Old Dec 25, 2003, 10:29 AM
bztguy is offline
Find More Posts by bztguy
Leaf River IL.
Joined Sep 2001
How to wire brushless esc to motor?
Okay, this may be a dumb question. I just got my first brushless setup. A nippy outrunner with a Jeti 8-3 ESC. There are no wiring
diagrams with either one. Is there a specific way the 3 leads need to be connected to the motor? All the specs say is reversing any two leads will reverse motor direction.
bztguy is offline Find More Posts by bztguy
Old Dec 25, 2003, 10:54 AM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
hook all three wires up.
power up slowly.
if it runs reversed switch any two wires.
it works.
gregg f is offline Find More Posts by gregg f
Old Dec 25, 2003, 11:24 AM
eitansl is offline
Find More Posts by eitansl
Espoo-Finland
Joined Sep 2003
You can play with the "+ or -" ("red and black")
but the one in the middle (motor) should connect to the middle one on the ESC
Eitan
eitansl is offline Find More Posts by eitansl
Old Dec 25, 2003, 01:57 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
That is not correct. It makes no difference in which order the wires are connected to the ESC. There is no red/black/+/- on the nippy motors, just three connection pads (the wires in the attached picture are from the ESC, not supplied with the motor - and as you can see, I just happen to have mine connected white/red/black) As Gregg said, if it runs the wrong way, just switch any two.
..a
Old Dec 25, 2003, 06:21 PM
bztguy is offline
Leaf River IL.
Joined Sep 2001
thanks....will go and try it now
How does a Brushless ESC work? shaneyee Power Systems 19 Aug 31, 2014 03:19 PM
How to test brushless ESC and motor Syphonics DIY Electronics 1 May 30, 2005 03:54 AM
How to solder Bl esc to motor? JimF Power Systems 1 Dec 12, 2003 09:55 PM
WTB - Brushless ESC/motor for Corona J328 Aircraft - Electric - Airplanes (FS/W) 0 May 02, 2003 10:51 PM
How to wire switch to ESC AussieParkflyer Parkflyers 10 Feb 10, 2002 10:52 AM
