take a picture but it will just show you the side (old gps port as I stated) wired the way the guy said. I'd wire to the new gps port but I dont have it. A photo would look just like the pic of the board I posted, no new gps port and no other molex connectors.
Old Feb 22, 2013, 07:01 PM
maxmus is offline
Joined Aug 2012
You were correct, the distribution system built into the frame plate was causing a havoc on the APM's GPS. Its sitting about 5mm off the bottom plate, and everything is kosher.
Thank you so much, for some reason I didn't even think of the plate at all.
Old Feb 22, 2013, 07:11 PM
Video Juggernaut
Joined Nov 2003
hey that worked, thanks. next question. I am running power from one of my ESCs through one of the inputs. I read running power from the esc is not the greatest idea on this. IS that true? I do have a power sensor from 3dr : http://store.diydrones.com/APM_Power...apmpwrdean.htm Since this board doesnt have the molex for it on there would you know what connector i should buy to connect it? I contacted 3dr, they might sell the little connections but no reply yet.
For Sale ArduPilot Mega 2.0 + Accessiories (PRICE REDUCED!) tresani Aircraft - General - Radio Equipment (FS/W) 1 May 18, 2014 10:19 PM
For Sale ArduPilot OSD MinimOSD and other items for ArduPilot Mega Ecibob Aircraft - Electric - Multirotor (FS/W) 5 Jan 17, 2013 10:59 AM
Sold Ardupilot Mega APM 2.0, SONAR, MinimOSD, Telemetry, Quad PDB kingiggy262 Aircraft - Electric - Multirotor (FS/W) 3 Sep 18, 2012 02:13 PM
For Sale Ardupilot Mega APM V1/900 MHz Xbee/Bixler Chassis - $300 shipped justjason Aircraft - Electric - Multirotor (FS/W) 2 Jul 13, 2012 01:22 PM
Wanted Trade: My Ardupilot Mega (APM) for a Hover Fly Pro Adidas4275 Aircraft - Electric - Multirotor (FS/W) 2 Nov 21, 2011 08:26 PM
