Old Jan 29, 2013, 10:32 PM
sirzeppu's Avatar
United States, UT, Farmington
Joined Aug 2011
Topflite Stinson SR-9 Build
I am really excited for this one. I've never built anything this complex before. Should be fun!
Power will be a DLE30 I have on the shelf (tail will be reinforced, and will be purchasing TNT single piece gear). It might be a little over-powered and may require some weight up front to balance (strange combination, but the research seems to indicate it's true).
Finish will be Solartex with rib stitching from www.pink-it.com, then painted with Rustoleum in the colors of the prototype on the box. I like the looks of the plane on the box, plus this way I get to use the stock decals.
Here we go...
sirzeppu is offline Find More Posts by sirzeppu
Old Jan 29, 2013, 10:46 PM
wizard of odd's Avatar
Australia, WA, Kalgoorlie
Joined Apr 2011
Nice!
There's a really nice build thread for reference, recently completed, by Splinterz http://www.rcgroups.com/forums/showt...ight=splinterz
Good luck, keep the pictures coming!
wizard of odd is offline Find More Posts by wizard of odd
Old Jan 30, 2013, 07:01 AM
sirzeppu's Avatar
Joined Aug 2011
Thanks for the thread reference. I found another thread inside that one as well. So that gives me two really solid pieces of reference material. Thanks!
Old Jan 30, 2013, 03:06 PM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Welcome with your Classic....Man, there's a lot of Golden Age Models being built this winter !
I've built several of those as contract builds.
The tail has options for gas engines- just sheet it when you build.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: The 'Ancient Modeler"
Old Jan 30, 2013, 05:33 PM
sirzeppu's Avatar
Joined Aug 2011
I plan to sheet the tail. I had a question about that:
Since the tail will be completely sheeted, won't the cross bracing be redundant? The sheeting should perform the function of the bracing as well as adding rigidity overall, kind of like a semi-monocoque structure. If that's the case, can I leave the braces out to make it simpler/a bit lighter?
Old Jan 30, 2013, 05:39 PM
sirzeppu's Avatar
Joined Aug 2011
Got some stuff done today:
Inventory of wood/labeling pieces:
Building Horizontal Stab:
Sure am enjoying this build. I've done a couple of smaller, easy planes lately, and I had a long somewhat tedious scratch build before that. It's nice to dig into something that is well engineered, easy to put together, but meaty and not over too quickly.
Old Jan 30, 2013, 06:15 PM
epoxyearl's Avatar
Joined Oct 2011
Believe me -it won't be over too soon...I build one every so often , then swear I'll never do another....But that was the biggest reward I've gotten, when it WAS done.
The toughest parts were the wing rib "egg crate" slots, which are on a compound angle in the spars.....I fabricated a sanding board with sandpaper on both sides,and sanded vertically the rib openings,which slowly yielded a good fit.
A hand held hacksaw blade cut slots for the thin plywood spar reinforcements and dihedral joiners..which I passed over, originally..
Yes the extra bracing in the stab is redundant, when sheeting the stab.
The extra $100 bucks for fiberglass parts is money WELL spent.
The wing struts are window dressing, unsecured at the bottom (not an omission)...
Old Jan 30, 2013, 06:45 PM
sirzeppu's Avatar
Joined Aug 2011
Thanks Earl! I'll skip the bracing, get the fiberglass, and watch those points of the build you pointed out (and build/get the necessary tools).
Thanks again.
Old Jan 31, 2013, 07:56 AM
Hamburger Eatin' Fool
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I'm in. A friend purchased the glass parts that Earl suggests. He was very happy with them.
TomCrump is offline Find More Posts by TomCrump
Old Jan 31, 2013, 04:53 PM
sirzeppu's Avatar
Joined Aug 2011
Finished the stab today.
Got the top sheeted, removed the pins/jigs and flipped it over:
Sheeting the bottom:
Cutting around the strut mounts seemed simple enough:
But I missed the 1/8" for the TE and cut the hole oversize. Also got the length wrong:
Oops!
But I used the piece I cut out to add some material back in and got a decent fit:
After that the other side went much better:
And...done!
It's rough sanded, but per the instructions I did not round the leading edge. FWIW, when I fit the right side, bottom sheet in and it lined up perfectly, I was so excited I yelped. Man I'm a dork. But to see your skills improving with each step really is encouraging. Such fun.
Old Jan 31, 2013, 07:34 PM
epoxyearl's Avatar
Joined Oct 2011
Yeee hah !
I just finished sheeting a wing I designed myself..And I know the feeling you're talking about.
I'm making a prototype model of a full scale prototype, and it's under weight and over strength.....just what everyone dreams about.
Old Jan 31, 2013, 07:37 PM
sirzeppu's Avatar
Joined Aug 2011
That's amazing! Congrats...it is truly a dream when a plane is coming out that way. Here's to low wingloading and high strength!
Old Feb 01, 2013, 12:28 AM
Joined Apr 2011
@sirzeppu
Looking very nice, even with the "oops!"
@earl
You mean you're actually working on something and not posting pictures??? What kind of a man does that? (Well done mate!)
Old Feb 02, 2013, 05:44 PM
sirzeppu's Avatar
Joined Aug 2011
Originally Posted by wizard of odd View Post
@sirzeppu
Thanks!
Here are some pics from today:
LH Elevator is finished...so much fun build this plane. The structure is so rewarding and the pieces are so much bigger than what I am used to working with. I need a break from balsa dust and CA fumes!
Old Feb 02, 2013, 05:50 PM
TomCrump's Avatar
Joined Dec 2005
Nice progress !
Discussion About to build a Topflite Stinson...and never painted a plane before sirzeppu Giant Scale Airplanes 37 Apr 07, 2013 09:08 PM
Sold Parkzone Stinson SR-10 skcope Aircraft - Electric - Airplanes (FS/W) 2 Jan 31, 2013 06:36 PM
Build Log Top-flite Stinson SR-9 -> or SR-8??? mamethot Giant Scale Airplanes 20 Jan 30, 2013 04:39 PM
Sold Ikon N'West Stinson Reliant SR-9 Rosster Aircraft - Fuel - Airplanes (FS/W) 4 Jan 24, 2013 08:36 PM
1/4 scale Stinson SR-9 build Bish Wheeler Giant Scale Airplanes 5 Jul 02, 2005 09:13 AM
