Old Jan 29, 2013, 10:20 PM
karikamiya is offline
Find More Posts by karikamiya
No flying at the Tower
karikamiya's Avatar
Canada, NT, Inuvik
Joined Jun 2010
Question
Thrust tester
Hello, i've jury-rigged a thrust tester, but im having some trouble with the prop adapter.
Whats happening is the prop adapter uses a grub screw, but the motor doesn't have a flat part for the screw. This is an easy fix with a dremel, but what worries me is the amount of thrust it takes to pop off. When i pull it off by hand i record over 5 kg of pulling, but when it pops off rotating its only pulling .6kgs
any particular reason for this?
karikamiya is offline Find More Posts by karikamiya
Old Jan 29, 2013, 10:49 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Vibration causing it to loosen up? You using any loctite?
ilektron is offline Find More Posts by ilektron
Old Jan 30, 2013, 04:00 AM
karikamiya's Avatar
Canada, NT, Inuvik
Joined Jun 2010
You are indeed correct, i just looked at it after i induced a pop off and it was loose.
I will be buying some tomorrow. Could i loctite the smooth shaft too or does it only work on threads?
Old Jan 30, 2013, 10:45 AM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
You can loctite the smooth shaft, but I recommend against it. You may never get the prop adapter off if you do that.
Old Jan 30, 2013, 12:00 PM
Test Pilot Mafia is offline
Find More Posts by Test Pilot Mafia
CSU Chico, Flight Club
Test Pilot Mafia's Avatar
United States, CA, Chico
Joined Sep 2012
i had to rough up my Eflight shafts, or the collet prop carriers would slowly pop off over 2-3 minutes of rotating.
Test Pilot Mafia is offline Find More Posts by Test Pilot Mafia
Old Jan 30, 2013, 10:07 PM
karikamiya's Avatar
Canada, NT, Inuvik
Joined Jun 2010
So i rerigged the tester. I was unable to stop the pop offs, so i have combined the loctite with a ground notch into the side of the shaft for it to rest on.
It is working admirably now
Sold Esky EK2-0906 Battery Tester N3SHXX Aircraft - Electric - Multirotor (FS/W) 2 Jan 20, 2013 11:47 AM
Sold Esky EK2-0906 Battery Tester N3SHXX Aircraft - Electric - Helis (FS/W) 3 Jan 20, 2013 11:46 AM
Sold Esky EK2-0906 Battery Tester SOLD....!!! N3SHXX Aircraft - General - Radio Equipment (FS/W) 0 Jan 20, 2013 10:01 AM
Sold rc parts, Battery connectors, low voltage buzzers servo tester more ronzer Cars - Trucks and Parts (FS/W) 5 Jan 18, 2013 10:49 PM
Wanted Servo Tester Davidpe Aircraft - General - Miscellaneous (FS/W) 2 Jan 10, 2013 12:24 PM
