Old Jan 29, 2013, 05:53 PM
sliderguy is offline
Find More Posts by sliderguy
Joined May 2010
ESC brushless 60amp wires
Hi guys i have a 60amp brushless esc. I have also got a 540 brushless 12T motor. The wires were not included.
I want to extend the wires from the ESC to the motor. Which wires do i use? Is this a simple case of getting 14 awg wires and extend all 3 wires to my desired length and then simple case of solder, OR do i need ESC extention cables?
Since the cables were not provided with the motor would it be ideal to solder the wires from the motor and then connect to the esc with bullet connectors.
What is the best option?
sliderguy is offline Find More Posts by sliderguy
Old Jan 29, 2013, 07:59 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Just use the same gauge wire that the ESC came with and you'll be fine.
wparsons is offline Find More Posts by wparsons
Old Jan 31, 2013, 02:32 PM
Joined May 2010
I have terminates on the brush-less motor. Its just the case of soldering the 3 wires per terminal. Would i need to heat shrink each terminal?
Old Jan 31, 2013, 04:32 PM
imgumby is offline
Find More Posts by imgumby
imgumby's Avatar
United States, CA, Pinole
Joined Jan 2009
Heat shrink at the motor terminals really isn't needed since they're static but couldn't hurt.Insulating any loose connector ends is a must however.
hope this helps
imgumby
imgumby is offline Find More Posts by imgumby
Question wires on brushless ESC Blind Bay Power Systems 3 Jan 20, 2013 03:10 PM
Sold Eflite 60amp esc with bec and switch brand new Eboyles Aircraft - Electric - Power Systems (FS/W) 1 Jan 18, 2013 02:51 PM
For Sale Good Condition Align 60amp ESC ($35 Shipped) helinut4ever Aircraft - Electric - Helis (FS/W) 0 Jan 12, 2013 09:16 PM
For Sale Align 60amp ESC ($35 Shipped!) helinut4ever Aircraft - Electric - Helis (FS/W) 0 Jan 09, 2013 04:02 PM
Sold Castle Creation 60AMP ESC bighead93 Aircraft - Electric - Power Systems (FS/W) 2 Jan 04, 2013 05:51 PM
