Old Jan 29, 2013, 10:39 PM
series57r is offline
Find More Posts by series57r
United States, LA, New Orleans
Joined Dec 2012
Curtiss flying boat
Hi all.
Hope this is the right place for the post.
Electric copters brought me back to R/C after many many years.
While messing around with copters a good friend gave me a beat up
Sukoi from Park Zone? to relearn to fly.
What a sensitive little thing! Did manage to relearn flying before the foam
wore out
All the guts are good and thinking of building something for the electronics that my old slow self can keep up with.
Input on building the airplane in the picture?
Around 13-14 inch span?
So much has changed in materials and so forth it seem a little puzzling and hard to decide what to use. Looking around best choice would be Depron(?)
up with. I love early Flying Boats
Balsa i know how to work, dread having to water proof inside and out.
Thanks!
series57r is offline Find More Posts by series57r
Old Jan 30, 2013, 12:02 AM
minimicrorc is offline
Find More Posts by minimicrorc
Joined Apr 2012
I think depron would be pretty good. the only thing that you might have a problem with is the size of the stock prop.
minimicrorc is offline Find More Posts by minimicrorc
Old Jan 30, 2013, 10:29 AM
Joined Dec 2012
Thanks minimicrorc
Enlarged a 3 view to 14 inch span and looking at that if I raise the prop shaft then
cut 1/4 inch or less off the blade tips of propeller that I would have about 1/8th inch clearance.
Would the reduced load on the motor be a problem?
Not much on electric motors, back in the day everything was glow engines.
Now I need to figure out what exactly Depron is.
As well as finding a good source in the States.
If Depron is what the elevator and rudder of the Sukoi are made from this appears to be the same a pick nick plates? Playing around it looks like foam super glue works well.
Learning is fun and have I got allot to learn about this 'new' stuff.
Old Jan 30, 2013, 12:11 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Depron is similar to take out box / stryofoam plate foam. Most hobby shops carry "cellfoam 88" depron sheets.
You want 2mm.
UNGN is offline Find More Posts by UNGN
Old Jan 30, 2013, 06:12 PM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
2mm white and 3mm grey depron
elvill is offline Find More Posts by elvill
Old Jan 30, 2013, 08:20 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
By the way, since 2 mm Depron is 90-100 percent the weight of 3 mm, sometimes 3 mm is a better solution.
http://home.comcast.net/~gordon-johnson/materials.htm
http://www.rcgroups.com/forums/attac...mentid=3757710
Petefoss is offline Find More Posts by Petefoss
Old Jan 30, 2013, 08:54 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
For small models, 3mm is just so chunky. It's not so much the weight, its that 3mm needs a lot of sanding to get smaller.
Old Jan 30, 2013, 10:01 PM
Joined Dec 2012
UNGN
Thanks for the take out box idea.
If I use a center section on the top wing to match the fuselage width it will come up to the 14 inch span
The round plates are thinner and look perfect for tail feathers.
Either one will have to be spliced for fuselage length.
looking at carbon fiber rod for struts and heavy black thread for bracing.
Bummed some take out boxes from the store deli so tonight will do some cutting
of parts and see how it looks.
Pete
Thanks for the links
This is extremely hand info.
Are there any articles or info on working this stuff?
Did a site search on Depron and nothing came up.
Elvill
Who did you order your depron from?
Have found BDS site. would be nice to be able to acquire wall foam in the U.S.
Thanks everyone
I feel better about success with this project now and will possibly have many
silly questions.
The LHS now days seem to be more like a toy store, no building required
The do have some carbon rods and super glue so not a totally wasted 60 mile trip. No Balsa, Ply, spruce of foam!
Old Jan 30, 2013, 10:24 PM
Joined Apr 2012
Originally Posted by series57r View Post
UNGN
Pete
Elvill
Thanks everyone
silly questions.
I usually get my depron from http://www.rcfoam.com/ , they have a large selection, but the only problem I have is the shipping cost
Old Jan 31, 2013, 08:34 AM
Joined Dec 2012
Thank you minimicrorc, another good site to save.
Stayed up late and have 90% of parts cut. Quick and easy to cut out and trim to fit.
Fuselage sides and formers are together
The flat bottoms of the foam boxes and plates is not flat
Not a problem except for the wing panels as they are curved in 2 direction.
Have an idea on how to cure the problem with an aluminum jig bent to have camber
to place panels on and a little heat to reshape the foam to the jig.
The camber should flatten and stiffen wing in the span direction.
So far having a blast so something is bound to go wrong soon.
Old Jan 31, 2013, 09:04 AM
TedD60 is offline
Find More Posts by TedD60
Joined May 2012
I know that the little Curtis you are building is not the NC4 used by the USN to cross the Atlantic, but I have included some plans and etc that I found of building and detailing one. Maybe you can find some of it useful.
I also have the story of that amazing flight ... its a true story but it reads like an old fashioned boys action novel. If i can, I'll find it and post it.
TedD60 is offline Find More Posts by TedD60
Old Jan 31, 2013, 09:59 AM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
Can you post a bigger version of the three view instead of the thumbnail?
Old Jan 31, 2013, 12:51 PM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
Thanks!!!!
Old Feb 01, 2013, 12:46 AM
Joined Dec 2012
Hi oddshot
I keep looking a the NC-4 and seeing lots of carbon fiber rods!
One day I hope. Read the story of the Crossing 45 years or so, wouldn't hurt to
read again if time ever allows reading.
For the next Depron Boat kind of thinking the Curtiss America.
Pretty Airplane!
Sucks when the girl hobby shops are well stocked with balsa and real hobby shops have zero balsa.
Picked up a few 1/8th sticks for receiver/servo mounts.
Next stop was the Hobby Shop where I found 2 gota have toys.
the Gee Bee R-2and the D.H. Mosquito!
The adoption fee was below unbelievable
Think I'm hooked?
So the current Curtiss project, not real sure what model as drawings of the F model or model 1 as the pictures have called it are wrong.
Did finally identify it as an MF model after getting started on the build!
Did change the tail to match the shape of the MF
I find no drawings of the MF but think I'm close!.
And almost finished! wing struts and bracing after some sleep!
For Sale Aerodrome RC Curtiss Jenny Kit N62350 Aircraft - Electric - Airplanes (FS/W) 0 Jan 25, 2013 04:55 PM
Discussion 1917 Curtiss Flying Boat mexico Your Plane Photos 20 Jul 30, 2010 07:53 AM
Discussion Curtiss F flying Boat Harold H. Duncan Waterplanes 2 Jan 06, 2009 03:30 AM
Build Log Curtiss Flying Boat sumomo Scale Kit/Scratch Built 35 Apr 03, 2008 09:18 PM
Link Glenn H. Curtiss Flying Boat 1914 America jimsp Waterplanes 0 Jun 21, 2007 10:01 PM
