Old Jan 29, 2013, 05:31 PM
siandhell is offline
Find More Posts by siandhell
Joined Jan 2013
trex 450 pro v2 collective pitch?
Hi could any one advise me on the collective pitch to set for this bird? it says in the instructions min 9 but i have been told that seems a little for a beginner? Many thx if anyone can help
siandhell is offline Find More Posts by siandhell
Old Jan 29, 2013, 05:32 PM
Joined Jan 2013
Sorry meant to say that seems a little strong for a beginner!!
Old Jan 29, 2013, 06:08 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
+9* of pitch is fine for beginner. However, -9* of pitch could be problematic in a panic situation. In an up-right hover a "quick" pull down on the collective (pitch) will result in the heli getting "slam" down into the ground.
To be safe, reduce the negative pitch to about -5*.
chopper62 is offline Find More Posts by chopper62
Old Jan 29, 2013, 11:37 PM
old4570 is online now
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
Eeeer
How much of a beginner ?
Total Noob , Id say no negative pitch at all ... Forget about 3D settings and think Noob starting to fly settings ..
old4570 is online now Find More Posts by old4570
Old Jan 30, 2013, 01:00 AM
ASTREA1 is offline
Find More Posts by ASTREA1
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
As long as hes learning to fly in calm conditions..I've been at hover power keeping her about eye level and then a gust came and I watched her keep climbing as I damn near chopped throttle to get her back down..I would say -3-4 deg would be safe to have at low stick.
ASTREA1 is offline Find More Posts by ASTREA1
Old Jan 30, 2013, 12:22 PM
Joined Jan 2013
Cheers guys think ill go for about 4/5 degrees but i dont no how to get rid of the negative pitch though? Or would 4/5 negative be ok for a noob?
Old Jan 30, 2013, 01:49 PM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
In my T-Rex 500 manual they recommended +12 to -2 for "normal" flight, with +3 at mid-stick.
As mentioned in post #5, some negative is sometimes needed to bring it down when a gust starts to lift it. In fact, for that very reason I also changed my throttle curve from the normally-recommended "normal" curve, to keep the head speed high until I get down to about the bottom 1/4 of the stick position. That prevents the motor bogging down when I have to go negative to stop it lifting in a gust, and then positive again when the gust dies down and the model drops.
abenn is online now Find More Posts by abenn
Old Feb 01, 2013, 10:37 AM
Joined Jan 2013
Thanks guys f all yr help . next question does anyone no why my tail servo will only work one way .no left turn ?
Old Sep 12, 2013, 03:40 PM
Joined Jan 2013
Can anyone please help me its been over 200 days since I gave up with my trex450 v2 pro and I still cant solve why my tail servo only works one way, no left turn.
ive still never flown this yet!!!!!!!:[
Old Sep 12, 2013, 03:52 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Do you mean the servo arm only moves one way? Have you detached the linkage and tried it?
Balr14 is offline Find More Posts by Balr14
Old Sep 12, 2013, 05:13 PM
Joined Jan 2013
Yes ive detached the linkage ?
Old Sep 12, 2013, 05:23 PM
Joined Jan 2013
Im running a dx6i, spectrum ar6115e reciever to if that helps ?
Old Sep 13, 2013, 12:05 PM
mdugas is offline
Find More Posts by mdugas
Joined Aug 2003
hi you havent answered the first question yet ,try that in rate mode .
mdugas is offline Find More Posts by mdugas
Old Sep 13, 2013, 12:32 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Have you tried moving the rudder left and right and seeing if the tail servo moves both directions? If the tail servo moves both ways, you either have a problem with your gyro, your initial pitch setting on the tail, or your servo arm positioning.
Old Sep 19, 2013, 06:17 AM
dceng888 is offline
Find More Posts by dceng888
I can fly!
dceng888's Avatar
Australia, TAS, East Launceston
Joined Aug 2010
Hi Siandhell, have you sorted this yet? If you have checked the tail moves freely and you have a good amount of pitch on the tail blades and the gyro is controlling in the right direction I would look at your head speed.
With a linear throttle curve as most beginners start with the head speed and consequently tail speed is relatively low at take off stick position. This means the tail authority is rather low. Right turns are with the main rotor blade rotation and left turns are against, so the left turn requires more power.
The solution is to increase the lower end of the throttle curve something like 0-50-75-80-80 should work.
dceng888 is offline Find More Posts by dceng888
Sold Align Trex 450 f.a.r.m.e.r Aircraft - Electric - Helis (FS/W) 3 Jan 29, 2013 07:57 PM
Sold Align Trex 450 Pro v2 DFC w/3gx Fbl system + CT6a $300. greenz Aircraft - Electric - Helis (FS/W) 1 Jan 26, 2013 11:37 PM
Discussion trex 450 v2 pro siandhell Electric Heli Talk 18 Jan 16, 2013 08:43 AM
Discussion trex 450 v2 pro siandhell Power Systems 2 Jan 07, 2013 11:42 AM
Discussion trex 450 v2 pro siandhell Beginner Training Area (Aircraft-Electric) 2 Jan 07, 2013 11:29 AM
