NE Ohio
Joined Apr 2003
A good rule of thumb USED to be 1C , and a good rule of thumb I used for a few seasons was the actual discharge "C" rating divided by 10. For charging most all users and chargers have the cv to protect against an outrageous charge current. We don't have that during the discharge.
Your two packs were probably listed as 1C max rate and would be 5.3 and 2.4 amps respectively. Your new pack is probably a 5C rated charge rate so you have that one correct as 27 amps. Please be advised that your old 13C pack and your old 20C pack may now be less than half of those numbers now. |
1C charge rates were very common and standard up until a few years ago, then some manufacturers approved 2C rates, then 5C, etc.. The Thunder Power packs I use now are rated up to 12C charge rate. You shouldn't charge older batteries higher than they were originally spec'ed for, if the label doesn't clearly indicate higher than 1C charge rates then stick to 1C...
Jack |
all good information however, whats a matter for you, can't you check your batteries while they are charging?
Of course you can. First rule of thumb is that lipo's should not get warmer during charge and in fact, if you charge just after a flight (and the lipo is already warm) then it should cool down during the charge. Second, check to see if your lipo is puffing during the charge and if so, stop the charge! Basically, it comes down to common sense vs printed media and what someone else said. With lipo's, it pays to err on the side of caution! I love lipo's and I assume that all is NOT well, until I can prove otherwise! ![]() Michael (if your not fryin, your not tryin!) |
Joined Feb 2012
A question that has never been adequately explained, in so far as I know, is, if a pack can be specified as having a 25 C continuous discharge rate, then why cannot it have also a 25C charge rate?
I see no reason why it can't be charged as fast as it can safely be discharged, but I willingly profess ignorance and would like to be educated on the matter. Does the reason for the difference in charging rate as opposed to discharging rate lie in the way a battery charges as opposed to discharges? Is it a matter of affecting longevity of capacity or is it actually a safety issue? If either one or both an explanation of what is happening to the battery would be most welcome. Also, and related, why has it always been assumed that a 1C discharge rate has been the norm? |
United Kingdom, England, Ware
Joined Aug 2012
[QUOTE=midnite;23986871]A question that has never been adequately explained, in so far as I know, is, if a pack can be specified as having a 25 C continuous discharge rate, then why cannot it have also a 25C charge rate?
I see no reason why it can't be charged as fast as it can safely be discharged, but I willingly profess ignorance and would like to be educated Not trying to be smart but many battery manufactures are generous with the ratings they give their product .Never is there any specific as to is that a burst current and for what period i.e. 1 second or 1 hour If you do a search there are posts covering extensive tests undertaken to determine the correct rating Try running at the stated C rating where good chance the battery will curl up and die ![]() Another factor is you would need a massive DC power supply to have sufficient output to charge at very high C ratings Cheers Jim ![]() |
It has always been my opinion that the quality of the charger is the limiting factor on charge rates. As long as the charger balancing circuit can keep any cell from going over 4.2 volts the charging amps are safe. About six years ago I inadvertently charged a pack at 5C. The pack did not even get warm and all cells were at 4.2V at the end of the charge. I was using an FMA 10S charger. Glen |
[QUOTE=Jimob23;24018230]
How massive? |
| Thread Tools | |
| Discussion can i charge a NIMH at 1c? | colj00 | Electric Plane Talk | 22 | Feb 01, 2013 11:09 PM |
| Discussion Can you confirm 'c' charge rate please. | littleimp | Batteries and Chargers | 4 | Dec 29, 2011 10:03 AM |
| Discussion Relationship between power supply output and charge rate (?) | KRProton | Batteries and Chargers | 13 | Jun 23, 2011 09:28 AM |
| Question can the battery C-rating effect my charge rate? 1C is getting boring!!! | SmoothCruizer2 | Batteries and Chargers | 10 | Feb 12, 2009 08:48 AM |
| Can some one explain the C in charge rate? And what do you charge your He-cell at? | rspiegel | Batteries and Chargers | 10 | Jan 08, 2003 09:50 AM |
