Jan 30, 2013, 12:28 AM
Joined Apr 2009
Planes designed like the Zone-V2 are designed to be able to start out high on launch and to be able to move around the sky well. The idea is that once one has lift, the game is mostly over anyway. Suppose someone else finds lift and one is in the wrong place? A plane which can move fast and flat has a greater chance of getting there. A plane that is light doesn't need a whole lot of lift and doesn't need the best power factor at float speeds. But, a wing which can take a lot of camber can recover the power factor*. A plane which can fly fast for its weight can go downwind to the lift, climb in it, and then come home. A plane which cannot, needs to be able to climb even better just to get back. If there is absolutely no lift to be had, or even worse, nothing but sink, then launching high is an advantage.
If one makes the right choices then the plane choice should only make a small difference in the possible results. This may occasionally be an important difference, but often it is not. Usually it is the pilot which matters and not the plane (within reason of course). But if one makes the wrong choice and is in the wrong air or in the wrong part of the field to hitch the winning ride that someone else found, then a plane which can bridge the gap in time and with enough altitude left just might save the day.
That's a bit of the idea behind designs such as the Zone-V2.
Now the reference design for the Zone-V2 moldie wing was made with particular attention to handling qualities. It is not a simple linear or near linear progression of airfoils; there is a little bit of complexity there.
The original Zone series, as is used in the FW5Flo, is not related to the Zone-V2 series except in name and some similarity in design goals. The XXLite uses the majority of the Zone-V2 series but not the whole series in a rather high aspect ratio wing. Going high aspect ratio like that certainly boosts launch height! But it also gives up performance across the board in other respects. Being light enough can make up for a lot of that though. But in general, it is different enough from the reference design and "normal" aspect ratios that one shouldn't use it as a benchmark for what a "normal" Zone-V2 wing should achieve. Changing aspect ratio a lot alters too many things.
Wings such as the Zone-V2 have some differences in characteristics compared to the majority of the wings out there. The range of useful camber is large. It is funny but some wing designs benefit from a large camber range but others do not. It is a bit hard to predict in advance how much camber one can really get away with in real life. In modeling, pretty much any design shows potential to use a fair bit of camber to improve min sink (boost power factor) but it is often not the case with a real wing.
Zone-V2 designs have a reputation for being able to profitably use a lot of camber at times. The flip side of this is that the pilot should be prepared to adjust the camber more frequently and over a greater range than is the case for most wings. So, there is a learning curve. Flying such as wing the way one would fly a plane such as the Sirius (just to pick an example) leaves a lot of potential performance on the table.
* The envilope of performance of a wing is worth considering. This is what it can do, provided it is always set at the optimal camber for the conditions. Comparing wings at, say, 4 degrees camber and calling that the float setting for each isn't really true even if that is what one might often do. Perhaps for matching conditions, one wing should really be at 5 degrees instead of 4. Now the analysis changes.
So, instead of fixed camber analysis, generate a curve of L/D or of power factor as a function of lift coefficient (or equivalently of airspeed) for the appropriate turbulence level (vaguely approximate by ncrit perhaps). But, use the optimal camber for each lift coefficient. One finds that the optimal camber is not a constant, but changes over this range. The resultant curve is an indication of the maximum performance achievable by the design provided the pilot could make the perfect choices all the time.
But let's back up to the fixed camber method of examining things, and go back in history to the original Zone design. When it came out, the usual planes of that era operated in float mode with something around 3.5 to 4 degrees of camber, depending on the design (referenced to speed mode). Now occasionally in perfect dead air conditions a little more camber was usable, but pretty much only then.
If one looked at the Zone design at that same camber, then one concludes it isn't as good as one might want at floating. But what one should notice is that the optimal speed for a Zone wing at that camber setting is a bit faster than for other wing designs of the time. So let's slow the wing down. How do we do that? Add more camber. Now the speeds match, but suddenly the Zone wing has a very good power factor so it floats nicely.
The peculiarities of the Zone wing design allowed it to use the extra camber easily, whereas other designs struggled more with the extra camber as they were optimal for even slower speeds where the piloting margin was lower, and in many cases the wings wouldn't do it in real life anyway. But the Zone would. So it could cover the other planes in cruise with a 4 degree "float" setting, cover the other planes in float with a 6 degree slower "float" setting, and run figurative rings around them in cruise or speed mode. So it had a wider usable speed range of good performance for the same wing loading.
Anyway that was with the version of wing design that I flew for a while but it is a bit different than the design used in the FW5. I've flown both and they do not fly the same at all. It is amazing the differences planform and washout pattern make in the behavior of a wing. I'm not dissing the FW5, just indicating that it shouldn't be taken as exactly representative of the reference Zone wing flight characteristics, any more than the Helios or the XXLite or some other Zone-V2 wings should be taken as exactly representative of the Zone-V2 moldie reference design flight characteristics. Do the Helios and the XXLite fly the same? The devil is in the details.
Gerald
Reason: spelling
