Old Jan 29, 2013, 06:39 PM
pyrohaz is offline
Find More Posts by pyrohaz
Joined Jan 2013
Question
Choosing a servo
Hey, I'd like help in knowing what "strength" servo i'll require for a task. I need a servo that will be able to pull the disc brake cable of an electric scooter. I have a servo with a stall torque of 1.5kg/cm at 4.8v. I will be running the system at 5vv.
Will this be sufficient? Or how will I go around choosing a sufficient servo?
Thanks, Harris
pyrohaz is offline Find More Posts by pyrohaz
Old Feb 01, 2013, 07:45 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
5 watts is not much. You will probably need a lever, or gearing to keep the amp draw down. To really figure it you need to know how much force it takes to pull the cable, how far, and how fast the cable needs pulled.
Roto Rob is offline Find More Posts by Roto Rob
Old Mar 01, 2013, 08:35 PM View Post
Umang Kumar
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Old Mar 02, 2013, 07:27 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
If you only need to apply the brakes once, you could use the servo to pull a pin, to release a spring. The spring applies the brakes.
Old Mar 13, 2013, 01:47 PM
Aaron 1 is offline
Find More Posts by Aaron 1
Joined Jun 2010
That's an air brake thingey and a reverse wheelie on a scooter. That would go viral on You tube with blood and all.
Aaron 1 is offline Find More Posts by Aaron 1
Discussion Can we move on from choo choo trains now? plowboy1966 Life, The Universe, and Politics 26 Mar 31, 2011 08:34 PM
Discussion Completed Project Choo...Choo... freddy warbird Life, The Universe, and Politics 9 Mar 27, 2011 04:00 PM
Chooing between the FSK Spitfire or FW190 two questions KasperE Parkflyers 1 Feb 11, 2004 11:07 AM
